Problems flashing the DFU on the Eval Kit
I am using the GCC DFU project provided by Nordic on GitHub (devzone.nordicsemi.com/.../)
I altered the main.c to trigger to DFU mode based on the contents of the GPREGRET register rather than Button 7. However when I try and Flash the .hex file (bootloader_gcc_xxaa.hex) of the project on nRFgo Studio I get the follow error. The hex file has data in SoftDevice region. Try programming using "Program SoftDevice", or erase all before programming.
Can I (,how can i) alter this project to not reside in the SoftDevice region or do I have to fully integrate it with the SoftDevice (7.0.0) .hex?
Thank you for your help.
P.S. I am using rRFgo Studio 1.17.1 to flash
nrf51_bootloader_gcc-master.zip
  • Thanks for your help. I had copied those files to the template/gcc folder. However I still had the same issue. I found another version of the DFU GCC project on the Nordic Github page (github.com/.../bootloader - gcc - BLE) When using this project, everything will compile and seems to flash. However when I try and Flash my application on top of the SoftDevice and the Bootloader, the Application verification fails. This is not the case when there is no bootloader. I did notice as you mentioned, that my bootloader hex file is incorrectly named bootloader.hex. So its not linking properly. I can't seem to fix this issue!
  • Also noted that when I build the Nordic DFU project from GitHub, the bootloader.bin file is 261,937kB in size. So quite my project it definately not linking to the linker file properly. However I do not have any option in Eclipse to set the linker file paths. Isn't this done via the Makefile, which is already correctly referenced as the project compiles?
  • Just to double check: I have the SoftDevice, My Application Project, and my DFU Application Project (bootloader - gcc - BLE). I first Erase-All, then flash the SoftDevice (88kB), then flash the .hex output of the DFU project (54kB), then My Application Project .hex code (112kB). Total memory usage is therefore 254kB. I don't think there is sufficient Flash memory to complete any OTA upgrade?
  • Could you try to copy your DFU project in to a fresh install of the SDK under the "device_firmware_updates" folder , and copy in the linker files to the template/gcc folder? Then in eclipse, import you project as a Makefile project and add /gcc to the build directory. This is what I did at least.
    There is also a .map file in the Build folder, could you send me this file for both the DFU and the Application, so I can check and see what went wrong during the linking?
    Just to check, the application has to be flashed through the bootloader, if you are using a bootloader, not in nRFgo Studio.
    Could you send me you app .hex file so I can test it?
  • I cannot get the project to compile if I remove the linker script gcc_nrf51_bootloader_xxaa.ld from the /gcc folder in the project and paste it in the template/gcc folder.
    Thanks for the assistance, but i cannot share .hex or .map files on a public forum. I'll move this to the customer portal.
