nRF Mesh and uart
hi..... everyone
I want to send the data from one node  to particular node and that same data should want to print in termite using uart . so i checked the ble_uart coexist example .so how to do this task . in this case which example i should use to pass the data from one to another node .
anyone can explain me clearly how do achieve this ?
  • The message that is sent in the example, is data and not a string. In the light switch example, a message is sent from client to server. You have to add UART to the server node if you want to print out the message.
  • Thanks . Which function is used to pass the data from client to server .
  • access_model_publish(...) is used to send data from client to server on the access layer. Have a look at this function on the application layer generic_onoff_client_set(...).
  •  here i have set my message , is it correct pls check here
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        uint32_t status = NRF_SUCCESS;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
        /* Button 1: On, Button 2: Off, Client[0]
         * Button 2: On, Button 3: Off, Client[1]
     char arr[5] = "code";
     char ara[5] = "set";
        switch(button_number)
            case 0:
            case 2:
                set_params.on_off = arr;
            case 1:
            case 3:
                set_params.on_off = Ara;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
  • Yes, it seems correct. Why have you :
    twice?
