May I know what is the hardware layout for measuring external voltage using SAADC? I may not be understanding the infocenter or the datasheet for setting the external reference pin
Thank you!
Thank you!
Hi Luke
Luke.L said:
************ Solved **************
Make sure the gain settings is within the voltage range
Do you mean that you solved both issues by this, or does the fluctuation problem still persist?
Simon
Hi Simonr
The fluctuation problem still occurs. Even when tying the voltage divider tying to ground, I get the following results(in V):
<info> app: 0.15
<info> app: 0.12
<info> app: 0.09
<info> app: 0.15
<info> app: 0.12
<info> app: 0.12
<info> app: 0.14
<info> app: 0.11
<info> app: 0.09
<info> app: 0.12
I am not sure if this is related to the precision of the ADC, but in my application I am required to detect voltage levels from 25-4v, this leads to me using a fairly high step down in my voltage divider, R1: 1M ohm, R2: 100k ohms. Would this setup cause problems? Should I revert to software filtering instead?
Hi Luke
We can't find anything wrong with your voltage divider, and there shouldn't be any problems with your set up. What code are you using for your project? I can recommend using our saadc example in either SDK version 15.0 or 15.2.
Simon
I am using SDK 15.2, NRF52840 latest softdevice
