nRF9160 DK stopped responding to AT commands
I have 2 nRF9160 DK's.  I've been using 1 for most of my testing and the second one was still in the box.
I loaded the secure boot and the AT_CLIENT demo project.  Opened up the nRF Link Monitor tool.  Hit the reset button and Zephyr stuff flies on the screen.  Ends up with:
Secure Boot: prepare to jump to Non-Secure image
***** Booting Zephyr OS v1.13.99-ncs2 *****
The AT host sample started. err=0
(I added the err=%d) in the printf statement to prove that I was doing stuff.
The problem is when I send it an AT command, I get: Error: 'AT ' timed out
I reloaded the modem firmware with: nrf9160_mdm_dfu --update
That worked.  But still did not respond to AT commands, just time out.
Took my other dev kit out of the box.  Moved my sim card to DevKit #2.  Loaded the same code on it.  With this: nrfjprog.exe --program zephyr.hex --sectorerase -r -f nrf91 --verify
Reboot DevKit #2, and get the same Zephyr messages and everything works.  AT commands work.  Connects to the network.
Hook back up to DevKit #1, AT commands time out.
Now I did solder on a 1 ohm resistor on R60 to measure current.  And if I program the asset tracker software to it, it connects and works perfectly.  But why does the AT_CLIENT time out now?
Anyone have any thoughts?  Thanks!
Steve
  • yes there should be.  And for some reason the 0.4.0 version of the AT Client writes itself to address 0 instead of 40000 (or whatever, I'm pulling that from memory).  If you take the secure boot I posted above, or take the SPM from 0.4.0 and load that.  And then take AT Client from 0.3.0 (which I can post here), it writes itself to address 40000.  so if you flash both it will give you the bunch of stuff from the SPM and then the AT client and that works.  If you load the old radio firmware 0.6.8 on there, the whole thing works (at least for me).
    But if you load the new 0.4.0 AT Client it overwrites the SPM and all you get is the AT Client, which I don't think works anyway.  At least I haven't figured out how it works.
    at_client_snarkyPrintf.hex
    WARNING, I get a bit strange when I've been working on things like this and to make sure I was really flashing the code I was compiling I added a snarky/rude line.  I don't feel this way, or am angry, but if you see this line you know 100% for sure it's not Nordic's stock code.  I was thinking, what could I write that they would never put in code.  And so it exists.
  • For 0.4.0, the nRF9160 samples include the SPM in a multi-image build. So instead of programming the two HEX files separately, you should program the merged.hex file - follow the instructions for a multi-image project here.
  • I believe the solution is the "ns".  If you open a project with the board directory as nrf9160_pca10090 but the board name as nrf9160_pca10090ns (and the build directory but that doesn't matter).    The trick is the NS.
    Without the NS:
    To build and flash a multi-image project:
    1. Select your project in the Project Explorer.
    2. From the menu, select Build -> Build Solution.
    3. When the multi-image build completes, you can flash the sample to a connected board. To do this, select Target -> Download File -> Download Intel Hex File. Navigate to the zephyr folder in your build directory and choose merged.hex.
    I don't get a merged.hex file.  I get a zephyr.hex.  And when I flash that, it's not the SPM and AT Client.  Just the AT Client.  And it doesn't respond to AT commands.
    With the NS you get a merged.hex file.
    If I try to follow the directions exactly and compile the asset tracker:
    If I build for nrf9160_pca10090
    4> In file included from C:/git/nRF/ncs/zephyr/include/toolchain.h:21:0,
    4>                  from zephyr/misc/generated/configs.c:7:
    4> C:/git/nRF/ncs/zephyr/include/toolchain/gcc.h:325:51: error: expected expression before ')' token
    4> zephyr/misc/generated/configs.c:22:1: note: in expansion of macro 'GEN_ABSOLUTE_SYM'
    4> zephyr/misc/generated/configs.c:29:1: note: in expansion of macro 'GEN_ABSOLUTE_SYM'
    Build failed
    But if I build for nrf9160_pca10090ns
    It's fine.  And I get a merged.hex file
    What's the NS stand for?  I was assuming Not Secure.  But I also assumed that not secure was if you didn't want the SPM or secure boot.  Maybe it's Nowloading Securepartitionmanager.  Slight smile
  • Wow, that worked! Thanks so much for your help. Strange that the new AT client overlaps with the SPM app if they are both required in order to work.
