nRF51422 cannot be waken after sleep/wake quite a few times.
Hi, I am now developing a product which uses nrf51422 chip. In this product, I use buttons to turn on and off (since I don't have hard-power cut off circuit, we use system-off sleep for power off and normal mode for active mode). To turn off the device, users need to press and hold the button for 3seconds (here I just used sd_power_system_off() function to go into system-off sleep mode) and to turn on the device, users need to do the same action. I completed the firmware tested a few times and it was OK. But now we found out that after we turn on/off for a few times (23times for a unit, 50times for another unit,it's inconsistent) , the device cannot be waken up at all. But after I remove the battery and put again (power reset), then it's working again. Does anyone encounter this kind of issue before? Please help me. The device is going to be in production soon and urgently need your help.
here is some details for the device,
MCU - nrf51422
SDK - v11.0.0
SD version - SD130
System-off sleep
            if(Flag.PowerOnOff==1)
                if( nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN) == false) // if the power on button is pressed
                    for(uint8_t i=0;i<=6;i++)
                        nrf_delay_ms(500);
                        if( nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN) == true)
                        if( i==6)
                            TurnOff_LEDs();
                            nrf_delay_ms(10);
                           //Disable some interrupt to prevent from waking up
                          nrf_drv_gpiote_in_uninit(SW_EMERGENGY_PIN);
                          nrf_drv_gpiote_in_event_disable(SW_EMERGENGY_PIN);
                          nrf_gpiote_int_disable(SW_EMERGENGY_PIN);
                          nrf_drv_gpiote_in_uninit(INT_PIN);
                          nrf_drv_gpiote_in_event_disable(INT_PIN);
                          nrf_gpiote_int_disable(INT_PIN);
Wake up Check whether from power reset or sleep reset
        if((NRF_POWER->RESETREAS & 0x00010000)== 0x00010000) // If reset from system off mode
            if(nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN)==false)
                for(temp=0;temp<=6;temp++)
                    nrf_delay_ms(500);
                    if(nrf_drv_gpiote_in_is_set(SW_PWR_ON_PIN)==true)
                        TurnOff_LEDs();
                        //Disable Hi G, Low G and Emergency Interrupt pin to prevent System-off wakeup
                        NRF_POWER->SYSTEMOFF = 1; // if the power on button is released within 3seconds, goto system off again
  • To disconnect e.g.:
    sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
    To stop advertising e.g.:
    (void) sd_ble_gap_adv_stop(p_advertising->adv_handle);
  • Hi Kenneth, thanks and I did as what you mentioned but I still found some issues. I just put these code in the function "sleep_mode_enter()"
    static void sleep_mode_enter (void)
    /* Turn off other peripherals before go to system on sleep mode */
    sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    sd_ble_gap_adv_stop();
    for(;;)
        sd_app_evt_wait();
        if(nrf_gpio_pin_read(SW_PWR_ON_PIN)==0)
           NVIC_SystemReset();
    I can see the device goes to system on sleep when sleep_mode_enter function is called and can wake up reset when I press the switch.
    But the problems that I found out are
    1. If the device is connected to the app and when I turn off the device (sleep_mode_enter called), the device disconnect the app and goes to sleep but it restarts advertising again so the app and the device got connected again.
    2. if the device is not connected, I put sleep after advertisment timeout and when advertisement timeout occurs the device can go to sleep but when I check the current in power profiler kit, the current consumption is too high (about 3mA). But when the device is not connected and turn off the device before advertisement timeout, it goes to sleep and current consumption is acceptable (8uA only).
    So what might be the possiblities?
    (By the way, do I need to create a new topic for this question since this is not related with my previous issue)
  • Hi
    1. If you are using the ble_advertising module, then you can find that in ble_advertising_on_ble_evt() on BLE_GAP_EVT_DISCONNECTED, that ble_advertising_start() is called automatically, you may consider comment out this.
    2. That was a bit strange, when advertisement timeout I assume the code callback on_adv_evt() and BLE_ADV_EVT_IDLE event, maybe you are calling sleep_mode_enter() from a different place in your code in this case?
    Kenneth
  • Hi Kenneth,
    thanks for your suggestion, I did check with advertising on event and that I found out the event in the advertise.c file and I put some condition in the event (though it's not a good practice) and now it worked.
    So the device is now just in a system on sleep in idle condition and I also put the watchdog just in case to prevent from the dead loop.
    Thanks again for your great help.
