Want to send value on a particular register using SPI
void spi_read_write(0x1E,0x00) ==> output 0x10 as return value of register read.
Here I want to send value 0x90 as register value in the argument of spi_read_write(0x1E, 0x90) function, after  sending this it is retaining  0x10 as a rx_data buffer. Here is my code
static spi_rx_data[2] = {0x00,0x00};
void init(void)
    spi_read_write(ACCEL_WHO_M_I,0x00);  //this is working perfectly
    spi_read_write(ACCEL_REG_CTRL0,0x00); //return value spi_rx_data = 0xff,0x10
    spi_read_write(ACCEL_REG_CTRL0,0x90); //return value spi_rx_data = 0xff,0x10 also returning 0x10 previous value instead of 0x90
void spi_read_write(uint8_t register_pointer, uint8_t register_value)
    ret_code_t err_code;
    uint8_t data[2] ={0};
    uint8_t rx_buf;
    memset(spi_rx_data,0x00,sizeof(spi_rx_data));
    register_pointer |= 0x80;
    data[0] = register_pointer;
    data[1] = register_value;
    err_code = nrf_drv_spi_transfer(&spi, data,sizeof(data), spi_rx_data,sizeof(spi_rx_data));
    NRF_LOG_HEXDUMP_INFO(spi_rx_data,sizeof(spi_rx_data));
  • I am working with LIS2DH12 connected with nrf51822 taiyo udan board. I did whatever you say but still I am getting output spi_read_write(ACCEL_REG_CTRL0,0x00) (before) : FF 10
    after  spi_read_write(ACCEL_REG_CTRL0,0x90) : FF 10
  • Are you sure that the write operation will echo back the value written to the register? What happens if you read/write it once again? Can you post your entire code you used for writing/reading the registers?
  • Yes .......I found the solution of my problem. I was masking MSB bit of a register for both read and write operation, but it is needed for read operation only.
    void spi_read(uint8_t register_pointer)
        uint8_t tx_data;
        register_pointer |= 0x80;   //this is needed for reading operation
        tx_data = register_pointer;
        err_code = nrf_drv_spi_transfer(&spi, &tx_data,1, spi_rx_data,sizeof(spi_rx_data));
    void spi_write(uint8_t register_pointer, uint8_t register_value)
        data[0] = register_pointer;    //no need of masking higher bit of register
