can't send ipv6
i'm trying to send ipv6 packet over thread with function otIp6Send.
but otIp6Send doesn't work and return '6' which means  "Failed to parse message or arguments." as openthread errors says.
i don't know why !!
i'm using nrf52840.
this's part of my code
static void ip_packet_transmit(void)
      uint8_t err;
      uint8_t* header5;
      header5= (uint8_t*)contructip6add(source_addr,des_addr,4);
          uint8_t aData [4]={'p','l','a','y'};
        otMessage *amessage;
        amessage=otIp6NewMessage(thread_ot_instance_get(), true);
                err=otMessageAppend(amessage, header5, 40);
        if (amessage == NULL) {
         return 0;
        err=otMessageAppend(amessage, aData, 4);
             if (err!= OT_ERROR_NONE ) {
        return  0;
        err=otIp6Send(thread_ot_instance_get(),amessage);
       if(err!= OT_ERROR_NONE)
          NRF_LOG_INFO("fail to send with error =  %d",err);
         NRF_LOG_INFO("sent");
 uint32_t* contructip6add (uint32_t* src,uint32_t* dest,uint16_t pay_len)
   static uint32_t header [10];
    header[0]=(((uint32_t)ver)<<28)|(((uint32_t)TRAFFIC_CLASS)<<20)|FLOW_LABEL;
    header[1]=(((uint32_t)pay_len)<<16)|(((uint32_t)NEXT_HEADER)<<8)|HOP_LIMIT;
    header[2]=src[0];
    header[3]=src[1];
    header[4]=src[2];
    header[5]=src[3];
    header[6]=dest[0];
    header[7]=dest[1];
    header[8]=dest[2];
    header[9]=dest[3];
    return header;
  • i don't have sniffer so i couldn't trace packets on air.
    i got destination address from coap functions and used it to send in otip6send and it we can't receive as  callback receive function doesn't be called.
    is there a clear way to determine the destination address ?
    i'll try to upload examples.
  • here i'm trying to send multicast message and i got source address from putty with ipaddr command but i still can't receive packet from my receiving callback
    this's the main of client example
     * Copyright (c) 2017 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup simple_coap_client_example_main main.c
     * @ingroup simple_coap_client_example_example
     * @brief Simple CoAP Client Example Application main file.
     * @details This example demonstrates a CoAP client application that enables to control BSP_LED_0
     *          on a board with related Simple CoAP Server application via CoAP messages.
    #include "app_timer.h"
    #include "bsp_thread.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log.h"
    #include "thread_coap_utils.h"
    #include "thread_utils.h"
    #include <openthread/openthread.h>
    #define IPV6_ADDR_BYTE_LENGTH   16                /**< Length of IPv6 address in bytes. */
    #define PAYLOAD_BYTE_LENGTH     4                 /**< Length of test packet payload in bytes. */
    #define TEST_RESULTS_LENGTH     16                /**< Length of test results in bytes. */
    #define UDP_PORT                40001             /**< Default UDP port of the transmitter. */
    #define NUMBER_OF_TEST_PACKETS  1000              /**< Number of test UDP packets to send. */
    #define TEST_PACKET_SEND_PERIOD 10                /**< Period between UDP test packets [ms]. */
    #define COAP_TOKEN_LENGTH       2                 /**< Length of a CoAP token. */
    #define IPV6_MCAST_ADDR_STRING  "FF03::1"         /**< IPv6 multicast address in string format. */
    #define HOP_LIMIT 64
    #define TRAFFIC_CLASS 0
    #define NEXT_HEADER 17
    #define ver 6
    #define FLOW_LABEL 0
    #define PP_HTONL(x) ((((x) & 0x000000ffUL) << 24) | \
                         (((x) & 0x0000ff00UL) <<  8) | \
                         (((x) & 0x00ff0000UL) >>  8) | \
                         (((x) & 0xff000000UL) >> 24))
    uint32_t lwip_htonl(uint32_t n)
      return (uint32_t)PP_HTONL(n);
    #ifndef lwip_htonl
    uint32_t lwip_htonl(uint32_t x);
     uint32_t* contructip6add (uint16_t pay_len)
        header[0]=lwip_htonl((((uint32_t)ver)<<28)|(((uint32_t)TRAFFIC_CLASS)<<20)|FLOW_LABEL);
        header[1]=lwip_htonl((((uint32_t)pay_len)<<16)|(((uint32_t)NEXT_HEADER)<<8)|HOP_LIMIT);
        header[2]=(0xADDEFD);
        header[3]=(0xEFBE);
        header[4]=(0xFF000000);
        header[5]=(0x6400FE);
        header[6]=lwip_htonl(0xFF030000);
        header[7]=lwip_htonl(0x00000000);
        header[8]=lwip_htonl(0x00000000);
        header[9]=lwip_htonl(0x00000001);
        for(uint8_t i=0;i<=9;i++)
           NRF_LOG_INFO("header[%d]  %x",i,header[i]);
        return header;
          uint8_t err;
          uint8_t* header5;
          header5= (uint8_t*)contructip6add(20);
          NRF_LOG_INFO("we are here");
            uint8_t aData [20]={1,0,2,3,1,0,2,3,1,0,2,3,1,0,2,3,1,0,2,3};
            amessage=otIp6NewMessage(thread_ot_instance_get(), false);
             NRF_LOG_INFO("error ");
            err=otMessageAppend(amessage, aData, 20);
             NRF_LOG_INFO("error");
              NRF_LOG_INFO("error code : %d",err);
             NRF_LOG_INFO("end");
    void ot_receive_handler(otMessage *aMessage, void *aContext)
          NRF_LOG_INFO("Anwar");
          uint16_t length;
          length=otMessageGetLength(aMessage);
          uint32_t data_read[length];
            uint32_t bytes_read=otMessageRead (aMessage,0,data_read,length);
             NRF_LOG_INFO("bytes %d",bytes_read);
           for(uint8_t i=0;i<length;i+=4)
              NRF_LOG_INFO("data %x",data_read[i]);
              NRF_LOG_INFO("data %x",data_read[i+1]);
              NRF_LOG_INFO("data %x",data_read[i+2]);
              NRF_LOG_INFO("data %x",data_read[i+3]);
    void change_rec(void)
          NRF_LOG_INFO("here 2");
            otIp6SetReceiveFilterEnabled(thread_ot_instance_get(), true);
        otIp6SetReceiveCallback(thread_ot_instance_get(),ot_receive_handler, NULL);
     * @section Buttons
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_KEY_0:
                thread_coap_utils_unicast_light_request_send(thread_ot_instance_get(), LIGHT_TOGGLE);
            case BSP_EVENT_KEY_1:
                uint8_t command;
                thread_coap_utils_mcast_light_on_toggle();
                if (thread_coap_utils_mcast_light_on_get())
                    command = LIGHT_ON;
                    command = LIGHT_OFF;
                thread_coap_utils_multicast_light_request_send(thread_ot_instance_get(),
                                                               command,
                                                               THREAD_COAP_UTILS_MULTICAST_REALM_LOCAL);
            case BSP_EVENT_KEY_2:
                ip_packet_transmit();
            case BSP_EVENT_KEY_3:
                thread_coap_utils_provisioning_request_send(thread_ot_instance_get());
                return; // no implementation needed
     * @section Callbacks
    static void thread_state_changed_callback(uint32_t flags, void * p_context)
        if (flags & OT_CHANGED_THREAD_ROLE)
            switch (otThreadGetDeviceRole(p_context))
                case OT_DEVICE_ROLE_CHILD:
                case OT_DEVICE_ROLE_ROUTER:
                case OT_DEVICE_ROLE_LEADER:
                case OT_DEVICE_ROLE_DISABLED:
                case OT_DEVICE_ROLE_DETACHED:
                    thread_coap_utils_peer_addr_clear();
        if (flags & OT_CHANGED_THREAD_PARTITION_ID)
        NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                     flags,
                     otThreadGetDeviceRole(p_context));
     * @section Initialization
    /**@brief Function for initializing the Thread Board Support Package
    static void thread_bsp_init(void)
        uint32_t error_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
        APP_ERROR_CHECK(error_code);
        error_code = bsp_thread_init(thread_ot_instance_get());
    /**@brief Function for initializing the Application Timer Module
    static void timer_init(void)
        uint32_t error_code = app_timer_init();
    static void log_init(void)
    /**@brief Function for initializing the Thread Stack
    static void thread_instance_init(void)
        thread_configuration_t thread_configuration =
            .role              = RX_ON_WHEN_IDLE,
            .autocommissioning = true,
        thread_init(&thread_configuration);
        thread_cli_init();
        thread_state_changed_callback_set(thread_state_changed_callback);
    /**@brief Function for initializing the Constrained Application Protocol Module
    static void thread_coap_init(void)
        thread_coap_configuration_t thread_coap_configuration =
            .coap_server_enabled               = false,
            .coap_client_enabled               = true,
            .coap_cloud_enabled                = false,
            .configurable_led_blinking_enabled = false,
        thread_coap_utils_init(&thread_coap_configuration);
     * @section Main
    int main(int argc, char * argv[])
          bsp_board_led_on(1);
            bsp_board_led_on(0);
        log_init();
        timer_init();
        thread_instance_init();
        thread_coap_init();
        thread_bsp_init();
        while (true)
            thread_process();
                thread_sleep();
  • It looks from your code that you are using Thread SDK v0.11.0, is this correct? I would strongly recommend that you retry your experiment using nRF5 SDK for Thread and Zigbee v2.0.0.
