Correct order of nrf_drv_twi commands
Hi, I try to read data from the ICM20948 IMU with I2C from my nRF 52840 DK.
Initialization of the device is correct, the IMU ID is sent to nRF correctly which means that the TWI protocol works fine  but when I initiate the process to read the accelerometer and gyroscope data from the IMU, the following error appears in the terminal emulator   app: ERROR 17 [NRF_ERROR_BUSY] at  ... ... ...  ICM20948.c:180.
The part of code that is pointed is line 12  in the following code snippet
void read_IMU(void){
       uint8_t pinax[] = {ICM20948_ACCEL_XOUT_H};
       int8_t rawData[12] = {0};
       err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDRESS, pinax, sizeof(pinax), false);
       while(nrf_drv_twi_is_busy(&m_twi));
       err_code = nrf_drv_twi_rx(&m_twi, ICM20948_ADDRESS, &rawData[0], 12);
       //while(nrf_drv_twi_is_busy(&m_twi));
       APP_ERROR_CHECK(err_code); //   <<<===== ERROR 17 [NRF ERROR BUSY]
       accel_buffer[0] = (int16_t) ((rawData[0] << 8) | rawData[1]); // x axis raw data
       accel_buffer[1] = (int16_t) ((rawData[2] << 8) | rawData[3]); // y axis raw data
       accel_buffer[2] = (int16_t) ((rawData[4] << 8) | rawData[5]); // z axis raw data
       gyro_buffer[0] = (int16_t) ((rawData[6] << 8)  | rawData[7]);  // x axis raw data
       gyro_buffer[1] = (int16_t) ((rawData[8] << 8)  | rawData[9]);  // y axis raw data
       gyro_buffer[2] = (int16_t) ((rawData[10] << 8) | rawData[11]); // z axis raw data
Now, if I add this line of code ---> while(nrf_drv_twi_is_busy(&m_twi));  before the APP_ERROR_CHECK() in line 11, the problem disappears
but in the next command  where I want to fetch the IMU data ---> nrf_drv_twi_rx()  , the  SDA line stays low and no stop is produced from the nRF52840 TWI.
As a result I cannot get an RX event from the nRF.   What am I doing wrong here?
Also, I cannot understand if the way that I am using nrf_drv_twi_is_busy(&m_twi) is correct or if I should use it another way
Thank you for your time
  • Hi.  The best thing would be if you could test it with an ICM20948 ic.... but since this might not be feasible maybe you could test the protocol in different SCL fequencies with an other I2C sensor .
    I tested it at 100,250,400 and 416kHz. The first two simply do not return nothing. They produce DNACK error . The 400kHz works sometimes and 416kHz all the time.
    Is there any way that I can configure the MCU clock source since  TWI depends on HFCLK source?     Apart from that
    Sorry no.
    I have ordered an ICM20948 from ebay, and if you can provide a project I may run on a nRF52-DK then I can try to recreate it as soon as I received it.
  • Hi Kenneth, sorry for the delayed answer. I modified the ICM20948 example and transferred it to the Dongle. The example now functions with 400k speed. This leads me to assume that the pull-up resistors of the I2C on the DK are different from those on my ICM module.
    Regards
  • Hello masterLee,
    I am using nrf52840 with SDK 15.3. I see a lot of twi drivers and its confusing which one to use. I want to read the ICM 20948 sensor data in burst mode for my application. In the second step I want to use the tap detection in DMP, so i have to write the DMP firmware into the ICM. But my twi drivers seem to constantly return with err_code 0x11 or 0x03 errors. Please let me know which is the best twi drivers for ICM. Your help would be much appreciated. Thanks and regards.
  • Use nrf_drv_twi.h . Basicaly what you need to do as a first step would be to read the device ID of ICM20948. The code for the ID is given in the sensor's datasheet.
    If you receive the same ID with the datasheet then your TWI  communication is working. If you receive garbage data, check the TWI handler function and the places you assign your twi_xfer_done flag to false. Also you should note that it is a good practice to reset the ICM20948 before performing anything else.
