SPI AND SPIM READING ISSUES
hi all i am trying to read data from a sensor in burst mode i can"t able to read all datas from the register .I tried to read the data in both spi and spim(with easydma) . spim is more better it reads data from 2 register(i am trying to read data of 3 register using burst mode).how can i solve this issues.
  • CONFIGURATION OF SPI
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin = NRF_DRV_SPI_PIN_NOT_USED;
    spi_config.miso_pin = SPI_MOUSE_MISO_PIN;
    spi_config.mosi_pin = SPI_MOUSE_MOSI_PIN;
    spi_config.sck_pin = SPI_MOUSE_SCK_PIN;
    spi_config.frequency = NRF_SPI_FREQ_1M;
    spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
    spi_config.irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY;
    spi_config.mode = NRF_DRV_SPI_MODE_0;
    spi_config.orc = 0xFF;
    err_code = nrf_drv_spi_init(&spi, &spi_config,NULL, NULL);
    if(err_code != NRF_SUCCESS)
    return NRF_ERROR_SPI;
    FUNCTION FOR READING DATA IN BURST MODE
    uint32_t adns_motion_burst_read(const nrf_drv_spi_t * i_spi_address , uint8_t * motion , uint8_t * deltaY , uint8_t * deltaX)
         uint32_t err_code;
         if (i_spi_address == NULL )
             return NRF_ERROR_INVALID_PARAM;
         uint8_t tx_bm_data;
         uint8_t rx_bm_dummy; //receive buffer for dummy
         uint8_t i_reg;
        // Reset serial port
         adns_ncs_assert(i_spi_address,1); //disable ncs
         adns_ncs_assert(i_spi_address,0); //enable nc
         i_reg = ADNS_REG_MOTION_BURST;
        // Format for register in burstmode read
         tx_bm_data = i_reg & 0x7f; // The MSB to "0" to indicate a read operation
       // Write to Motion_Burst register.
         APP_ERROR_CHECK(nrf_drv_spi_transfer(i_spi_address,(const uint8_t  *)&tx_bm_data,1,&rx_bm_dummy,1));
       *motion = rx_bm_dummy; // Execute dummy read to clear RX buffer for motion
         nrf_delay_us(4); //tSRAD
       //Read motion datas by Writing out a dummy data byte which will be ignored
         APP_ERROR_CHECK(nrf_drv_spi_transfer(i_spi_address,(const uint8_t  *)&tx_bm_dummy[0],3,&rx_bm_data[0],3));
        *motion = rx_bm_data[0];
        *deltaY = rx_bm_data[1];
        *deltaX = rx_bm_data[2];
         nrf_delay_us(1); //tBEXIT
         return NRF_SUCCESS;
    sdk_config.h
    #ifndef SPI0_ENABLED
    #define SPI0_ENABLED 1
    // <q> SPI0_USE_EASY_DMA - Use EasyDMA
    #ifndef SPI0_USE_EASY_DMA
    #define SPI0_USE_EASY_DMA 0
  • when i debugged it shows the value of all three register once then no value is reading
    look the screen short i can get the value only once in the intial then it well not get
    THIS IS HOW WE WANT TO READ
  • Try changing tx_bm_dummy to NULL in second call to nrf_drv_spi_transfer, and set the tx_length parameter to 0. In your current code you will write three bytes from whatever you have initialized tx_bm_dummy to (or garbage data from RAM if not initialized), to the SPI slave. The peripheral will automatically clock out dummy bytes when you do a read operation.
    You say that you can only receive the data once, how do you start the transfer? Have you tried debugging the application, to see if any error codes are reported?
