Using a Qt vista style Widget makes my Bleutooth data acquisition faster…why?
I'm using a Nordic dev board (PCA10040, nRF52832) with modified "Nordic_HRM" firmware sending packets of 20bytes at 100Hz over Bluetooth Low Energy.
I'm using Nordic's heart_rate_collector example to retrieve the data on a Windows 10 computer using Nordic's USB BLE dongle (PCA10031). I'm using version 2.2.1 of the pc-ble-driver. I modified the example code to report the data frequency of the last second (it originally reports the average data frequency for the whole session)
What I experience is very wierd:
  • The heart_rate_collector example (win32 console app) retrieves data only at 65Hz. So looks like 35% of the data are being lost. I originally believed 100Hz sampling rate was too high for a BLE connection...
  • - But, funny thing is that if I add a very simple GUI (QApplication and QDialog) to the project, then teh program is eventually able to receive data at 100Hz....but it depends on the mouse activity! When the mouse moves around a button, frequency jumps to 100Hz, when it's static, it drops to 65Hz. I know it's hard to believe, so I did a video ;-)
  • - And, even more funny, if I remove the Qt style plugin qwindowsvistastyle.dll from my installation folder, then GUI is hugly and then there is no way you can get the 100Hz anymore, you're stuck to 65Hz. I know it's also hard to believe, so I did another video ;-)
When you are using vista display style, when the mouse moves around a button, you see Qt does some repaint to draw the button focus. And I'm wondering if this probably reports to Windows that the process needs more attention and finally makes the OS give more attention to this process and then it looses less data?
Note that I tried to change the process priority to "High" in the task manager but this apparently has no effect.
Question is/are:
  • Can anyone explain what's going on here?
  • I'm not necessarily concerned about having the win32 console app be able to retrieve the data at 100Hz. But I'm really concerned about having my Qt app be able to do that, without requiring the user to be constantly moving his mouse around a button....is there anything that could be done (at QApplication level, Windows level, Nordic driver level....)?
The MCVE code:
mydialog.h:
#pragma once
#include <QApplication>
#include <QDialog>
#include <QPushButton>
#include <QVBoxLayout>
#include <QShowEvent>
#include <QLabel>
class MyDialog : public QDialog
    Q_OBJECT
public:
    MyDialog();
    ~MyDialog();
    void showEvent( QShowEvent* event ) override;
public slots:
    void toggle();
    void notify( uint32_t count, float freq );
private:
    int run();
    uint8_t cccd_value;
    uint32_t close();
    QLabel* label;
main.cpp (modification of Nordic's main.c), fully available in pastbin
static MyDialog* notify_dialog = NULL;
static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
    clock_t now = clock();
    if (!m_hvx_start) {
        m_hvx_start = now;
    m_hvx_count++;
    float seconds = (float)(now - m_hvx_start) / CLOCKS_PER_SEC;
    if ( seconds >= 1 )
        float pkt_per_sec = m_hvx_count / seconds;
        if ( notify_dialog )
            notify_dialog->notify( m_hvx_count, pkt_per_sec );
        printf("pkts: %06d, pkt/s: %f\n", m_hvx_count, pkt_per_sec);
        fflush(stdout);
        // reset counters
        m_hvx_start = clock();
        m_hvx_count = 0;
MyDialog::MyDialog()
    setLayout( new QVBoxLayout() );
    QPushButton* button = new QPushButton( "Toggle", this );
    connect( button, SIGNAL(clicked()), this, SLOT(toggle()) );
    layout()->addWidget( button );
    layout()->addWidget( label = new QLabel( this ) );
    notify_dialog = this;
MyDialog::~MyDialog()
    close();
void MyDialog::showEvent( QShowEvent* event )
    QDialog::showEvent( event );
    run();
int MyDialog::run()
    uint32_t error_code;
    char* serial_port;
    physical_layer_t * phy;
    data_link_layer_t * data_link_layer;
    transport_layer_t * transport_layer;
        cccd_value = 0;
    serial_port = UART_PORT_NAME;
    printf("Serial port used: %s\n", serial_port); fflush(stdout);
    phy = sd_rpc_physical_layer_create_uart(serial_port, 1000000, SD_RPC_FLOW_CONTROL_NONE, SD_RPC_PARITY_NONE);
    data_link_layer = sd_rpc_data_link_layer_create_bt_three_wire(phy, 100);
    transport_layer = sd_rpc_transport_layer_create(data_link_layer, 100);
    m_adapter = sd_rpc_adapter_create(transport_layer);
    //sd_rpc_log_handler_severity_filter_set(adapter, SD_RPC_LOG_INFO);
    error_code = sd_rpc_open(m_adapter, status_handler, ble_evt_dispatch, log_handler);
    if (error_code != NRF_SUCCESS)
        printf("Failed to open the nRF5 BLE Driver. Error code: 0x%02X\n", error_code);
        fflush(stdout);
        return error_code;
    error_code = ble_stack_init();
        return error_code;
    error_code = ble_options_set();
        return error_code;
    scan_start();
void MyDialog::toggle()
    cccd_value ^= CCCD_NOTIFY;
    hrm_cccd_set(cccd_value);
uint32_t MyDialog::close()
    uint32_t error_code = sd_rpc_close(m_adapter);
        printf("Failed to close the nRF5 BLE Driver. Error code: 0x%02X\n", error_code);
        fflush(stdout);
        return error_code;
    printf("Closed\n"); fflush(stdout);
    return error_code;
void MyDialog::notify( uint32_t count, float freq )
    std::stringstream str;
    str << "During the last second, received " << count << " packets, frequency is " << freq << "Hz";
    label->setText( str.str().c_str() );
int main(int argc, char *argv[])
    QApplication app( argc, argv );
    MyDialog frame;
    frame.show();
    return app.exec();
  • Hello Edvin,
    My device is a central. The peripheral is a "Nordic_HRM" example customized to send data at 100Hz.
    The full code is available at https://pastebin.com/mNzjg5LZ. It's nordic sample program with just a QApplication added. All information you are looking for is available here.
    Jean Porcherot
  • Hello Edvin,
    I added more data rate monitoring in the pc-ble-driver code itself and recompiled it. One in reder thread (`SerializationTransport::readHandler`), one in the code getting data from the USB connection (`UartBoost::readHandler`) for which I monitor the number of packets and the number of bytes received. Here is what I observe:
    When data is received at 100Hz, I see:
    UartBoost::readHandler: 000213, pkt/s: 212.362900
    UartBoost::readHandler: 004315, bytes/s: 4302.093750
    SerializationTransport::readHandler: 000103, pkt/s: 102.385681
    pkts: 000102, pkt/s: 102.000000
    When data is received at 65Hz, I see:
    UartBoost::readHandler: 000061, pkt/s: 60.157787
    UartBoost::readHandler: 002570, bytes/s: 2534.516602
    SerializationTransport::readHandler: 000061, pkt/s: 60.157787
    pkts: 000061, pkt/s: 60.157787
    It's surprising that `UartBoost::readHandler` data rate (bytes/s) is reduced from 4302 to 2534 (same ratio reduced by ~40%, like final sampling rate), while the number of packets by second (pkt/s) is much more reduced by 71% (from 212 to 60). The BLE dongle sends 35% of data less but using 71% of packets less...I d'ont know what to conclude.
  • Added this piece of code in UartBoost::readHandler:
    std::cout << std::hex;
    for ( size_t pos = 0; pos != bytesTransferred; ++pos )
        std::cout << (unsigned) readBufferData[pos] << " ";
    std::cout << std::endl;
    Then, when reported data rate is 65Hz, I see in the console:
    UartBoost::readHandler: 000065, pkt/s: 64.165840
    UartBoost::readHandler: 002738, bytes/s: 2702.862793
    c0 c1 2e 2 f 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 e9 97 c0
    c0 c2 2e 2 e 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 50 cd c0
    c0 c3 2e 2 d 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 94 80 c0
    SerializationTransport::readHandler: 000065, pkt/s: 64.102562
    pkts: 000065, pkt/s: 64.102562
    c0 c4 2e 2 c 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 22 78 c0
    c0 c5 2e 2 b 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 13 b9 c0
    c0 c6 2e 2 a 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 b8 c9 c0
    c0 c7 2e 2 9 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 7c 84 c0
    c0 db dc 2e 2 10 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 97 66 c0
    c0 c1 2e 2 f 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 fb bd c0
    c0 c2 2e 2 e 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 42 e7 c0
    c0 c3 2e 2 d 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 86 aa c0
    c0 c4 2e 2 c 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 30 52 c0
    c0 c5 2e 2 b 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 6f b4 2 0 c8 61 0 20 f3 6b 2 0 1 93 c0
    c0 db dc 2e 2 10 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 85 4c c0
    c0 c6 2e 2 a 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 aa e3 c0
    c0 c7 2e 2 9 2 39 0 0 0 0 0 0 0 10 0 1 14 0 0 0 0 0 8c 56 0 20 75 b4 2 0 c8 61 0 20 f3 6b 2 0 6e ae c0
    UartBoost::readHandler: 000065, pkt/s: 64.102562
    UartBoost::readHandler: 002738, bytes/s: 2700.197021
    SerializationTransport::readHandler: 000065, pkt/s: 64.165840
    pkts: 000065, pkt/s: 64.165840
    And when it's 100Hz, I see:
    UartBoost::readHandler: 000170, pkt/s: 169.322723
    UartBoost::readHandler: 004306, bytes/s: 4288.844727
    13 b9 c0
    c0
    c0
    SerializationTransport::readHandler: 000103, pkt/s: 102.589645
    pkts: 000103, pkt/s: 102.691925
    c0
    c0
    0 1
    c0
    c0
    1 14 0 0 0 0
    c0
    c0
    c0
    c0
    c0
    c0
    b8 c9 c0
    c0
    c0
    c0
    c0
    c0 c3 2e 2 d
    c0
    c0
    c0
    c0 c6
    c0
    c0
    14
    14 0 0 0 0
    c0 c1
    c0 c4
    c0 c7
    c0 c2
    c0
    f3 6b 2 0 13 b9 c0
    c0 db
    UartBoost::readHandler: 000192, pkt/s: 191.235077
    UartBoost::readHandler: 004331, bytes/s: 4313.745117
    c0
    86 aa c0
    c0 c6
    SerializationTransport::readHandler: 000103, pkt/s: 101.778656
    pkts: 000103, pkt/s: 101.778656
    as you can see, the packets are splitted. At 65Hz, every packet is a full notification. At 100Hz, packets are splitted, meaning that many reads are necessary to get the full notification. This explains why at 65Hz we receive a few less bytes but a lot of less packets.
    if I use notpad tp clean the 100Hz packets to group them c0...c0, I get:
    very similar to the situation where we have 65Hz, but with ~35 more lines. This is expected.
    So looks like Windows or the driver at some points prefers to send less data but in a cleaner way (not splitting the packets)....again, I don't understand why.
    What I find strange is that if your device is a central, it is the peripheral that decides how often to send packets, as long as you use notifications (not indication), which you do, right? The central can't decide to receive just parts of the packet that the peripheral sends. It is either the entire packet or not any parts of the packet.
    What I suspect is that when you do some Qt stuff (which I don't know anything about), then the parsing of these packets are split up by some Qt interrupt of some sort. Do you have any idea regarding the IRQ priorities of the Qt interrupts?
