nrf52832 sleep mode from android app
I am currently looking at how to put the nrf52 development board to sleep (and wake up) by sending a command from an android application (with SDK v15.2).
I have been experimenting with the nrfBlinky app and wanted to know if anyone has some advice on how one would go about doing this.
I have searched the forums but couldn't find a similar question although there are posts about calling __WFE() to put the board in low power mode from the firmware (or calling an event like sd_app_evt_wait()). I did read there are two sleep mode for this board a SYSTEM ON and SYSTEM OFF mode. I am not certain which mode suits the use case best, although I assume we would want the SYSTEM ON mode as the app would need to send an event to wake it up. Although I wouldn't be against a SYSTEM OFF mode where the reset button would need to be pressed to wake it up (so just sending a "put to sleep" command from the app).
Any advice would be much appreciated.
  • mialo_5 said:
    Therefore based on your reply for Question 1, you mention looking at the ble_uart example which uses a softdevice which I don't believe I am using. Is this then the only way to get the device to sleep in a System OFF mode and why my test didn't work or have I missed something?
    Why does it not work? Have you tried to debug and see what error messages you get?
    If you want control your device from an android app you need a SoftDevice (which handles all low level BLE activity). The reason I recommended you the ble_app_uart example is because it is a quite simple example which uses the SoftDevice.
  • Thanks for your help although I don't believe I am getting to the answer I'm looking for.
    Maybe if I rephrase the question as follows:
    I am using the nrfBlinky Android app with an nrf52832. I would like to press a button on the dev board to put the board into a system off (sd_power_system_off() or nrf_pwr_mgmt._shutdown()) sleep mode where I can only recover by pressing RESET button on the board.
    If I create a static variable "m_is_sleep_mode" to store if BSP_BUTTON_1 is pressed and check that it is true in the main function (in the for(;;) loop I assume), see code snippet, the board seems to perform a reset (the connection drops and comes back up immediately) but has not gone into a power down mode.
    Thoughts this time?
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        ret_code_t err_code;
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            case SLEEPBUTTON_BUTTON:
                m_is_sleep_mode = true;
                APP_ERROR_HANDLER(pin_no);
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler},
            {SLEEPBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
        // Initialize.
        // Enter main loop.
        for (;;)
            if (m_is_sleep_mode)
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
                idle_state_handle();
  • Have you taken a look at the nrf_pwr_mgmt example? That might give you a better understanding of the System OFF sleep mode.
  • Try changing NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF  with NRF_PWR_MGMT_SHUTDOWN_STAY_IN_SYSOFF.
