getting started: can't load project file: 'solution load command failed (-1)'
Hello.  I'm just trying to get going with the nRF9160 DK which just arrived.
Using macOS.
Followed Getting Started and then nRF Connect Getting Started Assistant, and everything was going quite well.
However, when I got to the point of Open nRF Connect SDK Project, regardless of whether I try it with the asset_tracker or the secure_boot, immediately after filling out the paths in that initial dialog, I get "Can't load project file" / "The project file '/Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/build/secure_boot.emProject' is invalid.
The reported error is 'solution load command failed (-1)'
I've verified all the paths, etc., and all seems fine.
Screen shot below.
Any ideas how to move forward?
Thanks.
  • Most likely the issue is that you are using v8 of the armemb toolchain. There is a bug when compiling nRF91 examples from Nordic Connect SDK with this version which has already been reported. The solution for now is to download & use the v7 (q2 2018) of the armemb toolchain. That should most likely make this error disappear.
  • I just rm -rf'ed the old sdk, and downloaded and replaced it with:
    gcc-arm-none-eabi-7-2018-q2-update-mac.tar.bz2
    I then restarted segger.   Same failure:
    Loading solution secure_boot.emProject
    Executing load commands
    /usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=/Users/rozzie/dev/nrf/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb -B/Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/build -H/Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -DDTC_OVERLAY_FILE=/Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/nrf9160_pca10090.overlay
    -- Found PythonInterp: /usr/local/bin/python3 (found suitable version "3.7.2", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090
    Zephyr version: 1.13.99
    Parsing Kconfig tree in /Users/rozzie/dev/nrf/ncs/zephyr/Kconfig
    Loading /Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/build/zephyr/.config as base
    -- Loading /Users/rozzie/dev/nrf/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying /Users/rozzie/dev/nrf/ncs/zephyr/dts/common/common.dts
    -- Overlaying /Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/nrf9160_pca10090.overlay
    nrf9160_pca10090.dts_compiled: Warning (unit_address_format): /soc/adc@0x5000e000: unit name should not have leading "0x"
    nrf9160_pca10090.dts_compiled: Warning (unit_address_format): /soc/ficr@00ff0000: unit name should not have leading 0s
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@50008000: duplicate unit-address (also used in node /soc/i2c@50008000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@50009000: duplicate unit-address (also used in node /soc/i2c@50009000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@5000a000: duplicate unit-address (also used in node /soc/i2c@5000a000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@5000b000: duplicate unit-address (also used in node /soc/i2c@5000b000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@50008000: duplicate unit-address (also used in node /soc/spi@50008000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@50008000: duplicate unit-address (also used in node /soc/spi@50008000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@50009000: duplicate unit-address (also used in node /soc/spi@50009000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@50009000: duplicate unit-address (also used in node /soc/spi@50009000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@5000a000: duplicate unit-address (also used in node /soc/spi@5000a000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@5000a000: duplicate unit-address (also used in node /soc/spi@5000a000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@5000b000: duplicate unit-address (also used in node /soc/spi@5000b000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@5000b000: duplicate unit-address (also used in node /soc/spi@5000b000)
    nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/clock@50005000: duplicate unit-address (also used in node /soc/power@50005000)
    -- Cache files will be written to: /Users/rozzie/Library/Caches/zephyr
    -- The C compiler identification is GNU 7.3.1
    -- The CXX compiler identification is GNU 7.3.1
    -- Found assembler: /opt/gnuarmemb/bin/arm-none-eabi-gcc
    -- Performing Test toolchain_is_ok
    -- Performing Test toolchain_is_ok - Success
    CMake Warning (dev) at /Users/rozzie/dev/nrf/ncs/zephyr/cmake/extensions.cmake:837 (target_link_libraries):
      Policy CMP0079 is not set: target_link_libraries allows use with targets in
      other directories.  Run "cmake --help-policy CMP0079" for policy details.
      Use the cmake_policy command to set the policy and suppress this warning.
      Target
        zephyr_interface
      is not created in this directory.  For compatibility with older versions of
      CMake, link library
        -mabi=aapcs
      will be looked up in the directory in which the target was created rather
      than in this calling directory.
      /Users/rozzie/dev/nrf/ncs/zephyr/cmake/extensions.cmake:1055 (target_link_libraries_ifdef)
      /Users/rozzie/dev/nrf/ncs/zephyr/cmake/extensions.cmake:115 (target_ld_options)
      /Users/rozzie/dev/nrf/ncs/zephyr/arch/arm/CMakeLists.txt:20 (zephyr_ld_options)
    This warning is for project developers.  Use -Wno-dev to suppress it.
      Target
        zephyr_interface
      CMake, link library
        -march=armv8-m.main+dsp
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/rozzie/dev/nrf/ncs/nrf/samples/nrf9160/secure_boot/build
    /Applications/SEGGER NORDIC/bin/ninja_import zephyr/zephyr.elf zephyr/liboffsets.a zephyr/liboutput_lib.a zephyr/libpriv_stacks_output_lib.a zephyr/app_sizing_prebuilt.elf zephyr/zephyr_prebuilt.elf zephyr/zephyr_app_sizing_prebuilt.elf zephyr/priv_stacks_prebuilt.elf
    Project load failed
    Reported error: solution load command failed (-1)
  • I just tested running the whole nRF91 Getting Started Assistant v0.5.1 from nRF Connect v2.6.0. I have been running it on a Mac Book Air from Mid 2011 running macOS Sierra Version 10.12.6. The mac is so old that I am not able to upgrade to the latest & greatest OS. It should work with newer versions of MacOS too.
    I followed the whole getting started assistant & was able to successfully open & compile the secure boot example. Unfortunately, I was unable to reproduce your issue. The output I received when opening the asset tracker example (i.e. from Output window, Show: Transcript, Output tab) was a lot shorter:
    Preparing project 'zephyr/kernel/libkernel.a'
    Restoring state from previous session
    Preparing to load data
    Loading session data from file
    SEGGER Embedded Studio is ready to use
    For some reason, the Getting Started Assistant suggests to extract gnuarmemb in the /opt/gnuarmemb folder. At first, I could not find the opt folder, so I decided to place it in the /Applications/gnuarmemb folder. I was able to successfully open & build the secure boot example that way.
    Next, I tried placing the gnuarmemb folder inside /usr/local/opt/gnuarmemb. That worked too. The path of the gnuarmemb folder was the only thing that I changed compared with what the Getting Started Assistant said to do. Hopefully that will help in solving your problem!
  • I think you may skip some instructions of the 3rd step while installing nRF Connect SDK
  • Why would you want to skip those steps? I believe they are required to properly setup the Nordic Connect SDK.
