Can't find suitable tools to make a project with nRF51822
I have to develop a project for nRF51822 but I can't find tools that work. I tried SES and Eclipse and none can compile the examples of SDK12 (the last one that supports my development board - nRF51 DK. It's frustrating.
I develop FW for microcontrollers since more than 20 years so it is not lack of experience...
I need someone to help setup the suitable development tools... please!
  • The reset handler is defined in the assembly file ses_nrf51_startup.s and, in my view, it is defined. However, no matter what SDK example I load, all give the same error. The point is how to remove this error, as I have no clue how to do it.
    This is a part of the file where I believe it is defined:
    .section .vectors, "ax"
    .code 16
    .global _vectors
    _vectors:
    .word __stack_end__
    .word reset_handler
    ISR_HANDLER NMI_Handler
    So, in my opinion the error is in the ses_nrf51_startup.s file.
    It is also strange that compiling gives only a warning, not an error, but doesn't build, although the setting "treat warnings as errors" is set to No!
    Note that the file ses_nrf51_startup.s is original, so I made no change.
  • This is the complete ses_nrf51_startup.s file:
    * Copyright (c) 2013 Rowley Associates Limited. *
    * This file may be distributed under the terms of the License Agreement *
    * provided with this software. *
    * THIS FILE IS PROVIDED AS IS WITH NO WARRANTY OF ANY KIND, INCLUDING THE *
    * WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. *
    .macro ISR_HANDLER name=
    .word \name
    .section .init, "ax"
    .thumb_func
    .weak \name
    \name:
    1: b 1b /* endless loop */
    .endm
    .macro ISR_RESERVED
    .word 0
    .endm
    .syntax unified
    .global reset_handler
    .code 16
    .global _vectors
    _vectors:
    .word __stack_end__
    .word reset_handler
    ISR_HANDLER HardFault_Handler
    ISR_RESERVED /*Reserved */
    ISR_HANDLER SVC_Handler
    ISR_HANDLER PendSV_Handler
    ISR_HANDLER SysTick_Handler
    /* External Interrupts */
    ISR_HANDLER POWER_CLOCK_IRQHandler
    ISR_HANDLER RADIO_IRQHandler
    ISR_HANDLER UART0_IRQHandler
    ISR_HANDLER SPI0_TWI0_IRQHandler
    ISR_HANDLER SPI1_TWI1_IRQHandler
    ISR_HANDLER GPIOTE_IRQHandler
    ISR_HANDLER ADC_IRQHandler
    ISR_HANDLER TIMER0_IRQHandler
    ISR_HANDLER TIMER1_IRQHandler
    ISR_HANDLER TIMER2_IRQHandler
    ISR_HANDLER RTC0_IRQHandler
    ISR_HANDLER TEMP_IRQHandler
    ISR_HANDLER RNG_IRQHandler
    ISR_HANDLER ECB_IRQHandler
    ISR_HANDLER CCM_AAR_IRQHandler
    ISR_HANDLER WDT_IRQHandler
    ISR_HANDLER RTC1_IRQHandler
    ISR_HANDLER QDEC_IRQHandler
    ISR_HANDLER LPCOMP_IRQHandler
    ISR_HANDLER SWI0_IRQHandler
    ISR_HANDLER SWI1_IRQHandler
    ISR_HANDLER SWI2_IRQHandler
    ISR_HANDLER SWI3_IRQHandler
    ISR_HANDLER SWI4_IRQHandler
    ISR_HANDLER SWI5_IRQHandler
    .thumb_func
    reset_handler:
    // turn on RAM blocks
    .equ NRF_POWER_RAMON_ADDRESS, 0x40000524
    .equ NRF_POWER_RAMONB_ADDRESS, 0x40000554
    .equ NRF_POWER_RAMONx_RAMxON_ONMODE_Msk, 0x3
    /* Make sure ALL RAM banks are powered on */
    MOVS R1, #NRF_POWER_RAMONx_RAMxON_ONMODE_Msk
    LDR R0, =NRF_POWER_RAMON_ADDRESS
    LDR R2, [R0]
    ORRS R2, R1
    STR R2, [R0]
    LDR R0, =NRF_POWER_RAMONB_ADDRESS
    LDR R2, [R0]
    ORRS R2, R1
    STR R2, [R0]
    #ifndef __NO_SYSTEM_INIT
    ldr r0, =__SRAM_segment_end__
    mov sp, r0
    bl SystemInit
    b _start
    .thumb_func
    .weak SystemInit
    SystemInit:
    bx lr
  • Can you upload your entire project? That way I can check if I see any issues with the configuration.
  • The project I am trying to compile is the SDK12 example ble_app_template_pca10028_s130 wihout any changes.
    How can I upload the project? Sorry but I'm new in Nordic....
  • ZIP the directory and upload it to your reply like this:
