SDK 15.2, S132 6.1, nRF52832
I have a characteristics to write data to a peripheral, using variable length up to 507 bytes and authorization.
Writing to the peripheral works fine with ATT_MTU=23 and DATA_LENGTH=27
When I establish a connection with ATT_MTU=247 and DATA_LENGTH=251, writing returns bad data after 28 bytes!
Data on wire: 122808021a241a2212200102030405060708091011121314151617181920212223242526272829303132
Data in buffer:122808021A241A22122001020304050607080910111213141516171801000000354D0300D1A90200A5A5
When writing from the central to the peripheral, the data is correct transmitted over the air to the peripheral (logged with wire shark).
In the peripheral, I get the event for receiving the written data. The length of the data is indicated correctly, but the data in the buffer in the BLE stack are incorrect.
The data I copy from the BLE stack to my local buffer are only correct for the first 28 byte! The remaining bytes are in the most cases constant memory garbage.
For me it looks like the BLE stacks doesn't handle all data.
Characteristic:
static uint32_t toolCommandCharAdd(tBlePowerTool * prtToBlePowerTool, const tBlePressGunSrvInit * ptrToBlePressGunSrvInit)
ble_gatts_char_md_t gatts_char_md;
ble_gatts_attr_t gatts_attr;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t gatts_attr_md;
// setup the char attr meta data
memset(&gatts_char_md, 0, sizeof(gatts_char_md));
gatts_char_md.char_props.write = true;
gatts_char_md.char_ext_props.reliable_wr = true; // Queued write operation permmited
// setup the characteristic attr
ble_uuid.type = prtToBlePowerTool->pressGunSrv.uuid_type;
ble_uuid.uuid = PRESSGUNSRV_UUID_TOOL_COMMAND_CHAR;
memset(&gatts_attr_md, 0, sizeof(gatts_attr_md));
gatts_attr_md.read_perm = ptrToBlePressGunSrvInit->payload_writeonly_attr_md.read_perm;
gatts_attr_md.write_perm = ptrToBlePressGunSrvInit->payload_writeonly_attr_md.write_perm;
gatts_attr_md.vlen = true; // support of variable len
gatts_attr_md.vloc = BLE_GATTS_VLOC_USER;
gatts_attr_md.rd_auth = true;
gatts_attr_md.wr_auth = true;
memset(&gatts_attr, 0, sizeof(gatts_attr));
gatts_attr.p_uuid = &ble_uuid;
gatts_attr.p_attr_md = &gatts_attr_md;
gatts_attr.init_len = 0;
gatts_attr.init_offs = 0;
gatts_attr.max_len = sizeof BlePwrBrdCommEventDataWrite.dataBuf;
gatts_attr.p_value = (uint8_t *) BlePwrBrdCommEventDataWrite.dataBuf;
return sd_ble_gatts_characteristic_add(prtToBlePowerTool->pressGunSrv.service_handle,
&gatts_char_md,
&gatts_attr,
&prtToBlePowerTool->pressGunSrv.toolCommandHandles);
Event for Receiving:
case BLE_GATTS_OP_WRITE_REQ:
NRF_LOG_DEBUG("BLE_GATTS_OP_WRITE_REQ: len: %d", p_evt_write->len );
memset( BlePwrBrdCommEventDataWrite.dataBuf, 0 , sizeof BlePwrBrdCommEventDataWrite.dataBuf );
memcpy( BlePwrBrdCommEventDataWrite.dataBuf, &p_evt_write->data[0], p_evt_write->len );
BlePwrBrdCommEventDataWrite.size = p_evt_write->len;
Debug Log:
<debug> nrf_ble_gatt: max_tx_time: 2120
<debug> nrf_sdh_ble: BLE event: 0x51.
<debug> app: BLE_GATTS_AUTHORIZE_TYPE_WRITE with BLE_GATTS_OP_WRITE_REQ
<debug> app: BLE_GATTS_OP_WRITE_REQ: len: 11
<debug> app: BlePwrBrdCommEventBleWrite
<debug> app: DATA BUFFER: 0A0908FA0710021A020816
<debug> app: BLE_GATTS_OP_WRITE_REQ: len: 8
<debug> app: DATA BUFFER: 120608011A025200
<debug> app: BLE_GATTS_AUTHORIZE_TYPE_READ
<debug> app: FrameRead reply offset 0 (16 bytes) with SUCCESS.
<debug> app: BLE_GATTS_OP_WRITE_REQ: len: 42
<debug> app: DATA BUFFER: 122808021A241A22122001020304050607080910111213141516171801000000354D0300D1A90200A5A5
