DFU compatibility for a mesh example
I am interested to know how to make a mesh node (for example, a light server) compatible to perform a DFU.
I have gone through the DFU page and I noticed that the DFU is done over the Serial port. I understand that the dfu firmware is being replaced with blinky firmware. Correct me if I am wrong.
Now, what changes should I make to the commands inorder to make the light_server example node to be DFU compatible/capable over the air?
Would replacing the application hex file on step 8 to light_server instead of dfu solve it? or should I add any other commands to have light_server firmware first?
Thank you.
  • No. They do not need to be provisioned, but note that it takes some time even after the nrfutil cmd window says 100% until the update is finished. I believe it is done transmitting, but leave it on for a couple of minutes more. Then you will see that both devices (if they are configured with the same device_page (application version, application ID and manufacturer ID) will update the firmware. It is easy to confirm this with blinky, because it is easy to see when it is done (when it starts to blink).
    Can you test this? I have seen several posts claiming that it doesn't work because they restart the process when it reaches 100%. Just try to leave it on for a couple of minutes more.
    BR,
    Edvin
  • Can you test this? I have seen several posts claiming that it doesn't work because they restart the process when it reaches 100%. Just try to leave it on for a couple of minutes more.
    I tried it now but I couldn't reproduce the situation. I was transferring the DFU to both the board as LED1 and LED3 were ON while the transfer was taking place and it did push the update successfully resulting in LED2 blinking.
    If I were to have only one node as the gateway to push all the DFU updates into the mesh with various application ID's, do I need to have a different device page on the gateway node every time I push a different firmware?
    Because the device page that is flashed on the gateway node might have a different application id and that varies with every new firmware that is being updated.
    The new documentation released today states that the node checks for the application ID first and then decides whether to relay it or ignore. How can we make sure whether the node is going to relay or ignore?
    Does the device page contain application id, application version details or it just contains device series and soft device information?
  • I believe that the enocean FW is a bit different than other examples. Can you try with one of the others, if you do not intend to use enocean in the end?
    The Enocean switches are energy harvesting devices. I don't think they are listening at all times, as other mesh nodes. They only wake up and send a message when a button is pushed. This is probably why you don't see that they get the DFU packets over Mesh.
    Edvin
  • Can you try with one of the others, if you do not intend to use enocean in the end?
    I did add the DFU example to the experimental_dimming example and it works fine.
    Can I have an explanation about pushing the DFU to a gateway node and device page that I asked in my previous comment on this thread?
    Thank you.
  • Oh, sorry.
    Yes. You can push a FW with another application ID through a node.
    E.g. A network with 3 nodes, one with application ID 1, one with application ID 2, and one with application ID 3. Only the node with application ID 1 is connected via serial, and does all the pushing of the data.
    Generate 3 DFU images. Each with their own application ID, (1, 2 and 3):
    nrfutil dfu genpkg --application ..\..\bin\blinky\blinky_nrf52832_xxAA_s132_6.1.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file data\private_key.txt --sd-req 0x00AF --mesh data\dfu_test1.zip
    nrfutil dfu genpkg --application ..\..\bin\blinky\blinky_nrf52832_xxAA_s132_6.1.0.hex --company-id 0x00000059 --application-id 2 --application-version 2 --key-file data\private_key.txt --sd-req 0x00AF --mesh data\dfu_test2.zip
    nrfutil dfu genpkg --application ..\..\bin\blinky\blinky_nrf52832_xxAA_s132_6.1.0.hex --company-id 0x00000059 --application-id 3 --application-version 2 --key-file data\private_key.txt --sd-req 0x00AF --mesh data\dfu_test3.zip
    Now, to test this, I used the dfu example, and the blinky example as the DFU image, as you can see above. To speed things up a bit, I changed one thing in the DFU example. in nrf_mesh_dfu.c, line 75, I changed:
    #define TIMER_DATA_TIMEOUT_US               (600000000)  /**< Time to wait for next data during a transfer. */
    to
    #define TIMER_DATA_TIMEOUT_US               (10000000)   /**< Time to wait for next data during a transfer. */
    Resulting in a 10 second timeout instead of 10 minutes.
    This is just because the devices that the packet isn't intended for doesn't by default discover when the DFU transfer is complete, but stays in DFU mode for another 10 minutes.
    Reducing this to 10 seconds, I then used the bat script:
    REM nrfutil keys --gen-key data\private_key.txt
    nrfutil keys --show-vk hex data\private_key.txt
    cd tools\dfu
    REM python device_page_generator.py -d nrf52832_xxAA -sd "s132_6.1.0"
    cd ..\..
    nrfjprog -e --snr 111111111
    nrfjprog -e --snr 222222222
    nrfjprog -e --snr 333333333
    nrfjprog --program ..\..\bin\softdevice\s132_nrf52_6.1.0_softdevice.hex --verify --snr 111111111
    nrfjprog --program ..\..\bin\softdevice\s132_nrf52_6.1.0_softdevice.hex --verify --snr 222222222
    nrfjprog --program ..\..\bin\softdevice\s132_nrf52_6.1.0_softdevice.hex --verify --snr 333333333
    nrfjprog --program ..\..\bin\bootloader\gccarmemb\mesh_bootloader_gccarmemb_nrf52832_xxAA.hex --verify --snr 111111111
    nrfjprog --program ..\..\bin\bootloader\gccarmemb\mesh_bootloader_gccarmemb_nrf52832_xxAA.hex --verify --snr 222222222
    nrfjprog --program ..\..\bin\bootloader\gccarmemb\mesh_bootloader_gccarmemb_nrf52832_xxAA.hex --verify --snr 333333333
    nrfjprog --program build\dfu_nrf52832_xxAA_s132_6.1.0_Debug\dfu_nrf52832_xxAA_s132_6.1.0.hex --verify --snr 111111111
    nrfjprog --program build\dfu_nrf52832_xxAA_s132_6.1.0_Debug\dfu_nrf52832_xxAA_s132_6.1.0.hex --verify --snr 222222222
    nrfjprog --program build\dfu_nrf52832_xxAA_s132_6.1.0_Debug\dfu_nrf52832_xxAA_s132_6.1.0.hex --verify --snr 333333333
    nrfjprog --program tools\dfu\bin\device_page_id_1.hex --verify --snr 111111111
    nrfjprog --program tools\dfu\bin\device_page_id_2.hex --verify --snr 222222222
    nrfjprog --program tools\dfu\bin\device_page_id_3.hex --verify --snr 333333333
    nrfjprog --reset --snr 111111111
    nrfjprog --reset --snr 222222222
    nrfjprog --reset --snr 333333333
    TIMEOUT 10
    nrfutil --verbose dfu serial -pkg data\dfu_test2.zip -p COM7 -b 115200 -fc --mesh
    TIMEOUT 15
    nrfutil --verbose dfu serial -pkg data\dfu_test3.zip -p COM7 -b 115200 -fc --mesh
    TIMEOUT 15
    nrfutil --verbose dfu serial -pkg data\dfu_test1.zip -p COM7 -b 115200 -fc --mesh
    As you can see, it waits 15 seconds between each transfer, allowing the nodes to go back to default mode (not DFU mode), so that it is ready to receive a new packet.
    As you also can see, I transfer the image with application ID 2, 3 and then 1. All is sent through the COM port belonging to the device with application ID 1.
    When it is done, all 3 devices is updated. Now it uses the same application, but with different application IDs. The same method can be used to update with different applications to the devices with different application IDs.
    Edvin
