Default PHY
Hi
What is the default PHY when using NRF52832, SDK 14.2 and SD S132 v5.0?
When does a device's PHY get reset to this default value? Is it upon disconnect or is it as a part of each connection? Or is it the responsibility of the application to handle the PHY?
I have created a peripheral with above combination. If this peripheral connects to a BLE 5.0 enabled central, I get a PHY update request for 2M PHY. The peripheral selects AUTO and hence the PHY gets set to 2M PHY. If the peripheral disconnects from this central and connects to a new one which is not BLE PHY enabled, what should happen? Not all centrals trigger PHY update procedure. To handle this cleanly, should I call the SD API to set the PHY to 1M after every disconnection or does the softdevice handle this internally?
Thanks
Amruta
