Button normal press and long press detect
I need some clarification about how to differentiate the normal press and long press detect for a single button to assign awake and sleep mode.
I am using nRF52832 SDK15.3 in segger embedded studio .
Is there any predefined code for sleep and awake system?
  • Vidar, Now i didn't change anything
    freshly opened ble_app_uart  (from sdk15.3)
    In bsp_btn_ble.c  file
    static uint32_t connection_buttons_configure()
        uint32_t err_code;
        err_code = bsp_event_to_button_action_assign(BTN_ID_SLEEP,
                                                     BTN_ACTION_SLEEP,
                                                     BSP_EVENT_DEFAULT);
        RETURN_ON_ERROR_NOT_INVALID_PARAM(err_code);
        err_code = bsp_event_to_button_action_assign(BTN_ID_WHITELIST_OFF,
                                                     BTN_ACTION_WHITELIST_OFF,
                                                     BSP_EVENT_WHITELIST_OFF);
        err_code = bsp_event_to_button_action_assign(BTN_ID_DISCONNECT,
                                                     BTN_ACTION_DISCONNECT,
                                                     BSP_EVENT_DISCONNECT);
        return NRF_SUCCESS;
    is changed to
        uint32_t err_code;
                                                     BTN_ACTION_SLEEP,
                                                     BSP_EVENT_DEFAULT);
                                                     BSP_EVENT_SLEEP);
        return NRF_SUCCESS;
    getting restarted
  • Coming back to your code which you given from the link
    i changed the value as
    #define USE_BSP 1
    and
        uint32_t err_code;
        switch (event)
            case BT0_SHORT_PUSH:
                NRF_LOG_INFO("Short button press");
                printf("\r\n Short button press.\r\n");
            case BT0_LONG_PUSH:
                NRF_LOG_INFO("Long button press");
    		printf("\r\n Long button press.\r\n");
    			sleep_mode_enter();
    just called sleep_mode_enter(); in the LONG_PUSH event
    system getting  restarted  not when to off state
  • It either means that the chip does not enter sleep because it is in debug interface mode, or that you have a pin that wakes it up again as soon as it goes to sleep. In other words, you need to test this without having the debugger attached, and go over your pin configurations.
