HID USB support 16 bit X-axis and Y-axis
I came across the SDK document below:
For the mouse protocol, one 4-byte input report is defined:
BYTE[0]: Button state bit field.
BYTE[1]: Signed 8-bit X-axis offset since the last position.
BYTE[2]: Signed 8-bit Y-axis offset since the last position.
BYTE[3]: signed 8-bit Wheel offset since the last position.
By using the Generic HID USB instance how do I extend this 4 bytes to 6 bytes reporting to support 16 bit X-axis and Y-axis?
  • Hi Bernard
    There is an inconsistency in your report between the comments and the data:
    0x75, 0x08, /* Report Size (16), */ \
    0x95, 0x03, /* Report Count (2), */ \
    Assuming the comment is correct it should be:
    0x75, 0x10, /* Report Size (16), */ \
    0x95, 0x02, /* Report Count (2), */ \
    Best regards
    Torbjørn
  • It is working now after I have made the change in the Report Descriptor per your advice on the typo.
     * @brief Reuse HID mouse report descriptor for HID generic class    modified chanhock 9/1/2019
    #define HID_GENERIC_REP_DESCRIPTOR {                            \
    0x05, 0x01,       /* Usage Page (Generic Desktop),       */     \
    0x09, 0x02,       /* Usage (Mouse),                      */     \
    0xA1, 0x01,       /*  Collection (Application),          */     \
    0x85, 0x01,                        /*     Report Id 1  Mouse Motion   */     \
    0x09, 0x01,       /*   Usage (Pointer),                  */     \
    0xA1, 0x00,       /*  Collection (Physical),             */     \
    0x05, 0x09,       /*     Usage Page (Buttons),           */     \
    0x19, 0x01,       /*     Usage Minimum (01),             */     \
    0x29, 0x03,       /*     Usage Maximum (03),  3 buttons  */     \
    0x15, 0x00,       /*     Logical Minimum (0),            */     \
    0x25, 0x01,       /*     Logical Maximum (1),            */     \
    0x75, 0x01,       /*     Report Size (1),                */     \
    0x95, 0x03,       /*     Report Count (3),               */     \
    0x81, 0x02,       /*     Input (Data, Variable, Absolute)*/     \
    0x75, 0x05,       /*     Report Size (5), 5 bit padding  */     \
    0x95, 0x01,       /*     Report Count (1),               */     \
    0x81, 0x01,       /*     Input (Constant),               */     \
    0x09, 0x30,       /*     Usage (X),                      */     \
    0x09, 0x31,       /*     Usage (Y),                      */     \
    0x16, 0x01, 0x80, /*     Logical Minimum (-32767),       */     \
    0x26, 0xFF, 0x7F, /*     Logical Maximum (32767),        */     \
    0x81, 0x06,       /*     Input (Data, Variable, Relative)*/     \
    0x09, 0x38,       /*     Usage (Scroll),                 */     \
    0x15,0x81,        /*     Logical Minimum(-127)           */     \
    0x25,0x7F,        /*     Logical Maximum(127)            */     \
    0x75,0x08,        /*     Report Size(8)                  */     \
    0x95,0x01,        /*     Report Count(1)                 */     \
    0x81,0x06,        /*     Input(Data,Var,Rel)             */     \
    0x95,0x02,        /*     Report Count(1) dummy padding for 1 byte as standard 8 byte USB max size        */     \
    0x81,0x01,        /*     Input(Data,Var,Rel)             */     \
    0xC0,             /*  End Collection,                    */     \
    0xC0,             /* End Collection                      */     \
    However, noticed that would need to add the additional line below to report 1st byte of Motion ID 0x01.
    Thank you so much for your prompt. This really helps in my development work. Appreciate it so much!
  • Hi Bernard,
    I tried the same thing and found that when I sent mouse offset data (X/Y axes) at the same time as wheel offset data, Android reported only the mouse offset data -- that is, MotionEvent with action ACTION_MOVE. The scroll event (ACTION_xSCROLL) and data is lost. Do you see the same issue? Thanks.
