AT Command interface hangs
without providing too much code right away, I would like to ask how I could circumvent AT command interface hangups. My current test application calls AT commands like
static const char cereg[] = "AT+CEREG?";
static const char cesq[] = "AT+CESQ";
static const char vbat[] = "AT%XVBAT";
I just modified lte_lc. for this
in the main loop with an interval of 10s by calling k_sleep(K_MSEC(10000)); in between. So the commands are sent to the modem via the socket, the results are received and evaluated and then sent to our cloud via UDP. Between each command passed to the modem lie 10 seconds.
What I would like to know is how I can prevent the AT command interface hangup, and if it happens anyway how can I reset the modem separately from the Cortex-M33.
Typically I can go through the above sequence 4 times and then the AT Command interface hangs. This is not acceptable, so I have to find a way to prevent this from happening.
Best Regards,
KT
  • Well the tags are:
    \zephyr>git log
    commit 82fe1f9dfcf0e100d6fc952c07cf63d63aa08a0e (HEAD, tag: v1.13.99-ncs2-rc2, tag: v1.13.99-ncs2)
    \nrf>git log
    commit 5ad94691363cb0832943d8cb759df7db982a2e63 (HEAD, tag: v0.3.0)
    \nrfxlib>git log
    commit 891c089577857d8a197b7360e007a0d84e6dbe54 (HEAD, tag: v0.3.0)
    any newer versions would be great to have, I just went through the Getting Started App for this.
    The modem firmware is:
    mfw_nb1_nrf9160_0.3.0-73.prealpha.zip
    The main change to lte_lc.c is:
    static int at_cmd_wret(int fd, const char *cmd, size_t size, char * const ret)
        int len;
        uint32_t retCount = 0;
        int fnc_return;
        u8_t buffer[LC_MAX_READ_LENGTH];
        char *pLine[2] =
        { NULL, NULL };
        LOG_DBG("send: %s", cmd);
        len = send(fd, cmd, size, 0);
        if (len != size)
            LOG_ERR("send: failed");
            return -EIO;
        len = recv(fd, buffer, LC_MAX_READ_LENGTH, 0);
        memset(ret,0,LC_MAX_READ_LENGTH);
        do
            if (len < AT_CMD_SIZE(success))
                LOG_ERR("recv: %s", buffer);
                fnc_return = -EIO;
                pLine[0] = buffer;
                pLine[1] = memchr(buffer, '\n', LC_MAX_READ_LENGTH);
                pLine[1][0]='\0';
                pLine[1]++;
                if (memcmp(success, &pLine[1][0], AT_CMD_SIZE(success)) == 0)
                    memmove(ret, pLine[0], strlen(pLine[0]));
                    fnc_return = 0L;
                    fnc_return = -EIO;
            printk("rx1: %s\n", pLine[0]);
            printk("rx2: %s\n", pLine[1]);
            printk("rx3: %s\n", ret);
            retCount++;
        while (retCount < 1U);
        return fnc_return;
    and to give an example of using this function:
    int exl_lte_lc_get_cereg(exl_lte_lc_cereg_t * const pCereg)
        int errVal;
        int at_socket_fd;
        at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
        if (at_socket_fd == -1)
            return -EFAULT;
        errVal = at_cmd_wret(at_socket_fd, cereg, AT_CMD_SIZE(cereg), buffer);
        if (errVal == 0L)
            // "+CEREG: 2,5,\"C76A\",\"01ACB906\",9"
            sscanf(&buffer[8], "%u,%u,\"%[^\"]\",\"%[^\"]\",%u", (unsigned int *)&pCereg->n, (unsigned int *)&pCereg->stat, pCereg->tac,
                    pCereg->ci, (unsigned int *)&pCereg->act);
            return errVal;
        close(at_socket_fd);
        return 0;
    The main loop looks like the following:
        int32_t s;
        char imei[16];
        uint8_t stage = 0U;
        char dgram[256];
        int32_t Rsrp;
        uint32_t uptime;
        uint32_t vbat;
        exl_lte_lc_cereg_t Cereg;
        printk("Application started\n");
        memset(dgram,0,sizeof(dgram));
        memset(&Rsrp,0,sizeof(Rsrp));
        memset(&uptime,0,sizeof(uptime));
        memset(&vbat,0,sizeof(vbat));
        memset(&Cereg,0,sizeof(Cereg));
        memset(imei,0,sizeof(imei));
        buttons_leds_init();
        work_init();
        modem_configure();
        s = udp_connect();
        if (IS_ENABLED(CONFIG_CLOUD_UA_CONSOLE))
            console_init();
        // get imei
        exl_lte_lc_get_imei(imei);
        while (true)
            if (s >= 0L)
                uint32_t slen;
                uptime = (uint32_t)(k_uptime_get() / 1000L);
                switch (stage)
                case 0:
                    stage=0U;
                case 1:
                    exl_lte_lc_get_cereg(&Cereg);
                    stage=2U;
                case 2:
                    exl_lte_lc_get_cesq(&Rsrp);
                    stage=0U;
                case 3:
                    exl_lte_lc_get_vbat(&vbat);
                    stage=0U;
                    stage=0U;
                sprintf(dgram, "%s?b=[s=\"Test\",c=%s,tc=%s,r=%.1f,ti=\"%u\",a=%u]", imei, Cereg.ci, Cereg.tac,
                        (float)1.0f * Rsrp, (unsigned int)uptime, (unsigned int)((100 * vbat) / 5000U));
                printk("%s", dgram);
                slen = nrf_strnlen(dgram, sizeof(dgram));
                if (send(s, dgram, slen, 0L) != slen)
                    printk("partial/failed write\n");
                    printk("Sent %u Bytes\n", (unsigned int)slen);
            /* if logging is enabled, sleep */
        return 0L;
    Should  I change the approach in exl_lte_lc_* I'll go with the one used in at_client. For now I don't need to use AT_commands in the main loop.
    KT
    I think the problem is on line 25 in the middle code block you posted. In case of return, the socket remains open, but a new one is opened in the next run. In the end you run out of available sockets, and I guess you would see -EFAULT returned from exl_lte_lc_get_cereg(). You can either just keep the socket open all the time, or ensure that you close it also when something fails.
    Update: You can see the new implementation of the AT host for tips on how you can send and receive AT commands in a dedicated thread, and receive callbacks whenever there's data on the socket: https://github.com/NordicPlayground/fw-nrfconnect-nrf/blob/master/lib/at_host/at_host.c
    This allows you to receive notifications for example when the signal strength changes, without having to poll the modem, using the Nordic proprietary AT command AT%CESQ: www.nordicsemi.com/.../proc_cesq
    I tried instrumenting the code around socket() and found that the socket descriptor never changes its value and stays at 2, also it never reaches return -EFAULT.
        int errVal;
        int at_socket_fd;
            printk("%s:%u: Error EFAULT\n",__FUNCTION__,__LINE__);
            return -EFAULT;
        printk("%s:%u: Socket: %d\n",__FUNCTION__,__LINE__,at_socket_fd);
        if (errVal == 0L)
            return errVal;
        return 0;
    There is a high consistency in reaching the 140 seconds mark and not getting further. Also it hangs in at_cmd_wret():recv() and not elsewhere. All this lets me think that awneil is on the right track, despite my sloppy coding involving not checkng return values and returning from a function in more than one place.
    Let me add a bit of output from UART_0:
    s
    exl_lte_lc_get_cesq:312: Socket: 2
    Before recv
    After recv
    rx1: +CESQ: 99,99,255,255,255,61
    rx2: OK
    rx3: +CESQ: 99,99,255,255,255,61
    352656100000036?b=[s="Test",c=01ACB906,tc=C76A,r=-79.0,ti="127",a=0]Sent 68 Bytes
    352656100000036?b=[s="Test",c=01ACB906,tc=C76A,r=-79.0,ti="137",a=0]Sent 68 Bytes
    exl_lte_lc_get_cereg:247: Socket: 2
    Before recv
    After recv
    rx1: +CEREG: 0,5,"C76A","01ACB906",9
    rx2: OK
    rx3: +CEREG: 0,5,"C76A","01ACB906",9
    352656100000036?b=[s="Test",c=01ACB906,tc=C76A,r=-79.0,ti="147",a=0]Sent 68 Bytes
    Before recv
    Thanks for the update about at_host.c I'm using this in its older form already. Using a separate thread for reading the interface is something I may also try in the future.
    KT
  • Thanks for the log output! I was able to reproduce locally, and it seems you've hit a bump with regards to missing implementation of the function bsd_os_timedwait(). Could you try this hack in nrf/lib/bsdlib/bsd_os.c :
    int32_t bsd_os_timedwait(uint32_t context, uint32_t timeout)
    	    /* TODO: to be implemented */
        	k_sleep(timeout);
    	    return 0;
    This is not a long term solution, but it can help you overcome this weird issue for now and isolate the issue.
  • I tried this, it doesn't prevent recv() from hanging.
    KT
