Parallel to Serial Converter
Hello everyone,
I write this post because I haven't been able to find a solution to a problem I'm having to implement a parallel to serial converter. I am employing the nrf52 DK device.
My scheme of the circuit is the following one:
- Inputs :    -Clock : 2 MHz signal.
                  -Flag : 150 KHz signal.
- Outputs :  - Out : Serial output.
                   - Enable: Signal that in HIGH while Out is being transmitted.
-Internal:     - Values_8 : Array of 8 bool elements (they can change).
- What do I want to do? : Every time Flag goes low to high, I have to transmit Values_8 by Out at Clock frequency. It means, each of the 8 elements of Values_8 have to be transmitted in a Clock period.
Firstly, I am trying to transmit the information 1 bit at 2 MHz in a serial way, without Flag. However, my main problem relies on the operation frequency: I set the input pin Clock as a GPIOTE with high priority, sensing a rising edge of this pin. When the edge is sensed, it employs its event_handler where a GPIO output is set or clear regarding the value of Value_8. However, this works only for a frequency of 100 kHz. I attach a simpler code which toggle a pin when Clock goes low to high. It only works for frequencies below 100 kHz. The event is "in_pin_handler".
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
  nrf_gpio_pin_toggle(28);
 * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
 * and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    nrf_drv_gpiote_init();
	  nrf_gpio_cfg_output(28);
		nrf_gpio_cfg_sense_input(22, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_LOW);
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    in_config.pull = NRF_GPIO_PIN_NOPULL;
    nrf_drv_gpiote_in_init(22, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(22, true);
 * @brief Function for application main entry.
		gpio_init();
    while (true)
        // Do nothing.
If I implement this employing GPIOTEs connection by PPI (This is the code) it correctly works at 2 MHz, however I don't know how to transmit the information of a bit to the output, I only can set, clear or toggle the output pin. I don't know how to implement an if statement, or something like that, in order to check the value (high or low) of the output pin.
static void led_blinking_setup()
    uint32_t compare_evt_addr;
    uint32_t gpiote_task_addr;
    nrf_ppi_channel_t ppi_channel;
    ret_code_t err_code;
   nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false); //this has be configured regarding the value of a global variable
	  err_code = nrf_drv_gpiote_out_init(28, &config);
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
    nrf_drv_gpiote_in_init(22, &in_config, NULL);
 	compare_evt_addr = nrf_drv_gpiote_in_event_addr_get(22);
    gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(28);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel, compare_evt_addr, gpiote_task_addr);
   err_code = nrf_drv_ppi_channel_enable(ppi_channel);
 	nrf_drv_gpiote_out_task_enable(28);
	led_blinking_setup();
    while (true)
			__WFI();
        // Do Nothing - GPIO can be toggled without software intervention.
I would like to know a possible solution to achieve, or an event_handler at upper frequencies, or an alternative to set/clear a GPIO pin at high frequencies driven by an external Clock and regarding a global variable (or memory) that is changing.
Thank you so much for your help.
  • You can try to configure two GPIOTE OUT tasks via two PPI channels - one for setting, another for clearing output, and switch between them using PPI.CHEN register. A number of mcu cycles will be about the same, but you will get synchronous switching done by hardware, and a "window" to prepare PPI.CHEN according to next bit. Another point to optimize - all hardware registers are defined as volatile, so try to save EVENTS_IN[0] into a variable instead of reading it twice in two if() statements - you will save some cycles.
  • Thank you all for your help!
    Finally I achieved that I wanted but only for 1 MHZ. I attach the code. I have to say that now (in the code is included) I need that Out has to be Out1 and Out2 with the same value but for two output pins. If somebody find a way to optimize the code, please tell me!
    static void GPIO_TIMER_Init(void)
    		nrf_gpio_cfg_output(28); //Out1
    		nrf_gpio_cfg_output(29); //Out2
    		nrf_gpio_cfg_output(30); //Enable
    	//GPIOTE FOR FLAG SIGNAL
    						nrf_gpio_cfg_input(17, NRF_GPIO_PIN_NOPULL); // Enable pullup on the GPIO
    						NRF_GPIOTE->CONFIG[0] = (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
    																		(GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos) |
    																		(17 << GPIOTE_CONFIG_PSEL_Pos);
    	//GPIOTE FOR CLOCK SIGNAL
    						nrf_gpio_cfg_input(22, NRF_GPIO_PIN_NOPULL); // Enable pullup on the GPIO
    						NRF_GPIOTE->CONFIG[1] = (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
    																		(GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos) |
    																		(22 << GPIOTE_CONFIG_PSEL_Pos);
    	NVIC_DisableIRQ(TIMER2_IRQn);
      NVIC_ClearPendingIRQ(TIMER2_IRQn);
    //TIMER FOR CLOCK
      NRF_TIMER2->MODE = TIMER_MODE_MODE_Counter;              // Set the timer in Counter Mode
    	NRF_TIMER2->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
      NRF_TIMER2->TASKS_CLEAR = 1;                             // clear the task first to be usable for later
    	NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_08Bit;		   //Set counter to 16 bit resolution
    	NRF_TIMER2->CC[0] = 1;                               //Set value for TIMER2 compare register 0
     NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos);
     NVIC_EnableIRQ(TIMER2_IRQn);
      //TIMER FOR ENABLE
    	NRF_TIMER1->MODE = TIMER_MODE_MODE_Counter;              // Set the timer in Counter Mode
    	NRF_TIMER1->SHORTS = (TIMER_SHORTS_COMPARE1_CLEAR_Enabled << TIMER_SHORTS_COMPARE1_CLEAR_Pos) |
    											 (TIMER_SHORTS_COMPARE1_STOP_Enabled << TIMER_SHORTS_COMPARE1_STOP_Pos);
      NRF_TIMER1->TASKS_CLEAR = 1;                             // clear the task first to be usable for later
    	NRF_TIMER1->BITMODE = TIMER_BITMODE_BITMODE_08Bit;		   //Set counter to 16 bit resolution
    	NRF_TIMER1->CC[1] = 8;                               //Set value for TIMER2 compare register 1
    	NRF_PPI->CH[0].TEP = (uint32_t)&NRF_TIMER2->TASKS_START; //Start TIMER2
    	NRF_PPI->CH[0].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    	NRF_PPI->CHEN |= PPI_CHEN_CH0_Enabled << PPI_CHEN_CH0_Pos;
    	NRF_PPI->CH[1].TEP = (uint32_t)&NRF_TIMER1->TASKS_START; //START TIMER1
    	NRF_PPI->CH[1].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    	NRF_PPI->CHEN |= PPI_CHEN_CH1_Enabled << PPI_CHEN_CH1_Pos;
    	NRF_PPI->CH[2].TEP = (uint32_t)&NRF_TIMER2->TASKS_COUNT; //COUNT TIMER2
    	NRF_PPI->CH[2].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[1];
    	NRF_PPI->CHEN |= PPI_CHEN_CH2_Enabled << PPI_CHEN_CH2_Pos;
    	NRF_PPI->CH[3].TEP = (uint32_t)&NRF_TIMER1->TASKS_COUNT; //COUNT TIMER1
    	NRF_PPI->CH[3].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[1];
    	NRF_PPI->CHEN |= PPI_CHEN_CH3_Enabled << PPI_CHEN_CH3_Pos;
    	NRF_PPI->CH[6].TEP = (uint32_t)&NRF_TIMER2->TASKS_STOP; //STOP TIMER2
      NRF_PPI->CH[6].EEP = (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[1];
      NRF_PPI->CHEN |= PPI_CHEN_CH6_Enabled << PPI_CHEN_CH6_Pos;
    void TIMER2_IRQHandler(void)
    		NRF_TIMER2->EVENTS_COMPARE[0] = 0;	       //Clear compare register 0 event
    	if(lect<7)
    				if(b[lect]){
    					NRF_GPIO->OUTSET = (1UL << 30);
    					NRF_GPIO->OUTSET = (1UL << 28) | (1UL << 29);
    				else{
    					NRF_GPIO->OUTCLR = (1UL << 28) | (1UL << 29);
    				lect++;
    				else{
    					if(b[lect]){
    				else{
    				lect=0;
    	// VARIABLE INITIALIZATION
          lect=0;
    			NRF_GPIO->OUTCLR = (1UL << 30);
    	 // WAIT FOR HFCLK START
    			while(NRF_CLOCK->EVENTS_HFCLKSTARTED != 1){}
    			GPIO_TIMER_Init();
            for (;;)
    				NRF_GPIOTE->EVENTS_IN[0]=0;
            if(NRF_TIMER1->EVENTS_COMPARE[1]){
    				lect=0;
    				NRF_GPIO->OUTCLR = (1UL << 30);}
    				while(NRF_GPIOTE->EVENTS_IN[0] != 1){}
  • Why don't you set the output pins in the for (;;) function in main()? Using the interrupt handler requires some extra cycles as explained earlier. Regarding the question about Out1 and Out2, you could take a look at the fork mechanims of PPI.
    I simplified the IRQHandler, but I don't think it will make much difference regarding speed:
    void optimized_TIMER2_IRQHandler(void)
    	if(b[lect]){
    	}else{
    	if(lect<7){
    		lect++;
    	}else{
    		lect=0;
    Simon
