Connection security failed: role: Central in ble_app_rscs_c
I am working on nRF52840 DK with nRF5_SDK_15.2.0_9412b96 and I used the example ble_app_rscs_c with absolutely no changes. I first erased the flash and then burned the Softdevice and app to erase any bonding. I used LightBlue on my iPhone to advertise 0x1814 (BLE_UUID_RUNNING_SPEED_AND_CADENCE). The first time I received the pairing request on iPhone. Every time I restart the DK, I receive the following error several times (4 to 5 times):
<info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Encryption, error: 4352
and then
<info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption.
Although it finally works, these failures cause a long delay.  I have also seen this problem reported for BLE peripheral examples but their solution (un-pairing from iPhone) does not work for me. I need to keep the devices paired.
I was wondering how I can fix this.
  • Hi, I did so and the problem is still there.
  • I'm also having this issue, in my case, the application is based on the multirole example. When acting as a central, it scans and found a peripheral that was already bonded before. The central says that it connected, I'm receiving the PM_EVT_BONDED_PEER_CONNECTED event, and the BLE_GAP_EVT_CONNECTED. I've tested with and without the pm_handler_secure_on_connection call when receiving the PM_EVT_BONDED_PEER_CONNECTED which it will start the Secure connection, when used it doesn't show the PM_EVT_CONN_SEC_START, PM_EVT_CONN_SEC_SUCCEEDED nor PM_EVT_CONN_SEC_CONFIG_REQ.
    I don't know if the problem is related to the primary service discovery which is showing me the following logs:
    [16:17:34:791] <debug> ble_db_disc: Starting discovery of service with UUID 0xFF80 on connection handle 0x0.
    [16:17:34:791] <debug> nrf_ble_gq: Adding item to the request queue
    [16:17:34:796] <debug> nrf_ble_gq: GATTC Primary Services Discovery Request
    [16:17:34:796] <debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted again later.
    [16:17:34:802] <debug> nrf_ble_gq: Processing the request queue...
    [16:17:34:802] <debug> nrf_ble_gq: GATTC Primary Service Discovery Request
    [16:17:34:802] <debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted again later.
    It disconnects before completing the primary service discovery request
    Even if I'm not securing the connection I see this log:
    I've tracked the event up to sm_ble_evt_handler of the security manager, however this event is fired by the Softdevice when calling the ble_evt_handler registered by the peer_manager
    Another thing I've noticed is that when debugging the peripheral side I can't see any event of BLE_GAP_EVT_CONNECTED nor PM_EVT_BONDED_PEER_CONNECTED even when the central device is showing me those events. It's like the Central device is receiving false BLE_GAP_EVT_CONNECTED events from the softdevice and it's not sending any actual connection packets to the peripheral
    I've tried with both scan_parameter.extended =1 and =0 and it's the same, no BLE_GAP_EVT_CONNECTED event on the peripheral
    I'm using nrf52832, SDK 16.0.0, Softdevice s132 7.0.1
    It's important to note that after a mass erase on the central, the peripheral connects perfectly (after deleting bonds on the peripheral) but after several successful connection, the problem starts and it never connect again.
    This thread is over a year old, I suggest you open a new ticket for your case and this issue will be handled there.
