Receiving error no such file for offsets.c.obj when building solution
I have updated my repos to the latest commits on master for zephyr, mcuboot, nrf, and nrfxlib. I ran `
pip3 install -r scripts\requirements.txt
and I can open the asset_tracker SDK project but when I go to build, I get this error. What would be causing this now that I've updated the codebase?
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
Combining ‘zephyr/include/generated/offsets.h’
/PROJECTCODE/ncs/zephyr/scripts/gen_offset_header.py", line 72, in <module>
[Errno 2] No such file or directory: 'C:/PROJECTCODE/ncs/fw-nrfconnect-nrf/applications/asset_tracker/build/zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj'
Build failed
  • Quick update: The master branch of Nordic Connect SDK (NCS) now works with SES! Just follow the latest version of the nRF Getting Started Assistant in nRF Connect for Desktop to get started!
  • Hello Bjørn K.
    nRF9160 dev kit.
    I am getting the error below, maybe this is related to what "rkguy" initially posted?
    1> Combining ‘zephyr/misc/generated/syscalls.json’
    1> Combining ‘zephyr/include/generated/offsets.h’
    1> Traceback (most recent call last):
    1> File "C:/programvare/nrfsemi/ncs/zephyr/scripts/gen_offset_header.py", line 72, in <module>
    1> input_file = open(args.input, 'rb')
    1> FileNotFoundError: [Errno 2] No such file or directory: 'C:/programvare/nrfsemi/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj'
    Build failed
    Regards
    David
  • Hi David,
    Could you please open a new DevZone case? Thanks!
