Asset tracking application in SES not building succesfully
Dear support,
The build of the asset tracking application is not working
Below the copy and paste of SES buildlog
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/liboffsets.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
Building ‘libapp.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/arch/arm/core/libarch__arm__core.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/arch/arm/core/cortex_m/mpu/libarch__arm__core__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/lib/libc/newlib/liblib__libc__newlib.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/boards/arm/nrf52840_pca10090/libboards__arm__nrf52840_pca10090.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/subsys/net/libsubsys__net.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/subsys/net/ip/libsubsys__net__ip.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/nrf/ext/cjson/lib..__nrf__ext__cjson.a’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/nrf/lib/bsdlib/lib..__nrf__lib__bsdlib.a’ from solution ‘build’ in configuration ‘Common’
Compiling ‘bsd_os.c’
nrfx.h
nrfx_uarte.h
bsd_os.c
'NRFX_UARTE1_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_UARTE_INSTANCE'?
in definition of macro 'NRFX_CONCAT_3_'
in expansion of macro 'NRFX_CONCAT_3'
in expansion of macro 'NRFX_UARTE_INSTANCE'
bsd_os.c
'EGU1_IRQn' undeclared (first use in this function); did you mean 'FPU_IRQn'?
in expansion of macro 'BSD_APPLICATION_IRQ'
each undeclared identifier is reported only once for each function it appears in
'EGU2_IRQn' undeclared (first use in this function); did you mean 'FPU_IRQn'?
in expansion of macro 'TRACE_IRQ'
irq.h
arch.h
cpu.h
kernel_includes.h
kernel.h
device.h
init.h
bsd_os.c
in definition of macro '_ISR_DECLARE'
in expansion of macro '_ARCH_IRQ_DIRECT_CONNECT'
in expansion of macro 'IRQ_DIRECT_CONNECT'
'UART_1_TX_PIN' undeclared (first use in this function); did you mean 'UART_0_TX_PIN'?
'UART_1_RX_PIN' undeclared (first use in this function); did you mean 'UART_0_RX_PIN'?
'UART_1_CTS_PIN' undeclared (first use in this function); did you mean 'UART_0_CTS_PIN'?
'UART_1_RTS_PIN' undeclared (first use in this function); did you mean 'UART_0_RTS_PIN'?
irq.h
arch.h
cpu.h
kernel_includes.h
kernel.h
device.h
init.h
bsd_os.c
'IPC_IRQn' undeclared (first use in this function); did you mean 'FPU_IRQn'?
in expansion of macro 'BSD_NETWORK_IRQ'
Build failed
What is giving the error and how can I solve this?
