Comparator External Connections
I am attempting to use the COMP section to build a relaxation oscillator. There appear to be a number of interactions between sections, some of which are subtly documented and some for which I find no documentation. For instance, the inability to set a GPIO output once a task is connected to a pin is documented but well-hidden. The fact that enabling a pin as a comparator input completely disables both digital inputs and digital outputs is not documented anywhere that I can find.
Bottom line is that I have everything working nicely as it should, except that the comparator sometimes appears to miss a transition and thereafter is hung. I fundamentally just need to be able to place the comparator output on a digital output pin, but the only way I can find to do that is via the crossing events from the comparator, feeding set and clr tasks of GPIOTE. This causes the same sort of problems as the early IBM PCs using edge-triggered interrupts: If you miss one, you're dead forever. Is there a better way to get the comparator output to appear on a pin? If not, how best can I initialize things to ensure that I don't miss a transition?
  • Unfortunately, I have no installation of the Nordic SDK at the moment. And I only used the nrfx library, so I have no experience on a register level. By looking at the datasheet, I can theorize that you can turn on/off a small hysteresis of 50 mV with the HYST register. I guess this is for the differential input of the operational amplifier (like setting the input offset voltage to 50 mV). My guess is that you would have to use external resistors and implement a classical Schmitt trigger circuit.
  • I can, if I must, use the 50 mV hysteresis with an external reference voltage. But the best I can do so far, whether diff or SE, etc., is to have switching at 150 mV & 350 mV. None of the register settings seem to have any influence.
  • A closer read of the datasheet shows that, counterintuitively, I must run the comparator in single-ended mode to accomplish what I want. It appears to work correctly with REFSEL set to 4 (Vdd) and adjusting the values in the TH registers works as expected - except that they must be kept close to their limits. I can live with that. But according to the DS I should be able to set REFSEL to 7 (ext ref) and then select an ADC pin to use as the reference. I have an external voltage calibrator connected to my selected AinX pin, but even with the calibrator voltage set the same as Vdd (3.3V), I don't get any action from the comparator. There is no value given in the datasheet for AREFMIN - the only reference to that value is under REFSEL.
    It would be most helpful to have an actual schematic of what's going on inside the chip, because not all of the registers have the stated effects.
  • The above works only if I select 4 (Vdd) for Vref. Per datasheet Figure 112: Comparator in single-ended mode, I should be able to feed Vref via Ain7 by selecting REFSEL 7 and EXTREFSEL 7. Even if I feed the same voltage as Vcc (external voltage calibrator), I can't get it to run correctly. Has anyone actually used these documented features of the COMP? Do they actually work? Nothing in the errata to suggest a problem.
  • Further (strange) info. I accidentally blipped 5V into Ain7, and things started working unexpectedly. Without doing that, only 4 (Vref = Vdd) works, and only if TH up & down are kept near the rails. But if I select other values for REFSEL, start it up, then blip Ain7 to 5V momentarily and back to 3V, I get the following results for the stated values of REFSEL:
    0 - 1.2V ref
    1 - 1.8V ref
    2 - 2.4V ref
    3 - 3.0V ref <<<<<undocumented
    4 - Vdd ref
    5 - no action
    6 - no action
    7 - no action <<<<<should use the AinX pin selected by EXTREFSEL
    I know about the parasitic clamp diodes, but why should smacking Vdd with a gentle nudge start COMP working? My voltage calibrator signal "overload" at 5V, so clearly the clamp diodes are doing there thing.
