PRODUCTION TESTING RF
Hi ,
We are using the BL652 module with your nRF52832 chipset in our important product.
In our product the wireless connection is fundamental and we would like to test the reliability of the Antenna after the welding process.
Can we suggest some instruments to test the module and what it is important to test?
Is nordic use some tools or instrument to verify the module ?
Do you have any direct contact ?
I hope that nordic can support us in this important fase.
Best regards ,
 Luca Rossini
    If you only need to test the performance of Antenna, I will suggest you use antenna coupler with power meter to see whether Antenna works normally after welding process. This would be sufficient and doesn't cost much(Compare to using Litepoint to see Tx, Rx...etc). I've done this with WiFi router to see whether every antenna is qualified in mass production test. Hope this helps.
    If you need solution of the whole test system for mass production. My company could provide. You can contact me through email.
    Jason
