Increasing number of bytes in HID descriptor
I'm working on hid keyboard example. How can I check whether multiple bytes are received & transmitted after I increase the assigned no. of bytes in input/output report? From the code I understood that nrf device can send 64 bytes to host device. So how do I append bytes in one packet of 64 bytes when sending to host? How does it work from host side? Does nrf read 1 byte at a time sent from host?
  • I'm using SDK15.2. Similarly for output report I noticed that nrfConnect can only send a byte to nrf device. Can more bytes be sent? If yes, then after changing the descriptor where else do I make the necessary changes?
    Also is the IN/OUT endpoint configured to send/receive data on receiving an IN/OUT token packet?
    What can be the maximum input/output buffer size?
  • What API are you using for developing the host application, specifically the HID portion?
  • To summarize –
    I am using SDK 15.2. I am trying to develop host application for packet size of 20 bytes.
    1. How to I increase the no of bytes assigned for input & output reports besides the report descriptor? In which locations is the packet size actually being checked for input & output reports?
    2. What is the maximum size possible for input & output reports for Windows & MAC OS?
    3. Do you think if the host sends packet of 64 bytes, nrf chip will be in a position to handle that size? nrfConnect can send only a byte to nrf device.
    4. Is IN/OUT endpoint configured to send/receive data on receiving an IN/OUT token packet?
     The original working code-
    Steps to execution-
    1. Press button 2 to see data received on nrfConnect
    2. Send any non-zero data from nrfConnect and led glows on nrf52832 kit.
    Question - Even though the report count =1 & report size = 8 bits, how can the host receive more than a byte?
    I tried to increase the packet size to 20 bytes only for input report but the buffer can fill only first few bytes out of 20 bytes. Why so?
    The result for above code on an api other than nrfConnect-
    I’m closely following Jan Axelson’s research and her hid api. But on her hid api I do not receive any data? I can send data to nrf device but does not seem like it is receiving any, although I get a message that output report is sent.
    I also tried https://github.com/signal11/hidapi for BLE HID, but similar behavior there as well.
    Thanks, awaiting your speedy reply.
  • Maybe I should try this for myself. Are you using nRF Connect for Desktop to monitor HID data received from the nrf device? How does that work?
  • Thanks Hakon! I receive data on nrfConnect but not after increasing packet size. I have been struggling to find answers to above questions for a while now.
