Question about stopping all the timers that are used in the application.
Hi Everyone
I have got 3 timers in my application.
1 is repeated , and other two are Single shot which are ran from the inputs to the 1st Repeated timer.
The repeated keeps checking the UART for a byte , once the byte is received , One single shot timer is started , which on expiry turn One of my sensor OFF and inside the handler starts another single shot timer which again turns ON the sensor after 1 hour.
If i stop the repeated timer when i turn OFF the Sensor , and start the Timer when I turn ON the sensor again. The whole thing just comes to a halt and it doesn't work anymore.
I have fixed this issue by using a timer of 10 seconds , which does literally nothing but keep repeating after 10 seconds, but i am not sure if the theory is correct or not.
""If all the timers have been turned OFF , the RTC goes to deep-sleep and it doesn't count anymore and to keep the RTC alive , i have used a repeated timer as desribed above.
It works in this configuration , but i am not sure if the reasoning is correct or not.""
Kindly help me understand this behavior.
Thanks
Rajat
  • Rajat said:
    Is my software compiling on your end?
     well, it wasn't. It was missing some logging files (I can't remember exactly which ones at this point in time). I removed everything except the app_timer things in order to compile. However I haven't been able get any timer callbacks with your project whatsoever. I have stripped away everything except the app_timer parts. Are you able to get interrupts if you have short timeouts?
    Edvin
