PC-BLE-Driver - Some advertisement lengths faulty/forbidden? [sdk5 v14.0.0]
I have strange problem using pc-ble-driver on nrf52 with heart_rate_monitor example.
When I set advertisement data to be 16 bytes long, two of our testing phones cannont see proper advertisement data (iPhone 6 iOS 10.2.1 and Sony Xperia Z5 Android 7.1.1)
It should me seen as connectable with 11 bytes of manufacturer data, but it's seen as unconnectable and without manufacturer data at all.
When I change manufacturer data to be one byte shorter, then everything is ok, one or two bytes more and it doesn't work, 6 bytes more and it start working again.
This is (not working) my setup:
    data_buffer[index++] = 0x02;
    data_buffer[index++] = BLE_GAP_AD_TYPE_FLAGS; // 0x01
    data_buffer[index++] = BLE_GAP_ADV_FLAG_LE_LIMITED_DISC_MODE | BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    data_buffer[index++] = 0x0C;
    data_buffer[index++] = 0xFF;
    data_buffer[index++] = 0x88;
    data_buffer[index++] = 0x44;
    data_buffer[index++] = 0x55;
    data_buffer[index++] = 0x34;
    data_buffer[index++] = 0x03;
    data_buffer[index++] = 0x11;
    data_buffer[index++] = 0x22;
    data_buffer[index++] = 0x33;
    data_buffer[index++] = 0x66;
    uint8_t sr_data[9];
    sr_data[0] = 0x08;
    sr_data[1] = 0x09;
    sr_data[2] = 0x43;
    sr_data[3] = 0x6F;
    sr_data[4] = 0x6E;
    sr_data[5] = 0x6E;
    sr_data[6] = 0x65;
    sr_data[7] = 0x63;
    sr_data[8] = 0x74;
    error_code = sd_ble_gap_adv_data_set(m_adapter, data_buffer, index, sr_data, 0x09);
Thanks for any help :)
    Yes, your are correct.
    Today I was able to sniff both devices:
    ++++++++++GOOD++++++++++
    8413 2019-03-08 10:38:19,024142 0.000482 c8:68:8e:d4:52:6c Broadcast LE LL 40 SCAN_RSP
    0000 86 21 00 02 58 0e 06 0a 01 26 3d 00 00 f4 00 00 .!..X....&=..ô..
    0010 00 d6 be 89 8e 44 0e 6c 52 d4 8e 68 c8 07 09 53 .Ö¾..D.lRÔ.hÈ..S
    0020 65 6e 73 6f 72 8c 7a 07 ensor.z.
    8414 2019-03-08 10:38:19,025007 0.000865 c8:68:8e:d4:52:6c Broadcast LE LL 48 ADV_IND
    0000 86 29 00 02 59 0e 06 0a 01 27 45 00 00 be 01 00 .)..Y....'E..¾..
    0010 00 d6 be 89 8e 40 16 6c 52 d4 8e 68 c8 02 01 05 .Ö¾[email protected]Ô.hÈ...
    0020 0c ff 8d 04 04 03 01 70 b3 d5 c5 32 63 b2 35 48 .ÿ.....p³ÕÅ2c²5H
    ++++++++++++BAD++++++++++
    276 2019-03-08 10:37:43,278682 0.000268 f3:0e:12:68:04:c7 Broadcast LE LL 40 SCAN_RSP
    0000 86 21 00 02 ec ea 06 0a 01 27 39 00 00 c3 01 00 .!..ìê...'9..Ã..
    0010 00 d6 be 89 8e 44 0e c7 04 68 12 0e f3 07 09 53 .Ö¾..D.Ç.h..ó..S
    0020 65 6e 73 6f 72 24 38 38 ensor$88
    277 2019-03-08 10:37:43,278955 0.000273 f3:0e:12:68:04:c7 Broadcast LE LL 48 ADV_IND
    0000 86 29 00 02 ed ea 06 0a 01 25 3c 00 00 2c 01 00 .)..íê...%<..,..
    0010 00 d6 be 89 8e 60 16 c7 04 68 12 0e f3 02 01 05 .Ö¾..`.Ç.h..ó...
    0020 0c ff 8d 04 04 03 01 70 b3 d5 c5 32 63 75 3e 6f .ÿ.....p³ÕÅ2cu>o
    WIRESHARK FILE:
    wireshark.pcapng
    I have had a look at the wireshark file, and the advertisement packets look good in both cases.
    However, the "bad" advertisement comes from a Bluetooth 5.0 compliant SoftDevice (as the ChSel field, that is the LE Channel Selection Algorithm field, is set indicating that the device supports Algorithm #2 from Bluetooth 5.0.)
    This suggests that the issue might be related to the SoftDevice used, and not to pc-ble-driver.
    What are the exact SoftDevices used for those two cases? (I.e. for the "good" and for the "bad" as listed from the wireshark file.)
    What nRF52 SoCs (full chip markings) and boards (pca10040, custom, etc.) are used, also for both "good" and "bad" scenario?
    Terje
  • GOOD - SoftDevice 4.0.2
    BAD - SoftDevice 5.1
    Both, good and bad is on the same devkit, PCA10040 v.1.1.0 2016.17
    N52832
    QFAAB0
    1511AN
    I assume that you use S132. Let me know if that assumption is false.
    Can you check if you get the "bad" behavior if you use a SD v5.1 version of the DK based application, instead of the SDv4.0.2 application?
    There are quite a few bugfixes between v5.1.0 and v6.1.1 which is currently the latest version of the SoftDevice. It may be worth checking if the examples from SDK v15.3.0, using that latest SoftDevice, works with the affected phones, and then if pc-ble-driver v4.0.0 works when using SoftDevice s132 API version 6 and SoftDevice 6.1.1.
    Terje
