nRF51422 cannot be waken after sleep/wake quite a few times.
Hi, I am now developing a product which uses nrf51422 chip. In this product, I use buttons to turn on and off (since I don't have hard-power cut off circuit, we use system-off sleep for power off and normal mode for active mode). To turn off the device, users need to press and hold the button for 3seconds (here I just used sd_power_system_off() function to go into system-off sleep mode) and to turn on the device, users need to do the same action. I completed the firmware tested a few times and it was OK. But now we found out that after we turn on/off for a few times (23times for a unit, 50times for another unit,it's inconsistent) , the device cannot be waken up at all. But after I remove the battery and put again (power reset), then it's working again. Does anyone encounter this kind of issue before? Please help me. The device is going to be in production soon and urgently need your help.
here is some details for the device,
MCU - nrf51422
SDK - v11.0.0
SD version - SD130
System-off sleep
            if(Flag.PowerOnOff==1)
                if( nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN) == false) // if the power on button is pressed
                    for(uint8_t i=0;i<=6;i++)
                        nrf_delay_ms(500);
                        if( nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN) == true)
                        if( i==6)
                            TurnOff_LEDs();
                            nrf_delay_ms(10);
                           //Disable some interrupt to prevent from waking up
                          nrf_drv_gpiote_in_uninit(SW_EMERGENGY_PIN);
                          nrf_drv_gpiote_in_event_disable(SW_EMERGENGY_PIN);
                          nrf_gpiote_int_disable(SW_EMERGENGY_PIN);
                          nrf_drv_gpiote_in_uninit(INT_PIN);
                          nrf_drv_gpiote_in_event_disable(INT_PIN);
                          nrf_gpiote_int_disable(INT_PIN);
Wake up Check whether from power reset or sleep reset
        if((NRF_POWER->RESETREAS & 0x00010000)== 0x00010000) // If reset from system off mode
            if(nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN)==false)
                for(temp=0;temp<=6;temp++)
                    nrf_delay_ms(500);
                    if(nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN)==true)
                        TurnOff_LEDs();
                        //Disable Hi G, Low G and Emergency Interrupt pin to prevent System-off wakeup
                        NRF_POWER->SYSTEMOFF = 1; // if the power on button is released within 3seconds, goto system off again
  • And I want to test like this. In stead of going to system-off deep sleep mode, I want to try to go to system on sleep mode (power_manage) command but I want to turn off BLE and when the user press and hold the button again, I will just turn on the BLE and continue. Although it's not good for power saving, I want to eliminate this issue first.
    So how can I do to turn off BLE and put the MCU in system on sleep mode and and turn on BLE again?
    Thanks.
  • See my suggestion inline (look for //KME 3 places):
        //uint32_t err_code;
            TurnOff_LEDs();
            // KME: Disable all interrupts here, e.g. __disable_irq()
            nrf_delay_ms(10);
            nrf_drv_gpiote_in_uninit(LOWG_INT_PIN);
            nrf_drv_gpiote_in_event_disable(LOWG_INT_PIN);
            nrf_gpiote_int_disable(LOWG_INT_PIN);
            //KME: Enable wakeup on the pins you want to wakeup on by calling nrf_gpio_cfg_input() and nrf_gpio_cfg_sense_set().
            sd_power_system_off(); // KME: You can use NRF_POWER->SYSTEMOFF = 1; directly here.
            NVIC_SystemReset();  // I just added this code
        //APP_ERROR_CHECK(err_code);
  • Thanks Kenneth for your prompt reply. I will try this and let you know about the outcome.
    Thanks again for your great help and hope this will solve my issue.
  • Hi Kenneth, when I tried this
    TurnOff_LEDs();
    __disable_irq()
    nrf_delay_ms(10);
    nrf_gpio_cfg_sense_input(SW_PWR_ON_PIN,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    the device cannot wake up anymore.
    so I added, __enable_irq() before NRF_POWER->SYSTEMOFF=1 and
    it still cannot wake up after deepsleep (the symptom is the same as in my issue)
  • Dont' enable irq again, instead follow my comment:
