i am not able display uuid, major,minor values and company identifier(so that we can change the beacon identification to ibeacon) using Ble_app_proximity example. please say the specific steps to display these.
ok without adding both beacon and proximity example i need to advertise my beacon like beacon in the above pictures......For that what should i do?
You should modify the following defines to match your beacon UUID, minor, major, and company ID:
#define APP_COMPANY_IDENTIFIER 0x004C
#define APP_MAJOR_VALUE 0x00, 0x02
#define APP_MINOR_VALUE 0x00, 0x02
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0
Also make sure that USE_UICR_FOR_MAJ_MIN_VALUES is not defined in your project. Are you able to get the ble_app_beacon example to advertise your desired beacon data?
yes i am able advertise ble_app_beacon example by these values
but i need battery level also....the above beacon is not mine...i gave a sample one that in which my beacon should also advertise same like the sample one above
I have made an example that combine ble_app_beacon advertising data and is connectable, with proximity services.
I have not modified the beacon values, you should be able to fix this yourself. The example is also not thoroughly tested, only checked that it advertise and can be connected.
