Is there any method to hide advertise packet from nRF52 in the nRF Connect utils?
We want to use some device in the peripherial mode.
after the devices were bonded, for next connect I need to hide this advertise packet from air in the nRF Connect util. Is it possible?
I can hide name- works.
Also I tryed (after has bonded) change
BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE
to
BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE
At this case, there is no any device in the nRF connect but also can't connect to bonded device.
  • Hi
    You have to set the address of the device you want to connect to in the p_peer_addr field of the ble_gap_adv_params_t struct when you configure advertising.
    Best regards
    Torbjørn
  • Thanks. So, if I want just advertise for a few devices, is there only one method- no name? Isn't it?
  • Hi
    There are two methods to limit the number of devices that can send connection or scan requests:
    1) Directed advertising, as described below. This only allows you to connect to a single device, and you will skip all the normal fields in the advertising payload.
    2) Advertising with white list: In this mode you don't change the content of the advertising payload, and everyone can read the advertising packet, but you will only accept connection requests or scan requests from devices that are stored in your white list.
    The advantage of this method is that you can have more than one device in the white list, but the drawback is that other devices can still read your advertising payload (if you want you could always remove the data fields from the adv packet if the devices in your white list don't need this data).
    Best regards
    Torbjørn
  • Hi!
    Thanks. It is clear. But I interesting- just hide my advertise device from nRF connect util. As I understand, if I need advertise for many devices- one way it hide name. Or I miss one more opportunity?
  • Hi
    You can't really hide the advertise packet from nRF Connect if you want to advertise to many devices, but you can change the payload if you like. For instance you can remove the advertising name, and only advertise the advertising flags and your BLE address.
    You can also make the address of your advertiser private resolvable, which means the address will change periodically so that nRF Connect can not track your advertiser over time. Devices that are bonded to you can still recognize the advertiser, because they can resolve a static address from the private resolvable one.
    Best regards
    Torbjørn
