I am facing problem while developing code for the application.
I am working on the "ble_app_uart" example code to develop my one of the application, But after making some custom changes into the code it stops showing the "DEVICE_NAME" in nRF Connect Nordic application.
I have added some of the code from the "Beacon" project to advertise the company and devices type & all.
Here after adding all these line of code into the "ble_app_uart" from the "Beacon" project it stop showing the DEVICE_NAME in the application. I don't know why is it so.
Can you please guide to resolve this error.
For more I am sharing code which i have used for advertising:
#define DEVICE_NAME "SSLBL"
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS 60 /**< The advertising timeout (in units of seconds). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define APP_TAG_INFO_LENGTH 0x17 /**< Total length of information advertised by the TAG. */
#define APP_ADV_DATA_LENGTH 0x16 /**< Length of manufacturer specific data in the advertisement. */
#define APP_COMPANY_IDENTIFIER 0x02A1 /**< Company identifier for ASA. as per www.bluetooth.org. */
#define APP_FM_VER 0x02, 0x03 /**< Firmware Version */
#define APP_HW_VER 0x04, 0x05 /**< Hardware Version */
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scanrsp;
ble_adv_modes_config_t options;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scanrsp.uuids_complete.p_uuids = m_adv_uuids;
manuf_specific_data.data.p_data = (uint8_t *) m_tag_info;
manuf_specific_data.data.size = APP_TAG_INFO_LENGTH;
// Build and set advertising data.
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
err_code = ble_advdata_set(&advdata, NULL);
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
memset(&options, 0, sizeof(options));
options.ble_adv_fast_enabled = true;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
And also I am sharing the screenshot of my application more clarification.
