implementation UART to examples from SDK
I have problem with implementing UART to simple_coap_client example, but there is too much problems. Some issues have been solved, but it still is not all.
defines in sdk_config.h  -solved
uart0 - used by openthread lib -solved
Can you help me with best way to use COAP and UART in same project?
nRF5_SDK_for_Thread_and_Zigbee_2.0.0_29775ac
Linux ubuntu 18.04
Segger studio
  • okej its true,  but problem still exist
    ‘nrf_drv_uart_config_t {aka struct <anonymous>}’ has no member named ‘use_easy_dma’
    problem is in file nrf_derial.c line 207-209
    #if defined(UARTE_PRESENT) && defined(UART_PRESENT)
    drv_config.use_easy_dma = (p_config->mode == NRF_SERIAL_MODE_DMA);
    nrf_drv_uart.h line 197
    struct nrf_drv_uart_config_t has member named ‘use_easy_dma’ if  this:
    #if defined(NRF_DRV_UART_WITH_UARTE) && defined(NRF_DRV_UART_WITH_UART)
    my fix :
    instead of condition file nrf_derial.c  in line 207
    replacing condition is from nrf_drv_uart.h line 197
    it is correct fix? build complete
  • So you didn't try the fix I suggested in the previous reply?
    It may work the way you describe. The issue with just avoiding one instance of #if defined() is that this check may be done several other places in your project (but maybe not). Also, remember that the changes you do in the generic SDK files applies to all projects using the same SDK.
    BR,
    Edvin
