NRF52 Watchdog not resetting
Currently I am trying to implement Watchdog functionality into my Project.
I have the followowing problem:
I use the Nordic WatchdogTimer.h and instance the class with 1s in the constructor.
now, if I just do a 'while(1);' the code succesfuly resets after about 1 Second.
But If I dont use a while loop, it does not reset, even if I dont use the WDT::Kick() function..?!
I think I altered some of the nrf52_bitfields.h parameters, but I dont remember which ones, so maybe thats the cause, but what could it be?
Its really strange that it resets on a while loop, but not without it and without WDT::Kick()
jonas
    There are a few issues with your code, but none that should prevent it from working. I have fixed the writes to the WDT registers and modified the code to match the normal nRF5 SDK like this:
        NRF_LOG_INFO("Temperature example started.");
        static const uint16_t NRF_CLK_RATE = 32768; //32KHz
        NRF_WDT->CONFIG = 0x00000009;
        NRF_WDT->CRV = 2 * NRF_CLK_RATE;
        NRF_WDT->RREN = 0x11111111;
        NRF_WDT->TASKS_START = 1;
        while (1)
            NRF_LOG_INFO("looping");
            nrf_delay_ms(1000);
    This gives the expected log output:
    <info> app: Temperature example started.
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    <info> app: looping
    Please also note that the SDK includes a WDT example which uses the WDT driver, providing a high-level API that is tested and verified by us (Nordic).
  • yehaa, its working!
    I still dont know why the WatchdogTimer.h does not work, but I will just do it this way now.
    my first try to do it without the included file would have worked, if I wouldnt have been so stupid and accidentally use 0x00001001 instead of 0b00001001.
    So thanks for helping me out! Slight smile
    Jonas
  • well.. I discovered something strange... when I set CONFIG to 0x00000009 it will work. If I try to set it to 0x00 it wont work?! also, I noticed that for the CONFIG=... it will take a power cycle for the change to get applied, is that intentionally?
    What do you mean by saying that it won't work when CONFIG is set to 0? In that case the WDT will pause when in sleep or haltet by a debugger, so if your current test code does that, then you should not expect to see a reset.
    Regarding changes to the CONFIG register, that must always be done before the WDT is started by writing to TASKS_START. Once it is started it cannot be reconfigured, and the only way to stop it (so that it can be reconfigured again) is with a reset. This is intentional behavior, as it prevents a malfunction system to accidentally reconfigure the SoftDevice, potentially preventing a WDT reset.
    The WDT chapter in the PS specifies it like this:
    The watchdog must be configured before it is started. After it is started, the watchdog’s configuration registers, which comprise registers CRV, RREN, and CONFIG, will be blocked for further configuration.
  • the chip does not sleep, nor am i debugging it(or does connecting over Segger RTT count as debugging?), but it simply wont reset if I set the config register to 0x00. I do start the chip after configuring it.
    regarding the power cycle, does that mean I can reconfigure the WDT every program start or every power cycle?
