advertising to pre shared irk
i need a help
As mentioned in this thread
https://devzone.nordicsemi.com/f/nordic-q-a/18512/directed-advertising-with-pre-shared-irk
in need to do directed advertising with pre shared irk
this is my code where should i add on the peripheral side
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_soc.h"
#include "nrf_drv_saadc.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_tps.h"
#include "ble_ias.h"
#include "ble_lls.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "ble_ias_c.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble_db_discovery.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
//#include "nrf_ble_scan.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_fstorage.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                     "NORDIC"
#define APP_BLE_OBSERVER_PRIO           3
#define APP_BLE_CONN_CFG_TAG            1
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(120000)
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define SLAVE_LATENCY                   0
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)
//#define APP_ADV_INTERVAL                40
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)
#define APP_ADV_DURATION                18000
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
#define SEC_PARAM_BOND                  1
#define SEC_PARAM_MITM                  0
#define SEC_PARAM_LESC                  0
#define SEC_PARAM_KEYPRESS              0
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB                   0
#define SEC_PARAM_MIN_KEY_SIZE          7
#define SEC_PARAM_MAX_KEY_SIZE          16
#define INITIAL_LLS_ALERT_LEVEL         BLE_CHAR_ALERT_LEVEL_NO_ALERT
#define TX_POWER_LEVEL                  (-8)
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600
#define ADC_PRE_SCALING_COMPENSATION    6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270
#define ADC_RES_10BIT                   1024
#define DEAD_BEEF                       0xDEADBEEF
#define APP_BEACON_INFO_LENGTH          0x17
#define APP_ADV_DATA_LENGTH             0x15
#define APP_DEVICE_TYPE                 0x02
#define APP_MEASURED_RSSI               0xC5
#define APP_COMPANY_IDENTIFIER          0x004C
#define APP_MAJOR_VALUE                 0x00, 0x02
#define APP_MINOR_VALUE                 0x00, 0x02
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18
#define UICR_ADDRESS                    0x10001080
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);
BLE_TPS_DEF(m_tps);
BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LLS_DEF(m_lls);
BLE_BAS_DEF(m_bas);
BLE_IAS_C_DEF(m_ias_c);
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);
BLE_ADVERTISING_DEF(m_advertising);
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
static volatile bool m_is_high_alert_signalled;
static volatile bool m_is_ias_present = false;
static nrf_saadc_value_t adc_buf[2];
static ble_uuid_t m_adv_uuids[] =
    {BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
static ble_gap_adv_params_t m_adv_params;
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static uint8_t              m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scandata,
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
    APP_DEVICE_TYPE,
    APP_ADV_DATA_LENGTH,
    APP_BEACON_UUID,
    APP_MAJOR_VALUE,
    APP_MINOR_VALUE,
    APP_MEASURED_RSSI
static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
static void adc_configure(void)
    ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code;
    err_code = nrf_drv_saadc_sample();
static void timers_init(void)
    err_code = app_timer_init();
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            break; // BLE_ADV_EVT_FAST
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
            break; // BLE_ADV_EVT_IDLE
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scandata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    memset(&scandata, 0, sizeof(scandata));
    scandata.name_type             = BLE_ADVDATA_FULL_NAME;
    scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scandata.uuids_complete.p_uuids  = m_adv_uuids;
    ble_gap_addr_t gap_address;
    gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
    memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
    err_code = sd_ble_gap_addr_set(&gap_address);
    err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    if (erase_bonds == true){
        delete_bonds();
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
///**@brief Function for initializing the Advertising functionality.
// * @details Encodes the required advertising data and passes it to the stack.
// *          Also builds a structure to be passed to the stack when starting advertising.
//static void advertising_init(void)
//    ret_code_t             err_code;
//    ble_advertising_init_t init;
//    memset(&init, 0, sizeof(init));
//    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
//    init.advdata.include_appearance      = true;
//    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
//    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
//    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
//    init.config.ble_adv_fast_enabled  = true;
//    init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
//    init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
//    init.evt_handler = on_adv_evt;
//    err_code = ble_advertising_init(&m_advertising, &init);
//    APP_ERROR_CHECK(err_code);
//    ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void tps_init(void)
    ble_tps_init_t tps_init_obj;
    memset(&tps_init_obj, 0, sizeof(tps_init_obj));
    tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
    tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
    err_code = ble_tps_init(&m_tps, &tps_init_obj);
static void ias_init(void)
    ble_ias_init_t ias_init_obj;
    memset(&ias_init_obj, 0, sizeof(ias_init_obj));
    ias_init_obj.evt_handler  = on_ias_evt;
    ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
    err_code = ble_ias_init(&m_ias, &ias_init_obj);
static void lls_init(void)
    ble_lls_init_t lls_init_obj;
    // Initialize Link Loss Service
    memset(&lls_init_obj, 0, sizeof(lls_init_obj));
    lls_init_obj.evt_handler         = on_lls_evt;
    lls_init_obj.error_handler       = service_error_handler;
    lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
    lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
    lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
    err_code = ble_lls_init(&m_lls, &lls_init_obj);
static void bas_init(void)
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = on_bas_evt;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    bas_init_obj.bl_rd_sec        = SEC_OPEN;
    bas_init_obj.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init_obj.bl_report_rd_sec = SEC_OPEN;
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
static void ias_client_init(void)
    ble_ias_c_init_t ias_c_init_obj;
    memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
    m_is_high_alert_signalled = false;
    ias_c_init_obj.evt_handler   = on_ias_c_evt;
    ias_c_init_obj.error_handler = service_error_handler;
    err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
    qwr_init();
    tps_init();
    ias_init();
    lls_init();
    bas_init();
    ias_client_init();
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;
static void alert_signal(uint8_t alert_level)
    switch (alert_level)
        case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
            NRF_LOG_INFO("No Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
            break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
        case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
            NRF_LOG_INFO("Mild Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
            break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
        case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
            NRF_LOG_INFO("HIGH Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
            break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
    switch (p_evt->evt_type)
        case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
            if (p_evt->p_link_ctx != NULL)
                alert_signal(p_evt->p_link_ctx->alert_level);
            break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
            // No implementation needed.
        case BLE_LLS_EVT_LINK_LOSS_ALERT:
            alert_signal(p_evt->params.alert_level);
            break; // BLE_LLS_EVT_LINK_LOSS_ALERT
static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
        case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
            // IAS is found on peer. The Find Me Locator functionality of this app will work.
            err_code = ble_ias_c_handles_assign(&m_ias_c,
                                                p_evt->conn_handle,
                                                p_evt->alert_level.handle_value);
            m_is_ias_present = true;
            break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
        case BLE_IAS_C_EVT_DISCOVERY_FAILED:
            // IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
            break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
        case BLE_IAS_C_EVT_DISCONN_COMPLETE:
            // Disable alert buttons
            break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
        case BLE_BAS_EVT_NOTIFICATION_ENABLED:
            // Start battery timer
            err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
            break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
        case BLE_BAS_EVT_NOTIFICATION_DISABLED:
            err_code = app_timer_stop(m_battery_timer_id);
            break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            // Assign connection handle to the Queued Write module.
            err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
            // Discover peer's services.
            err_code = ble_db_discovery_start(&m_ble_db_discovery,
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
        case BSP_EVENT_KEY_0:
            if (m_is_ias_present)
                if (!m_is_high_alert_signalled)
                    err_code =
                        ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
                    err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
                if (err_code == NRF_SUCCESS)
                    m_is_high_alert_signalled = !m_is_high_alert_signalled;
                else if (
                    (err_code != NRF_ERROR_RESOURCES)
                    (err_code != NRF_ERROR_NOT_FOUND)
        } break;
        case BSP_EVENT_KEY_1:
            NRF_LOG_INFO("Alert Off.");
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
///**@brief Function for starting advertising.
//static void advertising_start(bool erase_bonds)
//    if (erase_bonds == true){
//        delete_bonds();
//        // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
//    else
//        uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    adc_configure();
    gap_params_init();
    gatt_init();
    advertising_init();
    db_discovery_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Proximity example started.");
    advertising_start(erase_bonds);
    tx_power_set();
    // Enter main loop.
    for (;;)
        idle_state_handle();
thank you
  • The code is is available in several SDK examples. I recommend you refer to the Alert Notification Application, which is probably the simplest example using directed advertising.
  • Hi @Einar Thorsrud,
    i think beacon cannot be spoofed by doing aes encryption so i thought to do as given in this thread
    https://devzone.nordicsemi.com/b/blog/posts/intro-to-application-level-security-using-the-ecb-
    but i am not getting were i was wrong
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_ecb.h"
    #include "ble.h"
    #include "ble_gatt.h"
    #include "ble_gatts.h"
    #include "nrf_delay.h"
    #include "fds.h"
    #define APP_ADV_TIMEOUT_IN_SECONDS      80
    #define BLE_ADV_DIRECTED_ENABLED        true
    #define BLE_ADV_DIRECTED_DISABLED       false
    #define BLE_ADV_DIRECTED_SLOW_ENABLED   true
    #define BLE_ADV_DIRECTED_SLOW_DISABLED  false
    #define BLE_ADV_FAST_ENABLED            true
    #define BLE_ADV_FAST_DISABLED           false
    #define BLE_ADV_SLOW_ENABLED            true
    #define BLE_ADV_SLOW_DISABLED           false
    #define BLE_ADV_WHITELIST_ENABLED       true
    #define BLE_ADV_WHITELIST_DISABLED   false
    #define BLE_GAP_ADV_TYPE_ADV_IND          0x00
    #define BLE_GAP_ADV_TYPE_ADV_DIRECT_IND   0x01
    #define BLE_GAP_ADV_TYPE_ADV_SCAN_IND     0x02
    #define BLE_GAP_ADV_TYPE_ADV_NONCONN_IND  0x03
    #define BLE_GAP_ADDR_TYPE_PUBLIC                        0x00
    #define BLE_GAP_ADDR_TYPE_RANDOM_STATIC                 0x01
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE     0x02
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE 0x03
    #define ECB_KEY_LEN            (16UL)
    #define COUNTER_BYTE_LEN       (4UL)
    #define NONCE_RAND_BYTE_LEN    (12UL)
    // The RNG wait values are typical and not guaranteed. See Product Specifications for more info.
    #ifdef NRF51
    #define RNG_BYTE_WAIT_US       (677UL)
    #elif defined NRF52
    #define RNG_BYTE_WAIT_US       (124UL)
    #else
    #error "Either NRF51 or NRF52 must be defined."
    BLE_TPS_DEF(m_tps);
    BLE_LLS_DEF(m_lls);
    BLE_BAS_DEF(m_bas);
        .adv_data =
        .scan_rsp_data =
        APP_DEVICE_TYPE,
        APP_BEACON_UUID,
        APP_MAJOR_VALUE,
        APP_MINOR_VALUE,
        APP_MEASURED_RSSI
            uint32_t          err_code;
                sleep_mode_enter();
        uint32_t      err_code;
    void nonce_generate(uint8_t * p_buf)
        uint8_t i         = COUNTER_BYTE_LEN;
        uint8_t remaining = NONCE_RAND_BYTE_LEN;
        while(0 != remaining)
            uint32_t err_code;
            uint8_t  available = 0;
            err_code = sd_rand_application_bytes_available_get(&available);
            available = ((available > remaining) ? remaining : available);
            if (0 != available)
    	        err_code = sd_rand_application_vector_get((p_buf + i), available);
    	        i         += available;
    	        remaining -= available;
    	    if (0 != remaining)
    	        nrf_delay_us(RNG_BYTE_WAIT_US * remaining);
    static bool m_initialized = false;
    static nrf_ecb_hal_data_t m_ecb_data;
    void ctr_init(const uint8_t * p_nonce, const uint8_t * p_ecb_key)
        m_initialized = true;
        // Save the key.
        memcpy(&m_ecb_data.key[0], p_ecb_key, ECB_KEY_LEN);
        // Copy the nonce.
        memcpy(&m_ecb_data.cleartext[COUNTER_BYTE_LEN],
    	          &p_nonce[COUNTER_BYTE_LEN],
    	          NONCE_RAND_BYTE_LEN);
        // Zero the counter value.
        memset(&m_ecb_data.cleartext[0], 0x00, COUNTER_BYTE_LEN);
    static uint32_t crypt(uint8_t * buf)
        uint8_t  i;
        uint32_t err_code;
        if (!m_initialized)
        err_code = sd_ecb_block_encrypt(&m_ecb_data);
        if (NRF_SUCCESS != err_code)
    	    return err_code;
        for (i=0; i < ECB_KEY_LEN; i++)
    	    buf[i] ^= m_ecb_data.ciphertext[i];
        // Increment the counter.
        (*((uint32_t*) m_ecb_data.cleartext))++;
        return NRF_SUCCESS;
    uint32_t ctr_encrypt(uint8_t * p_clear_text)
        return crypt(p_clear_text);
            delete_bonds();
        qwr_init();
        tps_init();
        ias_init();
        lls_init();
        bas_init();
        ias_client_init();
                                                    p_evt->conn_handle,
            } break;
            } break;
        switch (event)
                sleep_mode_enter();
                        err_code =
                    else if (
            } break;
            nrf_pwr_mgmt_run();
    //        delete_bonds();
    //    else
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        adc_configure();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        // Start execution.
        tx_power_set();
        // Enter main loop.
        for (;;)
    please check and change the code
    Thank you.
    I do not follow you here. However this is a very different topic that what started this thread so I ask that you make a new thread with this question.
  • Bjørn who is handling that case is currently out of office, but he should be back next week. Please note that what you are asking for is application specific though, so it is entirely up to you to implement it. I suggest you give the implementation a new try instead of waiting for a reply. If you still cannot make it work, then please clarify how you intend it tor work in detail and how in what way it fails.
