NRF52 timing
I'm modelling a complex system with multiple BT devices based on the NRF52 using a very detailed model of the RF.
The system is based on the NRF52 using the mesh stack to but with additional user specific packets added by my code. I need to understand the behaviour of the Rx engine when a packet is received.
After a  successful reception does it re-enter Rx mode in the same channel or switch channels, and how long will it then remain on that channel, i.e. does it reset the rx timer, use the remaining time based on when it entered rx on that channel, or use any remaining time excluding the time consumed by the packet it actually received.
Additionally what happens in the event of a failed Rx ( Framing or CRC error ), how long does it take to recover and what actions does it take.,
I have a very detailed model that models all possible RF states but need to add some more detailed timing to the state machine, so in general the timings for the latest soft device on the NRF52 would be extremely useful, e.g. how long does it take to switch channels in Tx / Rx mode, how is the dwell time managed,
The same issues apply for Tx timing, does it truncate an Rx event when a Tx is scheduled?.
All of my data is sent as advertising events.
  • fixed by deleting and restoring the directories, seems that enable_lang had been called when I first ran the script without specifying armcc, then it created a build environment for gcc and tested that which failed. A bit crap of CMake, but it seems you cannot then change the build environment so I had to delete it.
  • Hi Phil,
    I see, I think I had the same issue a bit long ago. Now you can generate the build with CMAKE and armcc ?
    If you move to SDK v2.x  or 3.x you can just reuse the Keil project we have in the co-existence examples we provided. It has all the stack libraries and dependencies.
    Regard any detailed timing, I afraid that we don't have anything other than the documentation and softdevice specification we have.
  • yes, I can rebuild all of the projects now, but I can't find any keil projects for the mesh examples.
    I created a project for all the files used in beaconing and they all compile ok, but it fails to link.
    using ninja it passes --via=CMakeFiles\beaconing_nrf52832_xxAA_s132_6.1.0.rsp to the linker but I cannot find this file to work out what else it was trying to link with. There are 102 source files used but it also seems to be linked to libraries as I get
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol uECC_make_key (referred from prov_utils.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol uECC_secp256r1 (referred from prov_utils.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol uECC_shared_secret (referred from prov_utils.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol uECC_valid_public_key (referred from prov_utils.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol SEGGER_RTT_Write (referred from log.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol SEGGER_RTT_printf (referred from log.o).
    .\Objects\Beaconing.axf: Error: L6218E: Undefined symbol SEGGER_RTT_vprintf (referred from log.o).
    Not enough information to list image symbols.
    where is the linker control file?.
  • Please use latest SDK. You can find the Keil project at (MeshSDKv3.0.0)\examples\sdk_coexist\
  • I am using nrf5SDKforMeshv310src and there are no Keil projects there, there are 2 subfolders ble_app_proximity_coexist and ble_app_uart_coexist, but neither of these contains any Keil projects.
