advertising to pre shared irk
i need a help
As mentioned in this thread
https://devzone.nordicsemi.com/f/nordic-q-a/18512/directed-advertising-with-pre-shared-irk
in need to do directed advertising with pre shared irk
this is my code where should i add on the peripheral side
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_soc.h"
#include "nrf_drv_saadc.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_tps.h"
#include "ble_ias.h"
#include "ble_lls.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "ble_ias_c.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble_db_discovery.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
//#include "nrf_ble_scan.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_fstorage.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                     "NORDIC"
#define APP_BLE_OBSERVER_PRIO           3
#define APP_BLE_CONN_CFG_TAG            1
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(120000)
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define SLAVE_LATENCY                   0
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)
//#define APP_ADV_INTERVAL                40
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)
#define APP_ADV_DURATION                18000
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
#define SEC_PARAM_BOND                  1
#define SEC_PARAM_MITM                  0
#define SEC_PARAM_LESC                  0
#define SEC_PARAM_KEYPRESS              0
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB                   0
#define SEC_PARAM_MIN_KEY_SIZE          7
#define SEC_PARAM_MAX_KEY_SIZE          16
#define INITIAL_LLS_ALERT_LEVEL         BLE_CHAR_ALERT_LEVEL_NO_ALERT
#define TX_POWER_LEVEL                  (-8)
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600
#define ADC_PRE_SCALING_COMPENSATION    6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270
#define ADC_RES_10BIT                   1024
#define DEAD_BEEF                       0xDEADBEEF
#define APP_BEACON_INFO_LENGTH          0x17
#define APP_ADV_DATA_LENGTH             0x15
#define APP_DEVICE_TYPE                 0x02
#define APP_MEASURED_RSSI               0xC5
#define APP_COMPANY_IDENTIFIER          0x004C
#define APP_MAJOR_VALUE                 0x00, 0x02
#define APP_MINOR_VALUE                 0x00, 0x02
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18
#define UICR_ADDRESS                    0x10001080
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);
BLE_TPS_DEF(m_tps);
BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LLS_DEF(m_lls);
BLE_BAS_DEF(m_bas);
BLE_IAS_C_DEF(m_ias_c);
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);
BLE_ADVERTISING_DEF(m_advertising);
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
static volatile bool m_is_high_alert_signalled;
static volatile bool m_is_ias_present = false;
static nrf_saadc_value_t adc_buf[2];
static ble_uuid_t m_adv_uuids[] =
    {BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
static ble_gap_adv_params_t m_adv_params;
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static uint8_t              m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scandata,
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
    APP_DEVICE_TYPE,
    APP_ADV_DATA_LENGTH,
    APP_BEACON_UUID,
    APP_MAJOR_VALUE,
    APP_MINOR_VALUE,
    APP_MEASURED_RSSI
static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
static void adc_configure(void)
    ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code;
    err_code = nrf_drv_saadc_sample();
static void timers_init(void)
    err_code = app_timer_init();
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            break; // BLE_ADV_EVT_FAST
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
            break; // BLE_ADV_EVT_IDLE
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scandata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    memset(&scandata, 0, sizeof(scandata));
    scandata.name_type             = BLE_ADVDATA_FULL_NAME;
    scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scandata.uuids_complete.p_uuids  = m_adv_uuids;
    ble_gap_addr_t gap_address;
    gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
    memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
    err_code = sd_ble_gap_addr_set(&gap_address);
    err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    if (erase_bonds == true){
        delete_bonds();
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
///**@brief Function for initializing the Advertising functionality.
// * @details Encodes the required advertising data and passes it to the stack.
// *          Also builds a structure to be passed to the stack when starting advertising.
//static void advertising_init(void)
//    ret_code_t             err_code;
//    ble_advertising_init_t init;
//    memset(&init, 0, sizeof(init));
//    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
//    init.advdata.include_appearance      = true;
//    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
//    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
//    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
//    init.config.ble_adv_fast_enabled  = true;
//    init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
//    init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
//    init.evt_handler = on_adv_evt;
//    err_code = ble_advertising_init(&m_advertising, &init);
//    APP_ERROR_CHECK(err_code);
//    ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void tps_init(void)
    ble_tps_init_t tps_init_obj;
    memset(&tps_init_obj, 0, sizeof(tps_init_obj));
    tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
    tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
    err_code = ble_tps_init(&m_tps, &tps_init_obj);
static void ias_init(void)
    ble_ias_init_t ias_init_obj;
    memset(&ias_init_obj, 0, sizeof(ias_init_obj));
    ias_init_obj.evt_handler  = on_ias_evt;
    ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
    err_code = ble_ias_init(&m_ias, &ias_init_obj);
static void lls_init(void)
    ble_lls_init_t lls_init_obj;
    // Initialize Link Loss Service
    memset(&lls_init_obj, 0, sizeof(lls_init_obj));
    lls_init_obj.evt_handler         = on_lls_evt;
    lls_init_obj.error_handler       = service_error_handler;
    lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
    lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
    lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
    err_code = ble_lls_init(&m_lls, &lls_init_obj);
static void bas_init(void)
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = on_bas_evt;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    bas_init_obj.bl_rd_sec        = SEC_OPEN;
    bas_init_obj.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init_obj.bl_report_rd_sec = SEC_OPEN;
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
static void ias_client_init(void)
    ble_ias_c_init_t ias_c_init_obj;
    memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
    m_is_high_alert_signalled = false;
    ias_c_init_obj.evt_handler   = on_ias_c_evt;
    ias_c_init_obj.error_handler = service_error_handler;
    err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
    qwr_init();
    tps_init();
    ias_init();
    lls_init();
    bas_init();
    ias_client_init();
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;
static void alert_signal(uint8_t alert_level)
    switch (alert_level)
        case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
            NRF_LOG_INFO("No Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
            break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
        case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
            NRF_LOG_INFO("Mild Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
            break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
        case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
            NRF_LOG_INFO("HIGH Alert.");
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
            break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
    switch (p_evt->evt_type)
        case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
            if (p_evt->p_link_ctx != NULL)
                alert_signal(p_evt->p_link_ctx->alert_level);
            break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
            // No implementation needed.
        case BLE_LLS_EVT_LINK_LOSS_ALERT:
            alert_signal(p_evt->params.alert_level);
            break; // BLE_LLS_EVT_LINK_LOSS_ALERT
static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
        case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
            // IAS is found on peer. The Find Me Locator functionality of this app will work.
            err_code = ble_ias_c_handles_assign(&m_ias_c,
                                                p_evt->conn_handle,
                                                p_evt->alert_level.handle_value);
            m_is_ias_present = true;
            break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
        case BLE_IAS_C_EVT_DISCOVERY_FAILED:
            // IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
            break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
        case BLE_IAS_C_EVT_DISCONN_COMPLETE:
            // Disable alert buttons
            break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
        case BLE_BAS_EVT_NOTIFICATION_ENABLED:
            // Start battery timer
            err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
            break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
        case BLE_BAS_EVT_NOTIFICATION_DISABLED:
            err_code = app_timer_stop(m_battery_timer_id);
            break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            // Assign connection handle to the Queued Write module.
            err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
            // Discover peer's services.
            err_code = ble_db_discovery_start(&m_ble_db_discovery,
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
        case BSP_EVENT_KEY_0:
            if (m_is_ias_present)
                if (!m_is_high_alert_signalled)
                    err_code =
                        ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
                    err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
                if (err_code == NRF_SUCCESS)
                    m_is_high_alert_signalled = !m_is_high_alert_signalled;
                else if (
                    (err_code != NRF_ERROR_RESOURCES)
                    (err_code != NRF_ERROR_NOT_FOUND)
        } break;
        case BSP_EVENT_KEY_1:
            NRF_LOG_INFO("Alert Off.");
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
///**@brief Function for starting advertising.
//static void advertising_start(bool erase_bonds)
//    if (erase_bonds == true){
//        delete_bonds();
//        // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
//    else
//        uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    adc_configure();
    gap_params_init();
    gatt_init();
    advertising_init();
    db_discovery_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Proximity example started.");
    advertising_start(erase_bonds);
    tx_power_set();
    // Enter main loop.
    for (;;)
        idle_state_handle();
thank you
  • HI @Einar Thorsrud,
    that is why i am asking the code for  directed advertising (peripheral device) with specific peer address, so that the peripheral device will not be  visible to other phones ( whose peer address does not match with that address which we set in the peripheral device) and the periheral device will be visible to only the phone with the peer address set in the peripheral device
    i need this like for the latest soft device s132_nrf52_6.1.0_softdevice
    case BLE_ADV_EVT_WHITELIST_REQUEST:
       ble_gap_whitelist_t  whitelist;
       ble_gap_addr_t*      p_whitelist_addr[3];
       ble_gap_addr_t whitelist_addr = {1, BLE_GAP_ADDR_TYPE_RANDOM_STATIC, {0x25,0xD7,0x90,0x11,0x7A,0xC8}};
       p_whitelist_addr[0]     = &whitelist_addr;
       whitelist.addr_count    = 1;
       whitelist.pp_addrs      =  p_whitelist_addr;
       whitelist.pp_irks       = NULL;
       whitelist.irk_count     = 0;
       err_code = ble_advertising_whitelist_reply(&whitelist);
    so that i can acheive that
    I am still really interested in the basic use case here. The reason is that if you intend to use white listing with the MAC address of a mobile phone, that will not work wery well in practice, as they change the address regularly (every 15 minutes for iOS). So you would need a mechanism to update the whitelist every time, or do as intended: use the IRK. Have you thought this through? If so, can you share with us the full picture of how this is supposed to work?
    Regarding the code, it is straightforward to adapt this to S132 version 6.x.x. Take for instance this code from the HID keyboard example in SDK 15.3:
                ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
                ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
                uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
                uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
                err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                            whitelist_irks,  &irk_cnt);
                NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                              addr_cnt, irk_cnt);
                // Set the correct identities list (no excluding peers with no Central Address Resolution).
                identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
                // Apply the whitelist.
                err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
            } break; //BLE_ADV_EVT_WHITELIST_REQUEST
    The API of ble_advertising_whitelist_reply() has changed, but is is quite simple. The new API consists of for paramters: MAC address aray, length of mac address aray, IRK array, length of IRK array. So essentially you only have to modify the first element of the whitelist_addrs (if using MAC address) or whitelist_irks (if using IRK) and set the length field to one. The other length field should be 0. Then it should work.
    In code this could be something like this with a fixed random static MAC (untested):
                whitelist_addrs[0].addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
                whitelist_addrs[0].addr[0] = 0x12;
                whitelist_addrs[0].addr[1] = 0x34;
                whitelist_addrs[0].addr[2] = 0x56;
                whitelist_addrs[0].addr[3] = 0x78;
                whitelist_addrs[0].addr[4] = 0x9a;
                whitelist_addrs[0].addr[5] = 0xbc;
                                                           whitelist_addrs,
                                                           1,
                                                           whitelist_irks,
                                                           0);
    the code given advertises to every device even if i change the mac address and i am unable to connect even if it is advertising
                                                           whitelist_addrs,
                                                           1,
                                                           whitelist_irks,
                                                           0);
    i need a code for which the beacon advertises to only the device mac address which we enter in the code
    please check why i am getting the error in the .c file attached below i tried to solve but again and again i am getting same error
    error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at D:\softwares\nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_proximity_beacon\main.c:591
    PC at: 0x00031E07
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "fds.h"
    #define APP_ADV_TIMEOUT_IN_SECONDS      80
    #define 	BLE_ADV_DIRECTED_ENABLED   true
    #define 	BLE_ADV_DIRECTED_DISABLED   false
    #define 	BLE_ADV_DIRECTED_SLOW_ENABLED   true
    #define 	BLE_ADV_DIRECTED_SLOW_DISABLED   false
    #define 	BLE_ADV_FAST_ENABLED   true
    #define 	BLE_ADV_FAST_DISABLED   false
    #define 	BLE_ADV_SLOW_ENABLED   true
    #define 	BLE_ADV_SLOW_DISABLED   false
    #define 	BLE_ADV_WHITELIST_ENABLED   true
    #define 	BLE_ADV_WHITELIST_DISABLED   false
    #define BLE_GAP_ADV_TYPE_ADV_IND          0x00
    #define BLE_GAP_ADV_TYPE_ADV_DIRECT_IND   0x01
    #define BLE_GAP_ADV_TYPE_ADV_SCAN_IND     0x02
    #define BLE_GAP_ADV_TYPE_ADV_NONCONN_IND  0x03
    #define BLE_GAP_ADDR_TYPE_PUBLIC                        0x00
    #define BLE_GAP_ADDR_TYPE_RANDOM_STATIC                 0x01
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE     0x02
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE 0x03
    BLE_TPS_DEF(m_tps);
    BLE_LLS_DEF(m_lls);
    BLE_BAS_DEF(m_bas);
    static pm_peer_id_t      m_peer_id;
    static uint16_t          m_conn_handle  = BLE_CONN_HANDLE_INVALID;
        .adv_data =
        .scan_rsp_data =
        APP_DEVICE_TYPE,
        APP_BEACON_UUID,
        APP_MAJOR_VALUE,
        APP_MINOR_VALUE,
        APP_MEASURED_RSSI
    static void whitelist_set(pm_peer_id_list_skip_t skip)
        pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
        uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
        ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
        NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                       peer_id_count + 1,
                       BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
        err_code = pm_whitelist_set(peer_ids, peer_id_count);
    static void identities_set(pm_peer_id_list_skip_t skip)
        pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
        uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
        err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
                if (     p_evt->params.peer_data_update_succeeded.flash_changed
                     && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                    NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                    // Note: You should check on what kind of white list policy your application should use.
                    whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
            uint32_t          err_code;
                sleep_mode_enter();
            case BLE_ADV_EVT_FAST_WHITELIST:
                NRF_LOG_INFO("Fast advertising with whitelist.");
                err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
            case BLE_ADV_EVT_SLOW_WHITELIST:
                NRF_LOG_INFO("Slow advertising with whitelist.");
                                                           whitelist_addrs,
                                                           1,
                                                           whitelist_irks,
                                                           0);
            case BLE_ADV_EVT_PEER_ADDR_REQUEST:
                pm_peer_data_bonding_t peer_bonding_data;
                // Only Give peer address if we have a handle to the bonded peer.
                if (m_peer_id != PM_PEER_ID_INVALID)
                    err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                    if (err_code != NRF_ERROR_NOT_FOUND)
                        // Manipulate identities to exclude peers with no Central Address Resolution.
                        identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                        ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                        err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
            } break;
        uint32_t      err_code;
            delete_bonds();
            ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
            APP_ERROR_CHECK(ret);
        qwr_init();
        tps_init();
        ias_init();
        lls_init();
        bas_init();
        ias_client_init();
                                                    p_evt->conn_handle,
                //Connected device
                ble_gap_addr_t  addr;
                memcpy(addr.addr, p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr, 6);
                printf(" Connected to %X:%X:%X:%X:%X:%X AddrType:0x0%d\n",
                   addr.addr[5],addr.addr[4],addr.addr[3],
                   addr.addr[2],addr.addr[1],addr.addr[0],
                   p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr_type);
            } break;
        uint32_t         err_code;
        static uint8_t   size  = 0;
        switch (event)
                sleep_mode_enter();
                    case BSP_EVENT_WHITELIST_OFF:
                        err_code =
                    else if (
            } break;
            nrf_pwr_mgmt_run();
    //        delete_bonds();
    //    else
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        adc_configure();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        // Start execution.
        tx_power_set();
        // Enter main loop.
        for (;;)
    I want to help you, but it is still unclear to me how you want to do this. Take the error you see on line 590, which is NRF_ERROR_INVALID_STATE. This is because you call ble_advertising_start(), but have not initialized the advertising module. In your advertising_init() you configure the SoftDevice directly instead of using the SoftDevice. You also have code for handling events from the advertising module, like BLE_ADV_EVT_WHITELIST_REQUEST, but these events cannot occur since the adverting module is not even initialized. So you have to decide whether you want to use the advertising module or not.
    I have added whitelisting support to your example and you can find it below. Essentially you just have to call the set_raw_initial_whitelist() function I included before configuring advertising. I also updated your code so that the filter policy is now set to BLE_GAP_ADV_FP_FILTER_CONNREQ. Before it was set to BLE_GAP_ADV_FP_ANY, which means that you would have allowed any device to connect regardless if it was in the whitelist or not.
    I tested this code on my side and it works as expected.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "fds.h"
    BLE_TPS_DEF(m_tps);
    BLE_LLS_DEF(m_lls);
    BLE_BAS_DEF(m_bas);
        .adv_data =
        .scan_rsp_data =
        APP_DEVICE_TYPE,
        APP_BEACON_UUID,
        APP_MAJOR_VALUE,
        APP_MINOR_VALUE,
        APP_MEASURED_RSSI
                       peer_id_count + 1,
            uint32_t          err_code;
                sleep_mode_enter();
                                                           whitelist_addrs,
                                                           1,
                                                           whitelist_irks,
                                                           0);
            } break;
        uint32_t      err_code;
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_FILTER_CONNREQ;
    /**@brief Set raw whitelist with one hardcoded MAC.
     * Only intended to be used when there are no current bonds (if so, those should  be whitelisted.)
    static void set_raw_initial_whitelist()
        static const ble_gap_addr_t         whitelist_addr = {1, BLE_GAP_ADDR_TYPE_RANDOM_STATIC, {0x45,0xC3,0x69,0x38,0xA3,0xC6}};
        static ble_gap_addr_t const * const p_whitelist_addr   = &whitelist_addr;
        err_code = sd_ble_gap_whitelist_set(&p_whitelist_addr, 1);
            delete_bonds();
            if (pm_peer_count() == 0)
                NRF_LOG_INFO("No bonds. Use hard coded default MAC for whitelist.");
                set_raw_initial_whitelist();
                NRF_LOG_INFO("Whitelist bonded peers.");
            // ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
            // APP_ERROR_CHECK(ret);
        qwr_init();
        tps_init();
        ias_init();
        lls_init();
        bas_init();
        ias_client_init();
                                                    p_evt->conn_handle,
                //Connected device
            } break;
        uint32_t         err_code;
        switch (event)
                sleep_mode_enter();
                        err_code =
                    else if (
            } break;
            nrf_pwr_mgmt_run();
    //        delete_bonds();
    //    else
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        adc_configure();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        // Start execution.
        tx_power_set();
        // Enter main loop.
        for (;;)
    thank you so much for your help
    but now i have two doubts
    1)where should we have to change the mac address either in
    case BLE_ADV_EVT_WHITELIST_REQUEST:                 or
    set_raw_initial_whitelist()     ??
    2)i had loaded the code given by you but still it is advertising to all devices
