Tips on ULP, BLE and SoftDevice S110 with PCA10001 [nRF51822]
Hello Nordic people!
I'm developing my first firmware on nRF51822 and I need help with BLE, profiles and SoftDevice S110 stack.
Application it's a speed sensor for bicycles. I wish minimum energy consumption. Today, FW is capable to measure cadence data using RTC & LFCLK. Among the pulses due to wheel revolutions, I put the nRF CPU on sleep thus it consumes a very small amount of energy (Vdd=1.8 V, Idd=4.32 mA when CPU ON and Idd=3.05 uA when CPU sleep). I'm very happy ;)
Now it's time to send the speed information to external devices through BLE, using SoftDevice S110.
I think 8-16 bit of data are enough for speed information. I want a speed-related, variable frame-rate:
  • at speed lower than 15 km/h, wheel revolution period is higher than 500 ms thus frame-rate higher than 1/500 ms will be a waste of energy. In this situation, frame-rate will match the wheel's revolution period (>500 ms) and Frame_rate<(1/500) ms.
  • at speed higher than 15 km/h, wheel revolution period is lower than 500 ms. However send data via radio too often is still a waste of energy (end-user has no advantages in a non-real time applications like this) thus maximum desirable frame-rate is Frame_rate_max=1/500 ms. The end-user BLE equipment will have a maximum display-refresh rate of 1/500 ms. It's a good compromise.
Summarizing, maximum frame-rate is 2 FPS (1/500 ms). When no wheel's revolutions happened in 4 seconds, I send a 0 km/h data and switch off nRF51822 thus minimum frame-rate is 0.25 FPS (1/4 s).
I'm starting to read BLE manuals but is still a jungle of information. I briefly saw the GATT and CSC profile but I'm not sure it's the better choice to obtain extra low power consumption.
Maybe it's smarter using a custom profile? Have you got some useful links, BLE quick start, simple nRF51822 project and profiles/services and tips about this application? Please, put me on the right way :) Thank you all!
  • I think the ble_app_lbs is basically the template application with addition of a single service with 2x custom characteristics. Perhaps you just need to evaluate if you feel more comfortable with modifying the service in the ble_app_lbs example for your own purpose or to start from scratch from the ble_app_template , using the principles described in the nAN-36 and ble_app_lbs. In any case, you would need to add your LPCOMP and other functionality on top of that. Do you have PC10028 already, it requires SDK 7.0.1, see SDK release notes.
