nRF5 SDK for Mesh v3.0.0 PERSISTENT_STORAGE Macro Enable Create issue.
Hii,
I'm using Nordic nRF5 SDK for Mesh v3.0.0 Example Code in LIGHT SW Provisioner Example i got Error code please healp me how to solve.
In Case Of
 #define PERSISTENT_STORAGE 1
if  #define PERSISTENT_STORAGE 0 then works well. i want to store server and client data in stack so please help me out of it.
-Nikunj
  • Thanks its work well ..
    i want to send string like 10 byte using ble mesh is it possible..?
  • Edvin
    Thanks .but i have one  query , I'm using LIGHT SWITCH Example code.i want to send LIGHT ON/OFF Command Every 5 Second base on timer interpret instead of button pressed. In this scenario code stuck.
    Best Regards,
    Nikunj
  • Hello Nikunj,
    Have you tried to set up the timer? Does it trigger? I am not sure where the code is stuck without some more details.
  • void msg_send_to_server()
         uint8_t Data_Buff[50] ="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwx";
        uint32_t status = NRF_SUCCESS;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
        memcpy(set_params.on_off,Data_Buff,sizeof(Data_Buff));
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;//50MS
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;//100MS
        status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
        if(status==0)
          __LOG(LOG_SRC_APP, LOG_LEVEL_INFO,"\nClient Send:%s  LEN:%d\r\n",set_params.on_off,sizeof(Data_Buff));
    //    status = generic_onoff_client_set_unack(&m_clients[0], &set_params,&transition_params, 0);//APP_UNACK_MSG_REPEAT_COUNT
    //    if(status==0)
    //      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO,"\nClient Send:%s  LEN:%d\r\n",set_params.on_off,sizeof(Data_Buff));
        switch (status)
            case NRF_SUCCESS:
            case NRF_ERROR_NO_MEM:
            case NRF_ERROR_BUSY:
            case NRF_ERROR_INVALID_STATE:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nClient %u cannot send\r\n");
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
            case NRF_ERROR_INVALID_PARAM:
                /* Publication not enabled for this client. One (or more) of the following is wrong:
                 * - An application key is missing, or there is no application key bound to the model
                 * - The client does not have its publication state set
                 * It is the provisioner that adds an application key, binds it to the model and sets
                 * the model's publication state.
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\n Publication not configured for client %u\r\n");
                ERROR_CHECK(status);
       //hal_led_blink_ms(1 << BSP_LED_3, LED_BLINK_INTERVAL_MS, 1);
    APP_TIMER_DEF(m_temp_timer);
    uint8_t sec_2 =0;
    static void temp_handler(void * p_context)
      UNUSED_VARIABLE(p_context);
      sec_2=1;
    static void initialize(void)
          uart_init();
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO,"\n----- BLE Mesh Light Switch Client Demo -----\r\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
    #if MESH_FEATURE_GATT_ENABLED
        gap_params_init();
        conn_params_init();
        mesh_init();
       ERROR_CHECK(app_timer_create(&m_temp_timer, APP_TIMER_MODE_REPEATED, temp_handler));
       ERROR_CHECK(app_timer_start(m_temp_timer, MAX(APP_TIMER_MIN_TIMEOUT_TICKS, HAL_MS_TO_RTC_TICKS(2000)), NULL));
       initialize();
        start();
        for (;;)
           if(sec_2)
             msg_send_to_server();
             //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO,"\n----- 2Second Timer Run-----\r\n");
             sec_2=0;
            (void)sd_app_evt_wait();
    Got an Error below
    If i send command on Button press and only print timer line every 2 sec working ok but when i send command every 2 sec (single Byte oR bool data ) code is stuck.
    Nikunj
