Mesh with bi-direction communication
Hi all,
I have an application where I have a mobile app  that communicate with up to 20 BLE devices. The BLE devices are RGB LED lights with push buttons and a sensor. I want to be able to from the mobile app, send a code to turn on and set the color of 1 or more of these lights. Also, when the button on the light is pressed, it needs to send the sensor value to the app.
May I know what is the best method to implement this and how to get started? Will the Mesh Serial example or SDK UART coexistance example work?
Thanks in advance.
  • Thanks Hung Bui, I will wait for the updated codes on Github.
    Alternatively, I have a nRF52840 dongle (PCA10059). Can that work replace the nRF52840DK as an aggregator? If so, do I need to make any changes to the codes?
    I read on the nRF52840 dongle programming tutorial, the says the following:
    Adjust the linker configuration. Set FLASH_START=0x1000 to place the application right above the MBR. You should also set FLASH_SIZE=0xDF000 to make sure that there is room for the bootloader at the end of the flash. Set RAM_START=0x20000008, as the first 8 bytes are used by the MBR for interrupt forwarding and adjust the size accordingly by setting RAM_SIZE=0x3FFF8.
    Do I have the same exact change too?
  • If you have nRF52840 DK you can use the SES project for it in github and it should work out of the box. Keil project should also work if you include the missing file (in common folder). I would suggest to install SES and have a look inside the project to find the difference to fix the Keil project. It should be only 2 files missing.
    You don't have to do anything extra. The programming  tutorial is for other application.
  • Hi Hung Bui,
    I like to further feedback that the program for ble_peripheral is not working too for pca10040. I like to compile and download the codes onto a Nordic Thingy. I am trying to compile the ble_peripheral project for pca10040 on SES and I am getting this error:
    C:\NordicSemi\nRF5_SDK_15.2.0\examples\components\libraries\log\src\nrf_log_backend_rtt.c: No such file or directory
    I figured that the components directory is referenced wrongly in the project properties. So rather than changing the user directory in project options -> preprocessor, I just copied and paste the components directory inside the examples directory. I tried compiling again and I am getting another error:
    compiler_abstraction.h: No such file or directory
    I am not sure how to fix this and if there will be more errors after fixing this. Can Nordic also help to check and fix this project?
    I am using SES with the latest SDK15.2 downloaded from Nordic.
  • Hi Kian,
    I'm so sorry for that. I got the developer updated the project. Please try again.
  • Hello Hung Bui,
    I checked the update, but I guess PCA10040 still isn't supported. Any idea how to go on about this? I'm having the same issues as Kian.
