Can you make some small changes for C++ compatibility.
I had to modify the 0.10 mesh / rf sdk's to integrate them into a C++ environment and have now to do the same again with the latest SDK's due to some coding issues in the supplied FW
All of our code is written in C++ and my mesh application code also gets compiled into a simulation environment, switching to C is a more difficult option than switching to an alternative BT device supplier.
The issue for me since we use the Keil environment is mainly an issue with incomplete parameter specifications, many functions take an array of undefined length as their final parameter, this is not compatible with C++, but the ARM compilers allow it using the --gnu switch.
This however causes some compatiblity issues with other files which check for the definition of __GNUC_ causing conflicts, for example the assert definitions in app_util.h
A simple fix for this in these and simpler definitions would help greatly, make the test for __GNU_C conditional on __CC_ARM not being defined, this would have no impact on users of GCC, but would avoid users of ARM compilers needing to modify the source files when using C++
Better still, avoid the use of undefined length arrays, it is not necessary as defining them as length 1, or better still a pointer would resolve the C++ compatibility, after all you are actually passing a pointer anyway,
