pc-ble-driver example heart_rate_collector get disconnected with error 0x22
I am running on pc-ble-driver master branch.
https://github.com/NordicSemiconductor/pc-ble-driver
Currently I am using abce7974fe983c23930d362b1769e51c8fa13cbf.
I am trying to verifying the newly added connectivity firmware for nRF52840 Dongle PCA10059.
So I compiled and loaded hex/sd_api_v6/connectivity_<ver>_usb_with_s140_6.1.0.hex
I am now getting error 0x22 which is BLE_HCI_STATUS_CODE_LMP_RESPONSE_TIMEOUT, once I connect to a Nordic_HRM peripheral. Peripheral is built with nRF5_SDK_15.2.0_9412b96 and run on PCA10040.
My host is Ubuntu 18.04.
I am doing this because the release note 4.0.0 says:"Support SoftDevice API version 2, 3, 5 and 6 in the same release". And I am aware that PCA10059 works fine with https://github.com/NordicSemiconductor/pc-ble-driver/blob/release/v2.3.2/hex/sd_api_v3/connectivity_1.2.3_usb_with_s132_3.1.hex
Beside this problem, I also found that hex/sd_api_v6/connectivity_<ver>_1m_with_s132_6.1.0.hex does not work anymore on PCA10040. Does not know when this has started.
Thanks & best regards,
Chencheng
  • Hi Edvin,
    I've tested Sigurd's suggesttion. It (27) works. I guess there's ongoing work to fix this issue right?
    And I think the rest of my problem is how to get connectivity_4.0.0_1m_with_s132_6.1.0.hex working for PCA10040.
    BR/Chencheng
  • Can you describe what you mean by connectivity_4.0.0_1m_with_s132_6.1.0.hex not working? Are you sure you are using the PCA10040 board? The nRF52832 DK?
    Are you sure you are using the ...4.0.0_1m_with_s132... and not the ...4.0.0_1m_for_s132... ?
  • Yes, I am sure PCA10040 nRF52832 DK not working with ..._with_s132_... for release 4.0.0.
    More debug error log:
    Serial port used: /dev/ttyACM2
    Baud rate used: 1000000
    Info: Successfully opened /dev/ttyACM2. Baud rate: 1000000. Flow control: none. Parity: none.
    Log: State change: STATE_START -> STATE_RESET
    Log:        1 ->  [N/A] type:          RESERVED_5 reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    Status: 6, message: Target Reset performed
    Log: State change: STATE_RESET -> STATE_UNINITIALIZED
    Log:        2 ->  [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    Log:     1/ 0 <-  [02 7d ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC_RESP]
    Log: State change: STATE_UNINITIALIZED -> STATE_INITIALIZED
    Log:        3 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:        4 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:        5 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:        6 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:     2/ 0 <-  [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    Log:        7 ->  [02 7d ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC_RESP]
    Log:        8 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:     3/ 0 <-  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:        9 ->  [04 7b 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG_RESP [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:       10 ->  [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log:     4/ 0 <-  [04 7b 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG_RESP [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    Log: State change: STATE_INITIALIZED -> STATE_ACTIVE
    Status: 7, message: Connection active
    Log:       11 ->  [00 69 40 00 00 00 01 00 01 00 01 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:0 payload_length:c data_integrity:1 header_checksum:72 err_code:0x0
    Log:     5/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    Log:     6/ 0 <-  [01 69 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:1 payload_length:6 data_integrity:1 header_checksum:ca err_code:0x0
    Log:       12 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    Log:       13 ->  [00 69 23 00 00 00 01 01 96 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:1 payload_length:a data_integrity:1 header_checksum:89 err_code:0x0
    Log:     7/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    Log:     8/ 0 <-  [01 69 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:2 payload_length:6 data_integrity:1 header_checksum:c1 err_code:0x0
    Log:       14 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    Log:       15 ->  [00 60 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:2 payload_length:2 data_integrity:1 header_checksum:0 err_code:0x0
    Log:     9/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
    Log:    10/ 0 <-  [01 60 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:3 payload_length:6 data_integrity:1 header_checksum:b8 err_code:0x0
    Log:       16 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
    Log:       17 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Log:       18 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Log:       19 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Log:       20 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Log:       21 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Log:       22 ->  [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0
    Status: 4, message: Error sending packet to target. Code: 0x802a
    Scan start failed with error code: 32773
  • Shall I open another ticket for PCA10040 issue?
  • what command did you write to get this message? What example are you running? Please post the command like this:
    heart_rate_collector_v6.exe COM7
    that you used to start the example.
    The example is running. It looks like you failed scan start with error code 32773 (=0x8005).
    As far as I can tell, this should not be possible. But let me know what example you are running.
    BR,
    Edvin
