Flashing method for nrf52832
As I understand I can able to flash nrf52832 using Segger Jlink or using ST Link Debug Interface. That means we use JTAG or SWD interface for flashing the application on nRF52832.
Can I use USB or UART interface for flashing the application on nRF52832 without using JTAG or SWD Interface?
Thanks in Advance!!
Deepa
  • Hi Susheel,
    nrfutil dfu serial -pkg package.zip -p COM_PORT for UART transport
    Using this command, Can I flash to nRf52832 device without JTAG /SWD Interface?
    Can you please share the procedure of packing binary Image into a DFU zip package manually?
    Thanks & Regards,
    Deepa
     Yes, It will do it through the serial, Please check the documentation here for the procedure to make the package.zip.
  • Hi Susheel,
    Thanks for the info!! I will check this and get back to you If I face any issues.
    Is it possible to perform a DFU using UART with the latest Nordic SDK(nRF5_SDK_15.1.0_a8c0c4d ) ?
    Deepa
  • Deepa,
    The latest one is SDK15.2 and yes you can do a DFU using serial(UART)
    Please check this thread for more info.
  • Hi Susheel,
    I want to flash blink example application using dfu method. As stated in the link, I have installed the dependent packages.
    To generate the package - I have executed the below command -
    nrfutil pkg generate --application blinky_pca10056.hex blinky_dfu_package.zip
    But I got the below errors -
    Missing option "--hw-version"
    Missing option "--sd-req"
    Missing option "--application-version"
    Missing option "--key-file"
    1. Do we need to give all these options for generating dfu package? Is it mandatory?
    2. Before flashing application Image using UART DFU(blink example), do i need to flash bootloader, mbr , other images etc.,
    3. The link shared is not clear enough. Can you please share the step by step to flash the new application using dfu ?
    4. Do we have example to build non secure bootloader?
    5. While genrating the key, I used the below command which results in below error -
    D:\Work\Projects\Sw_work_packages\Nordic_SDK\test\dfu_test>nrfutil keys generate private.pem
    File found at private.pem. Do you want to overwrite the file? [y/N]
    File "C:\Users\deepa.gopinath\AppData\Local\Programs\Python\Python37\Scripts\nrfutil-script.py", line 11, in <module>
    load_entry_point('nrfutil==4.0.0', 'console_scripts', 'nrfutil')()
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 764, in __call__
    return self.main(*args, **kwargs)
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 717, in main
    rv = self.invoke(ctx)
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 1137, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 956, in invoke
    return ctx.invoke(self.callback, **ctx.params)
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 555, in invoke
    return callback(*args, **kwargs)
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\__main__.py", line 364, in generate
    if not query_func("File found at %s. Do you want to overwrite the file?" % key_file):
    File "c:\users\deepa.gopinath\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\dfu\util.py", line 69, in query_func
    choice = raw_input().lower()
    NameError: name 'raw_input' is not defined
    Can you please help to resolve the issue?
    Thanks in Advance!!
    Deepa
