Merge ble_app_interactive with ble_app_uart example available in SDK 15.2.0
Hi I am working on nRF 52832 and nrf 52840 dongle. I want UART service to be used in my application and application should allow me to scan peripheral devices with user command via Command Line Interface(Putty).
I am trying to merge ble_app_uart and Ble_app_interactive example codes with some modification.
Please suggest me the best way to do it...
     * Copyright (c) 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /**@brief BLE interactive app example application main file.
     * @detail This application demonstrates how to control a BLE connection using the command line interface.
     * @note This application requires the use of an external ECC library
     *       for public key and shared secret calculation.
     *       Refer to the application's documentation for more details.
    #include "sdk_config.h"
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include <ctype.h>
    #include "nordic_common.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_cli.h"
    #include "nrf_cli_uart.h"
    #include "nrf_cli_rtt.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_ble_lesc.h"
    #include "ble_m.h"
    #include "cli_m.h"
    #include "pm_m.h"
    #include "nfc_m.h"
    #include "nfc_central_m.h"
    #define FOUND_DEVICE_REFRESH_TIME APP_TIMER_TICKS(SCAN_LIST_REFRESH_INTERVAL) /**< Time after which the device list is clean and refreshed. */
    /**@brief Command line interface instance.
    NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
    NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &m_cli_uart_transport.transport, '\r', CLI_LOG_QUEUE_SIZE);
    /**@brief Function for starting a command line interface working on the UART transport layer.
    static void cli_uart_start(void)
        ret_code_t ret;
        ret = nrf_cli_start(&m_cli_uart);
        APP_ERROR_CHECK(ret);
    #if NRF_MODULE_ENABLED(CLI_RTT)
    NRF_CLI_RTT_DEF(m_cli_rtt_transport);
    NRF_CLI_DEF(m_cli_rtt, "rtt_cli:~$ ", &m_cli_rtt_transport.transport, '\n', CLI_LOG_QUEUE_SIZE);
    /**@brief Function for starting a command line interface working on the RTT transport layer.
    static void cli_rtt_start(void)
        ret_code_t ret;
        ret = nrf_cli_init(&m_cli_rtt, NULL, true, true, NRF_LOG_SEVERITY_INFO);
        ret = nrf_cli_start(&m_cli_rtt);
    #endif // CLI_RTT
    /**@brief Function for configuring UART for CLI.
    static void cli_uart_cfg(void)
        ret_code_t            err_code;
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd = TX_PIN_NUMBER;
        uart_config.pselrxd = RX_PIN_NUMBER;
        uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
        err_code            = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    /**@brief Function for handling the adv_list_timer event, which refreshes the connectable devices.
    static void adv_list_timer_handle(void * p_context)
        if (is_scanning())
            connect_addr_clear();
            scan_device_info_clear();
    /**@brief Function for initializing logging.
    static void log_init(void)
        ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    /**@brief Function for initializing the timer.
    static void timer_init(void)
        // Timer for refreshing scanned devices data.
        APP_TIMER_DEF(adv_list_timer);
        err_code = app_timer_create(&adv_list_timer, APP_TIMER_MODE_REPEATED, adv_list_timer_handle);
        err_code = app_timer_start(adv_list_timer, FOUND_DEVICE_REFRESH_TIME, NULL);
    static void idle_state_handler(void)
        nrf_cli_process(&m_cli_uart);
        nrf_cli_process(&m_cli_rtt);
    #endif // CLI_RTT
            nrf_pwr_mgmt_run();
        power_management_init();
        log_init();
        timer_init();
        // Console start
        cli_uart_cfg();
        cli_uart_start();
        cli_rtt_start();
    #endif // CLI_RTT
        ble_m_init();
        NRF_LOG_RAW_INFO("BLE application started.\r\n");
        NRF_LOG_RAW_INFO("Press Tab to view all available commands.\r\n");
        for (;;)
            idle_state_handler();
    ble_m.c
    HI these are the files where i modified for merging ble_app_uart into ble_app_interactive. No errors and there is no output also.
    Please check and let me now the comments.
    * list of conditions and the following disclaimer.
    * Semiconductor ASA integrated circuit in a product or a software update for
    * such product, must reproduce the above copyright notice, this list of
    * conditions and the following disclaimer in the documentation and/or other
    * materials provided with the distribution.
    * contributors may be used to endorse or promote products derived from this
    * software without specific prior written permission.
    * Nordic Semiconductor ASA integrated circuit.
    * engineered, decompiled, modified and/or disassembled.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "ble_m.h"
    #include "cli_m.h"
    #include "bsp_btn_ble.h"
    #include "ble_nus_c.h" //Rk added for NUS
    #include "ble.h"
    #include "app_util.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_balloc.h"
    //#include "nfc_ble_oob_advdata_parser.h"
    #include "nrf_ble_scan.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< Tag that identifies the SoftDevice BLE configuration. */
    #define CENTRAL_SCANNING_LED BSP_BOARD_LED_0
    #define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1
    #define PERIPHERAL_ADVERTISING_LED BSP_BOARD_LED_2
    #define PERIPHERAL_CONNECTED_LED BSP_BOARD_LED_3
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Max count of connection parameter update. */
    #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
    #define CCCD_DESCRIPTOR_UUID BLE_UUID_DESCRIPTOR_CLIENT_CHAR_CONFIG /**< UUID of characteristic CCCD descriptors. */
    #define L2CAP_HDR_LEN 4 /**< Length of a L2CAP header, in bytes. */
    #define BATTERY_INITIAL_LVL 100 /**< Battery initial level. */
    #define UUID_STRING_LEN 5 /**< UUID uint16_t string length. */
    /**@brief Priority of the application BLE event handler.
    * @note There is no need to modify this value.
    #define APP_BLE_OBSERVER_PRIO 1
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
    NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
    // Structure storing data of all discovered services.
    typedef struct
    ble_gattc_service_t services[MAX_SERVICE_COUNT]; /**< Data of the services found. */
    uint8_t count; /**< Count of the services found. */
    } device_srv_t;
    typedef struct
    ble_uuid_t uuid; /**< UUID of the characteristic. */
    uint16_t decl_handle; /**< Handle of the characteristic declaration. */
    uint16_t value_handle; /**< Handle of the characteristic value. */
    uint16_t cccd_desc_handle; /**< Handle of the CCCD descriptors. */
    bool notify; /**< True when notification of the value permitted. */
    } char_data_t;
    // Structure storing the data of all discovered characteristics.
    typedef struct
    char_data_t char_data[MAX_CHARACTERISTIC_COUNT]; /**< Characteristics data. */
    uint8_t count; /**< Characteristics count. */
    } srv_char_t;
    scanned_device_t m_device[DEVICE_TO_FIND_MAX]; /**< Stores device info from scan data. */
    char m_addr_str_for_connection[ADDR_STRING_LEN]; /**< Stores device address as string for establishing a connection. */
    srv_char_t m_srv_char; /**< Stores all the characteristics data from one service to allow further operations. */
    uint16_t m_desc_handle; /**< The CCCD descriptor handle found. */
    device_srv_t * mp_device_srv[NRF_BLE_LINK_COUNT]; /**< Pointers to the allocated memory needed to discover the services on the server. */
    static bool m_numeric_match_requested = false; /**< Numeric match request. */
    static uint16_t m_num_comp_conn_handle; /**< Numeric comparison connection handle. */
    static conn_peer_t m_connected_peers[NRF_BLE_LINK_COUNT]; /**< Connected devices data. */
    bool m_scanning = false; /**< Variable that informs about the ongoing scanning. True when scan is ON. */
    bool m_vendor_uuid_read = false; /**< Variable that informs about the read request for a 128-bit service UUID. */
    uint8_t m_uuid_attr_handle;
    NRF_BALLOC_DEF(m_srv_pool, sizeof(device_srv_t), NRF_BLE_LINK_COUNT);
    /**@brief UUIDs that the central application scans for if the name above is set to an empty string,
    * and that are advertised by the peripherals.
    //RK modified for NUS service
    ble_uuid_t m_adv_uuids[] = { { BLE_UUID_NUS_SERVICE, BLE_UUID_TYPE_BLE } }; //RK commened
    static char * mp_roles_str[] =
    "INVALID_ROLE",
    "CENTRAL",
    "PERIPHERAL",
    /**@brief Connection parameters requested for connection.
    static ble_gap_conn_params_t const m_connection_param =
    MIN_CONNECTION_INTERVAL,
    MAX_CONNECTION_INTERVAL,
    SLAVE_LATENCY,
    SUPERVISION_TIMEOUT
    /**@brief Function for handling asserts in the SoftDevice.
    * @details This function is called in case of an assert in the SoftDevice.
    * @warning This handler is an example only and is not meant for the final product. You need to analyze
    * how your product is supposed to react in case of an assert.
    * @param[in] line_num Line number of the failing assert call.
    * @param[in] p_file_name File name of the failing assert call.
    ASSERT(p_file_name);
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling errors from the Connection Parameters module.
    * @param[in] nrf_error Error code that contains information about what went wrong.
    APP_ERROR_HANDLER(nrf_error);
    bool is_scanning(void)
    return m_scanning;
    void addr_store_value_set(char const * const p_address_str)
    ASSERT(p_address_str);
    strcpy(m_addr_str_for_connection, p_address_str);
    scanned_device_t * scan_device_info_get(void)
    return m_device;
    void scan_device_info_clear(void)
    memset(m_device, 0, sizeof(m_device));
    bool is_numeric_match_requested(void)
    return m_numeric_match_requested;
    void numeric_match_request_clear(void)
    uint16_t numeric_match_request_conn_handle_get(void)
    return m_num_comp_conn_handle;
    void preferred_phy_set(ble_gap_phys_t const * const p_phy, uint16_t conn_handle)
    ASSERT(p_phy);
    err_code = sd_ble_gap_phy_update(conn_handle, p_phy);
    uint16_t cccd_descriptors_handle_get(char const * const p_char_uuid_str)
    ASSERT(p_char_uuid_str);
    char uuid_str[UUID_STRING_LEN] = {0};
    // Searching for characteristic.
    for (uint8_t i = 0; i < m_srv_char.count; i++)
    sprintf(uuid_str, "%X", m_srv_char.char_data[i].uuid.uuid);
    if ((!strcmp(uuid_str, p_char_uuid_str)) && m_srv_char.char_data[i].notify)
    return m_srv_char.char_data[i].cccd_desc_handle;
    return BLE_GATT_HANDLE_INVALID;
    /**@brief Function for searching for the CCCD of a characteristic.
    * @param[in] char_uuid UUID of the characteristic.
    * @param[in] conn_handle The connection handle that identifies the connection to perform this procedure on.
    static void cccd_descriptors_search(uint16_t char_uuid, uint16_t conn_handle)
    uint8_t i;
    ble_gattc_handle_range_t handle_range;
    uint16_t start_handle = 0;
    uint16_t end_handle = 0;
    // Searching for the handle of the initial characteristic.
    for (i = 0; i < m_srv_char.count; i++)
    if (m_srv_char.char_data[i].uuid.uuid == char_uuid)
    start_handle = m_srv_char.char_data[i].value_handle + 1;
    // Searching for the handle of the final characteristic if the characteristic is not the last one in the service.
    if ((i < (m_srv_char.count - 1)) && (m_srv_char.char_data[i + 1].uuid.uuid != 0))
    // If the characteristic is not the last one, start a handle equal to the declaration handle of the next characteristic's declaration handle.
    end_handle = m_srv_char.char_data[i + 1].decl_handle - 1;
    // Searching for the handle of the final characteristic. If the characteristic is the last one in the service, the end handle is equal to the service end handle.
    for (uint8_t j = 0; j < mp_device_srv[conn_handle]->count; j++)
    if ((start_handle >
    mp_device_srv[conn_handle]->services[j].handle_range.start_handle) &&
    (start_handle < mp_device_srv[conn_handle]->services[j].handle_range.end_handle))
    end_handle = mp_device_srv[conn_handle]->services[j].handle_range.end_handle;
    handle_range.start_handle = start_handle;
    handle_range.end_handle = end_handle;
    // Discovery descriptors inside, the found handle range.
    err_code = sd_ble_gattc_descriptors_discover(conn_handle, &handle_range);
    uint16_t handle_value_search(char const * const p_service_uuid_str)
    ASSERT(p_service_uuid_str);
    char buffer[UUID_STRING_LEN] = {0};
    sprintf(buffer, "%X", m_srv_char.char_data[i].uuid.uuid);
    if (!strcmp(buffer, p_service_uuid_str))
    return m_srv_char.char_data[i].value_handle;
    ble_gattc_handle_range_t * handle_range_search(char const * const p_service_uuid_str,
    for (uint8_t i = 0; i < mp_device_srv[conn_handle]->count; i++)
    sprintf(buffer, "%X", mp_device_srv[conn_handle]->services[i].uuid.uuid);
    return &mp_device_srv[conn_handle]->services[i].handle_range;
    return NULL;
    void link_layer_data_length_set(char * p_data_length, uint16_t conn_handle)
    ASSERT(p_data_length);
    uint8_t value;
    uint16_t mtu;
    // Get actual MTU.
    mtu = nrf_ble_gatt_eff_mtu_get(&m_gatt, conn_handle);
    value = atoi(p_data_length);
    // Check that new data length has a correct value.
    if ((value > (mtu + L2CAP_HDR_LEN)) || (value < (BLE_GATT_ATT_MTU_DEFAULT + L2CAP_HDR_LEN)))
    NRF_LOG_RAW_INFO("Data Length value must be less than %d and bigger than %d\r\n",
    (mtu + L2CAP_HDR_LEN),
    (BLE_GATT_ATT_MTU_DEFAULT + L2CAP_HDR_LEN));
    return;
    // Set data length.
    err_code = nrf_ble_gatt_data_length_set(&m_gatt, conn_handle, value);
    void gatt_mtu_set(char const * const p_mtu_value)
    ASSERT(p_mtu_value);
    uint16_t mtu_val;
    mtu_val = atoi(p_mtu_value);
    // Checking the new MTU value.
    if ((mtu_val < BLE_GATT_ATT_MTU_DEFAULT) ||
    (mtu_val > NRF_SDH_BLE_GATT_MAX_MTU_SIZE))
    NRF_LOG_RAW_INFO("%s %d - %d \r\n",
    "MTU value must be between",
    BLE_GATT_ATT_MTU_DEFAULT,
    NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    return;
    // New maxiumum MTU must be set before a connection is established.
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, mtu_val);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, mtu_val);
    NRF_LOG_RAW_INFO("MTU will be changed for next connection. Processing MTU change.\r\n");
    char const * phy_str(ble_gap_phys_t const * const p_phys)
    ASSERT(p_phys);
    static char const * p_str[] =
    "1 Mbps",
    "2 Mbps",
    "Coded",
    "Unknown"
    switch (p_phys->tx_phys)
    case BLE_GAP_PHY_1MBPS:
    return p_str[0];
    case BLE_GAP_PHY_2MBPS:
    case (BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS):
    case (BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED):
    return p_str[1];
    case BLE_GAP_PHY_CODED:
    return p_str[2];
    return p_str[3];
    void int_addr_to_hex_str(char * p_result, uint8_t result_len, uint8_t const * const p_addr)
    ASSERT(p_result);
    ASSERT(p_addr);
    if (result_len > BLE_GAP_ADDR_LEN)
    return;
    char buffer[BLE_GAP_ADDR_LEN] = {0};
    memset(p_result, 0, result_len);
    for (uint8_t i = 0; i < result_len; ++i)
    sprintf(buffer, "%.2X", p_addr[result_len - (i + 1)]);
    strcat(p_result, buffer);
    if (i < (result_len - 1))
    strcat(p_result, ":");
    /**@brief Function for printing the UUID for each service.
    * @param[in] conn_handle The connection handle identifying the connection to perform this procedure on.
    * @param[in] service_p Pointer to ble_gattc_service_t.
    static void uuid_print(uint16_t conn_handle, ble_gattc_service_t const * p_service)
    NRF_LOG_RAW_INFO("Found service UUIDs: \r\n");
    NRF_LOG_RAW_INFO("%s: %X %s: 0x%X\r\n",
    "UUID",
    p_service[i].uuid.uuid,
    "type",
    p_service[i].uuid.type);
    bool is_address_compare(ble_gap_addr_t const * const p_connected_addr, char const * const p_addr)
    ASSERT(p_connected_addr);
    ASSERT(p_addr);
    char string_addr_buf[ADDR_STRING_LEN] = {0};
    int_addr_to_hex_str(string_addr_buf,
    BLE_GAP_ADDR_LEN,
    p_connected_addr->addr);
    return (memcmp(string_addr_buf, p_addr, sizeof(string_addr_buf))) ? false : true;
    uint16_t addr_string_to_conn_handle(char const * const p_addr)
    ASSERT(p_addr);
    uint16_t conn_handle = 0;
    uint8_t idx;
    for (idx = 0; idx < NRF_BLE_LINK_COUNT; idx++)
    if (is_address_compare(&m_connected_peers[idx].address, p_addr))
    conn_handle = idx;
    return conn_handle;
    return BLE_CONN_HANDLE_INVALID;
    /**@brief Function for searching for a device name and adding it to a dynamic command.
    * @details Use this function to parse the received advertising data and to find a given
    * name in them either as 'complete_local_name' or as 'short_local_name'.
    * @param[in] p_adv_report Advertising data to parse.
    static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report)
    uint8_t idx = 0;
    uint16_t dev_name_offset = 0;
    uint16_t field_len;
    data_t adv_data;
    // Initialize advertisement report for parsing
    adv_data.p_data = (uint8_t *)p_adv_report->data.p_data;
    adv_data.data_len = p_adv_report->data.len;
    for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
    // If address is duplicated, then return.
    if (memcmp(p_adv_report->peer_addr.addr,
    m_device[idx].addr,
    sizeof(p_adv_report->peer_addr.addr)) == 0)
    return;
    // Add device data if an empty record is found.
    for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
    if (!m_device[idx].is_not_empty)
    memcpy(m_device[idx].addr,
    sizeof(p_adv_report->peer_addr.addr));
    //RK test rssi store rssi value @device instance m_device
    memcpy(&m_device[idx].RSSI_value_RK, &p_adv_report->rssi, sizeof(p_adv_report->rssi));
    //RK test rssi end
    m_device[idx].is_not_empty = true;
    // Search for advertising names.
    field_len = ble_advdata_search(adv_data.p_data,
    adv_data.data_len,
    &dev_name_offset,
    BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    if (field_len == 0)
    adv_data.data_len,
    &dev_name_offset,
    BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME);
    // If name is not found, then return.
    if (field_len == 0)
    return;
    memcpy(m_device[idx].dev_name, &adv_data.p_data[dev_name_offset], field_len);
    m_device[idx].dev_name[field_len] = 0;
    return;
    /**@brief Function for displaying an address in HEX format.
    static void hex_addr_display(uint8_t const * p_addr, size_t size)
    NRF_LOG_RAW_INFO("Connected to address: ");
    for (uint8_t i = 0; i < size; ++i)
    NRF_LOG_RAW_INFO("%.2X ", p_addr[size - (i + 1)]);
    NRF_LOG_RAW_INFO("\r\n");
    void private_connect(pm_peer_id_t const * p_peers_id)
    ASSERT(p_peers_id);
    ble_gap_addr_t public_addr;
    memset(&public_addr, 0, sizeof(public_addr));
    pm_peer_data_bonding_t data;
    memset(&data, 0, sizeof(data));
    // Load device bonding data.
    err_code = pm_peer_data_bonding_load(*p_peers_id, &data);
    if (err_code != NRF_SUCCESS)
    NRF_LOG_INFO("Try again with correct peer ID.");
    return;
    memcpy(&public_addr,
    &data.peer_ble_id.id_addr_info,
    // Stop scanning.
    scan_stop();
    // Set device identities list.
    err_code = pm_device_identities_list_set(p_peers_id, 1);
    scan_start();
    // Connect with device using privacy by public address.
    err_code = sd_ble_gap_connect(&public_addr, &m_scan.scan_params,
    &m_connection_param,
    APP_BLE_CONN_CFG_TAG);
    /**@brief Function for handling primary service discovery response.
    * @details This function will handle the primary service discovery response.
    * @param[in] p_ble_gattc_evt Pointer to the GATT Client event.
    static void on_primary_srv_discovery_rsp(ble_gattc_evt_t const * p_ble_gattc_evt)
    uint16_t count;
    uint16_t bytes_to_copy;
    uint16_t conn_handle;
    static uint16_t offset = 0;
    // For readability.
    ble_gattc_evt_prim_srvc_disc_rsp_t const * p_prim_serv =
    &(p_ble_gattc_evt->params.prim_srvc_disc_rsp);
    conn_handle = p_ble_gattc_evt->conn_handle;
    ble_gattc_service_t * const p_service =
    mp_device_srv[conn_handle]->services;
    // Number of discovered services.
    count = p_prim_serv->count;
    // If no more services are found.
    if ((count != 0) &&
    (p_ble_gattc_evt->gatt_status == BLE_GATT_STATUS_SUCCESS))
    if ((count + offset) > MAX_SERVICE_COUNT)
    bytes_to_copy = MAX_SERVICE_COUNT - offset;
    bytes_to_copy = count;
    // Save services data.
    memcpy((p_service + offset),
    p_prim_serv->services,
    bytes_to_copy * sizeof(ble_gattc_service_t));
    offset += count;
    // If the last service has not been reached, this function must be called again with a new start handle.
    err_code = sd_ble_gattc_primary_services_discover(
    conn_handle,
    p_prim_serv->services[count - 1].handle_range.end_handle + 1,
    NULL);
    mp_device_srv[conn_handle]->count = offset;
    // If service UUID type is unknown, then look for a 128-bit UUID.
    // Only the first one is searched for here, the rest is searched for in the @ref on_read_rsp.
    for (uint8_t i = 0; i < offset; i++)
    if (p_service[i].uuid.type == BLE_UUID_TYPE_UNKNOWN)
    m_vendor_uuid_read = true;
    // Read service 128-bit UUID.
    err_code = sd_ble_gattc_read(conn_handle, p_service[i].handle_range.start_handle, 0);
    offset = 0;
    return;
    NRF_LOG_INFO("Services count: %d", offset);
    uuid_print(p_ble_gattc_evt->conn_handle, p_service);
    offset = 0;
    /**@brief Function for starting a discovery of CCCD descriptors.
    * @details If characteristics can be notified, then look for CCCD descriptors in all
    * characteristics inside the service.
    static void cccd_descriptors_discovery(ble_gattc_evt_t const * p_ble_gattc_evt)
    // If it is possible to enable notification.
    if (m_srv_char.char_data[i].notify)
    // Search for CCCD descriptor handle
    cccd_descriptors_search(m_srv_char.char_data[i].uuid.uuid, p_ble_gattc_evt->conn_handle);
    /**@brief Function for handling a characteristic discovery response.
    static void on_characteristics_discovery_rsp(ble_gattc_evt_t const * p_ble_gattc_evt)
    uint16_t count;
    static uint16_t offset = 0;;
    uint16_t conn_handle = p_ble_gattc_evt->conn_handle;
    // For readability.
    count = p_ble_gattc_evt->params.char_disc_rsp.count;
    ble_gattc_evt_char_disc_rsp_t const * p_char_disc_rsp_evt;
    p_char_disc_rsp_evt = &(p_ble_gattc_evt->params.char_disc_rsp);
    if (p_ble_gattc_evt->gatt_status == BLE_GATT_STATUS_SUCCESS)
    if ((count + offset) > MAX_CHARACTERISTIC_COUNT)
    bytes_to_copy = MAX_CHARACTERISTIC_COUNT - offset;
    NRF_LOG_RAW_INFO("Too many characteristics discovered\r\n");
    // Save characteristics data.
    for (uint8_t i = offset; i < bytes_to_copy; i++)
    m_srv_char.char_data[i].decl_handle = p_char_disc_rsp_evt->chars[i].handle_decl;
    m_srv_char.char_data[i].value_handle = p_char_disc_rsp_evt->chars[i].handle_value;
    m_srv_char.char_data[i].uuid = p_char_disc_rsp_evt->chars[i].uuid;
    m_srv_char.char_data[i].notify = p_char_disc_rsp_evt->chars[i].char_props.notify;
    m_srv_char.char_data[i].cccd_desc_handle = 0;
    offset++;
    // Display characteristics data.
    ble_gatt_char_props_t char_param =
    p_ble_gattc_evt->params.char_disc_rsp.chars[i].char_props;
    NRF_LOG_RAW_INFO("Characteristic UUID: %X\r\n",
    p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid);
    NRF_LOG_RAW_INFO("Parameters:\r\n");
    NRF_LOG_RAW_INFO("broadcast: %d ", char_param.broadcast);
    NRF_LOG_RAW_INFO("read: %d ", char_param.read);
    NRF_LOG_RAW_INFO("write_wo_resp: %d ", char_param.write_wo_resp);
    NRF_LOG_RAW_INFO("write: %d ", char_param.write);
    NRF_LOG_RAW_INFO("notify: %d\r\n", char_param.notify);
    NRF_LOG_RAW_INFO("indicate: %d ", char_param.indicate);
    NRF_LOG_RAW_INFO("auth_signed_wr: %d\r\n", char_param.auth_signed_wr);
    // If the last characteristic has not been reached, look for a new handle range.
    handle_range.start_handle = m_srv_char.char_data[offset - 1].value_handle + 1;
    // Search for end handle.
    if (handle_range.start_handle >
    // Handle value of the characteristic being discovered is less than the end handle of
    // the service being discovered. There is no possibility of more characteristics being
    // present.
    if ((m_srv_char.char_data[offset - 1].value_handle >= handle_range.end_handle) ||
    (offset == MAX_CHARACTERISTIC_COUNT) ||
    (p_ble_gattc_evt->gatt_status != BLE_GATT_STATUS_SUCCESS))
    NRF_LOG_RAW_INFO("Number of characteristics: %d\r\n", offset);
    m_srv_char.count = offset;
    offset = 0;
    // Search for the CCCD descriptors.
    cccd_descriptors_discovery(p_ble_gattc_evt);
    return;
    // If the last Characteristic has not been reached, this function must be called again with new handle range.
    err_code = sd_ble_gattc_characteristics_discover(p_ble_gattc_evt->conn_handle, &handle_range);
    /**@brief Function for handling descriptor discovery response.
    static void on_descriptor_discovery_rsp(const ble_gattc_evt_t * const p_ble_gattc_evt)
    uint16_t count;
    count = p_ble_gattc_evt->params.desc_disc_rsp.count;
    // If no more descriptors are found.
    if (count == 0)
    NRF_LOG_RAW_INFO("No descriptors for characteristic, ",
    "notifications and indications not possible\r\n");
    return;
    if (p_ble_gattc_evt->gatt_status != BLE_GATT_STATUS_SUCCESS)
    return;
    // If the descriptor was found, connect it to the characteristic.
    for (uint8_t i = 0; i < count; i++)
    if (p_ble_gattc_evt->params.desc_disc_rsp.descs[i].uuid.uuid == CCCD_DESCRIPTOR_UUID)
    for (uint8_t j = 0; j < m_srv_char.count; j++)
    if (m_srv_char.char_data[j].cccd_desc_handle == 0 && m_srv_char.char_data[j].notify)
    p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle;
    return;
    // If the last descriptors have not been found, look for a new handle range to search for.
    memset(&handle_range, 0, sizeof(handle_range));
    handle_range.start_handle = p_ble_gattc_evt->params.desc_disc_rsp.descs[count - 1].handle + 1;
    // Search for end handle, to descriptors searching.
    if ((handle_range.start_handle >= m_srv_char.char_data[i].value_handle) &&
    (i < (m_srv_char.count - 1)))
    // If current characteristic is not last in service
    handle_range.end_handle = m_srv_char.char_data[i + 1].decl_handle - 1;
    // If the characteristic is last into service, search for service end handle.
    if (i == (m_srv_char.count - 1))
    (handle_range.start_handle <
    // If the last descriptors have not been reached, this function must be called again with a new handle range.
    /**@brief Function for handling a read response.
    static void on_read_rsp(const ble_gattc_evt_t * const p_ble_gattc_evt)
    ble_uuid128_t uuid;
    const ble_gattc_evt_read_rsp_t * p_read_rsp = &(p_ble_gattc_evt->params.read_rsp);
    if (m_vendor_uuid_read)
    if (p_read_rsp->handle ==
    mp_device_srv[conn_handle]->services[i].handle_range.start_handle)
    //lint -save -e420
    memcpy(uuid.uuid128, p_read_rsp->data, sizeof(uuid.uuid128));
    //lint -restore
    err_code = sd_ble_uuid_vs_add(&uuid, &mp_device_srv[conn_handle]->services[i].uuid.type);
    // If service UUID type is unknown, then try to search for the 128-bit UUID.
    if (mp_device_srv[conn_handle]->services[i].uuid.type == BLE_UUID_TYPE_UNKNOWN)
    // Look for service 128-bit UUID.
    err_code = sd_ble_gattc_read(conn_handle, mp_device_srv[conn_handle]->services[i].handle_range.start_handle, 0);
    return;
    // If service is last.
    if (i == (mp_device_srv[conn_handle]->count - 1))
    NRF_LOG_INFO("Services count: %d", mp_device_srv[conn_handle]->count);
    // Print services UUID. When you first discover services, the 128-bit UUIDs may not be displayed.
    // In such case, you should rediscover the services.
    uuid_print(p_ble_gattc_evt->conn_handle, mp_device_srv[conn_handle]->services);
    return;
    NRF_LOG_RAW_INFO("Read data:\r\n");
    for (uint8_t i = 0; i < p_read_rsp->len; i++)
    NRF_LOG_RAW_INFO("0x%X ", p_read_rsp->data[i]);
    // The application only supports reading data of length less than MTU which was set for this connection.
    /**@brief Function for handling a write response.
    static void on_write_rsp(const ble_gattc_evt_t * const p_ble_gattc_evt)
    // For readability.
    const ble_gattc_evt_write_rsp_t * p_write_rsp = &(p_ble_gattc_evt->params.write_rsp);
    // Display gattc write status.
    NRF_LOG_RAW_INFO("Type of write operation: 0x%x\r\n", p_write_rsp->write_op);
    NRF_LOG_RAW_INFO("Data was written to the server \r\n");
    for (uint8_t i = 0; i < p_write_rsp->len; i++)
    NRF_LOG_RAW_INFO("%d ", p_write_rsp->data[i]);
    if (p_write_rsp->len > 0)
    static void on_ble_evt(uint16_t conn_handle, ble_evt_t const * p_ble_evt)
    char passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t role = ble_conn_state_role(conn_handle);
    case BLE_GAP_EVT_CONNECTED:
    // Store device data to dynamic command buffer and for futher operations.
    m_connected_peers[conn_handle].address =
    p_ble_evt->evt.gap_evt.params.connected.peer_addr;
    connected_to_cmd_add(m_connected_peers, conn_handle);
    // Display device address.
    hex_addr_display(p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr,
    BLE_GAP_ADDR_LEN);
    // Allocation memory for services data.
    mp_device_srv[conn_handle] = (device_srv_t *)nrf_balloc_alloc(&m_srv_pool);
    // Clearing device data.
    connected_to_cmd_remove(m_connected_peers, conn_handle);
    memset(&m_connected_peers[conn_handle], 0x00, sizeof(m_connected_peers[0]));
    // Release of allocated memory.
    nrf_balloc_free(&m_srv_pool, mp_device_srv[conn_handle]);
    case BLE_GAP_EVT_PASSKEY_DISPLAY:
    memcpy(passkey,
    p_ble_evt->evt.gap_evt.params.passkey_display.passkey,
    BLE_GAP_PASSKEY_LEN);
    passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
    NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
    nrf_log_push(mp_roles_str[role]),
    nrf_log_push(passkey),
    p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
    if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
    NRF_LOG_INFO("Type /numeric accept/ to confirm, /numeric reject/ to reject");
    m_num_comp_conn_handle = conn_handle;
    m_numeric_match_requested = true;
    case BLE_GAP_EVT_AUTH_KEY_REQUEST:
    key_request_set();
    NRF_LOG_DEBUG("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(mp_roles_str[role]));
    case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
    NRF_LOG_DEBUG("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(mp_roles_str[role]));
    case BLE_GAP_EVT_AUTH_STATUS:
    NRF_LOG_INFO(
    "%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d",
    p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
    p_ble_evt->evt.gap_evt.params.auth_status.bonded,
    p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4);
    NRF_LOG_DEBUG("kdist_own:0x%x kdist_peer:0x%x",
    *( (uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
    *( (uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    NRF_LOG_RAW_INFO("PHY update request\r\n");
    ble_gap_phys_t phy_param =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    err_code = sd_ble_gap_phy_update(p_gap_evt->conn_handle, &phy_param);
    case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
    on_primary_srv_discovery_rsp(&(p_ble_evt->evt.gattc_evt));
    case BLE_GATTC_EVT_CHAR_DISC_RSP:
    on_characteristics_discovery_rsp(&(p_ble_evt->evt.gattc_evt));
    case BLE_GATTC_EVT_DESC_DISC_RSP:
    on_descriptor_discovery_rsp(&(p_ble_evt->evt.gattc_evt));
    case BLE_GATTC_EVT_READ_RSP:
    on_read_rsp(&(p_ble_evt->evt.gattc_evt));
    case BLE_GATTC_EVT_WRITE_RSP:
    on_write_rsp(&(p_ble_evt->evt.gattc_evt));
    case BLE_GATTC_EVT_HVX:
    // If server sends an indication, then send a Handle Value Confirmation to the GATT Server.
    if (p_ble_evt->evt.gattc_evt.params.hvx.type == BLE_GATT_HVX_INDICATION)
    err_code = sd_ble_gattc_hv_confirm(p_ble_evt->evt.gattc_evt.conn_handle,
    p_ble_evt->evt.gattc_evt.params.hvx.handle);
    uint8_t data_len = p_ble_evt->evt.gattc_evt.params.hvx.len;
    NRF_LOG_RAW_INFO(
    "%s data: ",
    (p_ble_evt->evt.gattc_evt.params.hvx.type !=
    BLE_GATT_HVX_NOTIFICATION) ? "Indication" : "Notification");
    // Display notifications or indication data.
    for (uint8_t i = 0; i < data_len; i++)
    NRF_LOG_RAW_INFO("%d ", p_ble_evt->evt.gattc_evt.params.hvx.data[i]);
    // No implementation needed.
    /**@brief Function for handling BLE Stack events that concern the central application.
    * @details This function keeps the connection handles of the central application up-to-date. It
    * parses scanning reports, initiating a connection attempt to peripherals,
    * and manages connection parameter update requests. Additionally, it updates the status
    * of LEDs used to report the central application's activity.
    * @note Since this function updates the connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
    * should be dispatched to the target application before invoking this function.
    * @param[in] p_ble_evt Bluetooth stack event.
    static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    // For readability
    // Upon connection, update LEDs status.
    NRF_LOG_INFO("CENTRAL: Connected, handle: %d.", p_gap_evt->conn_handle);
    memset(m_addr_str_for_connection, 0, sizeof(m_addr_str_for_connection));
    //RK added for NUS
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    // start discovery of services. The NUS Client waits for a discovery result
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
    //End RK
    // Update LEDs status.
    bsp_board_led_off(CENTRAL_SCANNING_LED);
    bsp_board_led_on(CENTRAL_CONNECTED_LED);
    break; // BLE_GAP_EVT_CONNECTED
    // Upon disconnection, reset the connection handle of the peer which disconnected, update
    // the LEDs status.
    NRF_LOG_INFO("CENTRAL: Disconnected, handle: %d, reason: 0x%x",
    p_gap_evt->params.disconnected.reason);
    bsp_board_led_off(CENTRAL_CONNECTED_LED);
    break; // BLE_GAP_EVT_DISCONNECTED
    case BLE_GAP_EVT_ADV_REPORT:
    if (is_address_compare(&p_gap_evt->params.adv_report.peer_addr,
    // Initiate connection.
    NRF_LOG_INFO("CENTRAL: Connecting...");
    err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr,
    NRF_LOG_DEBUG("Connection Request Failed, reason %d", err_code);
    return;
    // Add device address and name (if exists) from the scan report to dynamic CLI command.
    //RK test rssi
    // uint16_t m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; // RK test rssi
    // sd_ble_gap_rssi_start(m_conn_handle, 0, 0);
    // sd_ble_gap_rssi_stop(m_conn_handle);
    //RK test rssi end
    device_to_list_add(&p_gap_evt->params.adv_report); //No modification -RK test rssi add to event (included in this call)
    address_to_cmd_add(&p_gap_evt->params.adv_report.peer_addr);
    break; // BLE_GAP_ADV_REPORT
    case BLE_GAP_EVT_TIMEOUT:
    // Time-out for scanning has not been specified, so only connection attemps can time out.
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
    NRF_LOG_DEBUG("CENTRAL: Connection Request timed out.");
    case BLE_GAP_EVT_CONN_PARAM_UPDATE:
    NRF_LOG_RAW_INFO("Connection parameters update success\r\n");
    case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    // Accept parameters requested by the peer.
    err_code = sd_ble_gap_conn_param_update(
    &p_gap_evt->params.conn_param_update_request.
    conn_params);
    case BLE_GATTC_EVT_TIMEOUT:
    // Disconnect on GATT Client time-out event.
    NRF_LOG_DEBUG("CENTRAL: GATT Client Time-out.");
    case BLE_GATTS_EVT_TIMEOUT:
    // Disconnect on GATT Server time-out event.
    NRF_LOG_DEBUG("CENTRAL: GATT Server Time-out.");
    case BLE_GATTC_EVT_EXCHANGE_MTU_RSP:
    NRF_LOG_RAW_INFO("Current MTU: %d\r\n",
    p_ble_evt->evt.gattc_evt.params.exchange_mtu_rsp.server_rx_mtu);
    case BLE_GAP_EVT_PHY_UPDATE:
    ble_gap_evt_phy_update_t const * p_phy_evt = &p_ble_evt->evt.gap_evt.params.phy_update;
    if (p_phy_evt->status == BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION)
    // Ignore LL collisions.
    NRF_LOG_DEBUG("LL transaction collision during PHY update.");
    ble_gap_phys_t phys = { 0 };
    phys.tx_phys = p_phy_evt->tx_phy;
    phys.rx_phys = p_phy_evt->rx_phy;
    NRF_LOG_INFO("PHY update %s. PHY set to %s.",
    (p_phy_evt->status == BLE_HCI_STATUS_CODE_SUCCESS) ?
    "accepted" : "rejected",
    phy_str(&phys));
    //RK Added for NUS
    // Pairing not supported.
    err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
    ble_gap_phys_t const phys =
    } break;
    //Rk End NUS
    /**@brief Function for handling BLE Stack events involving peripheral applications. Manages the
    * LEDs used to report the status of the peripheral applications.
    static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
    NRF_LOG_INFO("PERIPHERAL: Connected, handle %d.", p_ble_evt->evt.gap_evt.conn_handle);
    bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
    bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
    NRF_LOG_INFO("PERIPHERAL: Disconnected, handle %d, reason 0x%x.",
    p_ble_evt->evt.gap_evt.params.disconnected.reason);
    bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
    NRF_LOG_DEBUG("PERIPHERAL: GATT Client Time-out.");
    NRF_LOG_DEBUG("PERIPHERAL: GATT Server Time-out.");
    case BLE_EVT_USER_MEM_REQUEST:
    err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gap_evt.conn_handle, NULL);
    case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
    ble_gatts_evt_rw_authorize_request_t req;
    ble_gatts_rw_authorize_reply_params_t auth_reply;
    req = p_ble_evt->evt.gatts_evt.params.authorize_request;
    if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) ||
    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
    auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
    auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
    err_code = sd_ble_gatts_rw_authorize_reply(
    p_ble_evt->evt.gatts_evt.conn_handle,
    &auth_reply);
    break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
    NRF_LOG_INFO("LL transaction collision during PHY update.");
    ble_gap_phys_t phys = {0};
    phy_str(&phys));
    * @param[in] ble_adv_evt Advertising event.
    static inline void on_adv_evt(ble_adv_evt_t ble_adv_evt)
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
    * @param[in] p_context Unused.
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    on_ble_evt(conn_handle, p_ble_evt);
    if (role == BLE_GAP_ROLE_PERIPH)
    // Manages peripheral LEDs.
    on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) ||
    (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
    on_ble_central_evt(p_ble_evt);
    /**@brief Function for initiating scanning.
    void scan_start(void)
    m_scan.scan_params.timeout = 0x0000; // No timeout.
    NRF_LOG_INFO("Starting scan.");
    err_code = nrf_ble_scan_start(&m_scan);
    bsp_board_led_on(CENTRAL_SCANNING_LED);
    NRF_LOG_INFO("Scanning");
    m_scanning = true;
    /**@brief Function for stopping scanning.
    void scan_stop(void)
    nrf_ble_scan_stop();
    m_scanning = false;
    * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
    * device including the device name, appearance, and the preferred connection parameters.
    ble_gap_conn_params_t gap_conn_params;
    (const uint8_t *)DEVICE_NAME,
    strlen(DEVICE_NAME));
    gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL;
    gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL;
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = SUPERVISION_TIMEOUT;
    /**@brief Function for handling BLE stack GATT events.
    static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    switch (p_evt->evt_id)
    case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
    NRF_LOG_RAW_INFO("MTU changed successfully\r\n");
    //Rk added for NUS
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    //RK end NUS
    case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
    NRF_LOG_INFO("Data length updated to %u bytes.", p_evt->params.data_length);
    /**@brief Function for initializing the GATT module.
    static inline void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    //RK added for NUS
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    //RK end
    /**@brief Function for handling the Connection Parameters Module.
    * @details This function will be called for all events in the Connection Parameters Module which
    * are passed to the application.
    * @note All this function does is to disconnect. This could have been done by simply
    * setting the disconnect_on_fail config parameter, but instead we use the event
    * handler mechanism to demonstrate its use.
    * @param[in] p_evt Event received from the Connection Parameters Module.
    uint16_t conn_handle = p_evt->conn_handle;
    err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
    cp_init.p_conn_params = NULL;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_CONN_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail = true;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
    void advertising_init(void)
    ble_advertising_init_t init;
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids = m_adv_uuids;
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_interval = ADV_INTERVAL;
    init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    /**@brief Function for initialization Scanning Module.
    static void scan_init(void)
    err_code = nrf_ble_scan_init(&m_scan, NULL, NULL);
    // //RK test NUS
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    //RK test NUS
    /**@brief Function for handling database discovery events.
    * @details This function is a callback function to handle events from the database discovery module.
    * Depending on the UUIDs that are discovered, this function forwards the events
    * to their respective services.
    * @param[in] p_event Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
    * @details This function takes a list of characters of length data_len and prints the characters out on UART.
    * If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
    do
    ret_val = app_uart_put(p_data[i]);
    if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
    APP_ERROR_CHECK(ret_val);
    } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
    while (app_uart_put('\n') == NRF_ERROR_BUSY);
    #if 0 //RK
    if (ECHOBACK_BLE_UART_DATA)
    // Send data back to the peripheral.
    do
    ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
    /**@brief Function for handling app_uart events.
    * @details This function receives a single character from the app_uart module and appends it to
    * a string. The string is sent over BLE when the last character received is a
    * 'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
    /**@snippet [Handling data from UART] */
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
    do
    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
    } while (ret_val == NRF_ERROR_RESOURCES);
    index = 0;
    NRF_LOG_ERROR("Communication error occurred while handling UART.");
    case APP_UART_FIFO_ERROR:
    NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling Nordic UART Service (NUS) client events.
    * @details This function is called to notify the application of NUS client events.
    * @param[in] p_ble_nus_c NUS client handle. This identifies the NUS client.
    * @param[in] p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
    case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
    NRF_LOG_INFO("Discovery complete.");
    err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
    err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
    NRF_LOG_INFO("Connected to device with Nordic UART Service.");
    case BLE_NUS_C_EVT_NUS_TX_EVT:
    ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
    case BLE_NUS_C_EVT_DISCONNECTED:
    NRF_LOG_INFO("Disconnected.");
    scan_start();
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    //RK end NUS
    * @brief Function for initializing a block allocator.
    static inline void balloc_init(void)
    err_code = nrf_balloc_init(&m_srv_pool);
    void ble_m_init(void)
    // Initialization of required BLE components.
    balloc_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    advertising_init();
    //RK added to test NUS
    db_discovery_init();
    nus_c_init();
    //Rk end NUS
    Above is the code for ble_m.c.
  • i haven't looked yet but make sure you didn't define the uart port twice. The ble_nus is not be attached to the cli uart. maybe there is no output because it is defined twice.
  • are you trying to running nus as the central or peripheral? Sorry I probably should have asked that earlier on.
