BT832 connect to a passiv MEATER temperature senor. How should I configure the Device with AT-commands. I use Docklight to send AT-Commands from my BT832.
So it is I´m new in BLE.
Thats what I get from MEATER.
Not bad, that document has all the information you need about the MEATER. Then I recommend you read up on BLE as suggested and continue to look at the SDK getting started guide, before you move on to the BLE central examples, which you should probably base your application on.
Ok Thank You for your fast Answer
