Uploading issue of Application and Softdevice file from the Master serial DFU.
I have implemented the Master serial DFU code to update application and SD file. I'm following DFU packet send sequence. Ping, inti packet, FW packet.
I'm framing packet of 116 byte and sending to nrf device. But device is not properlly uploading my packet.
To check this issue, i used development kit. I have created separate packages for Soft device, Application and bootloader.
nrfutil.exe pkg generate --hw-version 52 --softdevice s132_nrf52_6.1.0_softdevice.hex  --sd-req 0xAF  --key-file private.pem sd.zip
nrfutil.exe pkg generate --hw-version 52 --bootloader-version 2 --bootloader  secure_bootloader_uart_mbr_pca10040.hex --sd-req 0xAF  --key-file private.pem boot.zip
nrfutil.exe pkg generate --hw-version 52 --application-version 2 --application blinky.hex --sd-req 0xAF --key-file private.pem app.zip
I have loaded the boot loader file using nrfUtil dfu serial -b 115200 -p COM22 -pkg boot.zip command and I logged this data exchange between CMD prompt and nrf device.
Please check the attachment for the log file.securebootloader.htm
Below points i'm not able to understand from the log file.
1. is MTU  0x0183 byte ?
2. Why 0x08 opcode packet size is always changing?  some time 65 bytes, 64 bytes, 795bytes... etc
3.When we should ask for a CRC from the device? as in log its random time its asking for CRC.
4. How many bytes for data split need to do?
5. As in the log, while sending data to device, First it sending ~64bytes of 5 packets, then around 750 to 850 bytes of packet and at the last it sending around 3k bytes to device. after this its asking for CRC. Why this pattern?  Why number of bytes varying  packet to packet?
Please provide the details.
Thanks
Basava
