scan filters for custom uuid is not matching
hi attached code for below requirement:
command: scan on - scan devices
command: devices - display filtered devices .
Filters set are for : thermometer, NUS and custom service for nonin sensor.
but i could able to get only thermometer in peripheral device list.
please check and let me know what is wrong with the code.
i am using : SDK 15.02 nRF52832
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "boards.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "app_error.h"
#include "app_timer.h"
#include "task_manager.h"
#include "nrf_cli.h"
#include "nrf_cli_rtt.h"
#include "nrf_cli_uart.h"
#include "nrf_cli_ble_uart.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_stack_guard.h"
#include "nrf_fstorage_sd.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_log_backend_flash.h"
#include "ble_nus.h"
#define DEVICE_NAME                     "Nordic_CLI"                                /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(2000)                      /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                81                                         /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                100                                        /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT          1                                          /**< Increment between each simulated battery level measurement. */
#define MIN_CONN_INTERVAL                MSEC_TO_UNITS(400, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                MSEC_TO_UNITS(650, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                    0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#ifdef RK_CLI
//Added custom service
#include "ble_cus.h"
#include "ble_hts.h"
#define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
static void on_cus_evt(ble_cus_t     * p_cus_service, ble_cus_evt_t * p_evt);
BLE_CUS_DEF(m_cus);
APP_TIMER_DEF(m_notification_timer_id);
ble_cus_init_t   cus_init;
//Added HTS service
BLE_HTS_DEF(m_hts);
static void on_hts_evt(ble_hts_t * p_hts, ble_hts_evt_t * p_evt);
#define TEMP_TYPE_AS_CHARACTERISTIC     0                                           /**< Determines if temperature type is given as characteristic (1) or as a field of measurement (0). */
static bool              m_hts_meas_ind_conf_pending = false;                       /**< Flag to keep track of when an indication confirmation is pending. */
static sensorsim_cfg_t   m_temp_celcius_sim_cfg;                                    /**< Temperature simulator configuration. */
static sensorsim_state_t m_temp_celcius_sim_state;                                  /**< Temperature simulator state. */
#define ADDR_STRING_LEN         (2 * (BLE_GAP_ADDR_LEN)+6)
NRF_BLE_SCAN_DEF(m_scan);
/* array of Scan filters */
static ble_uuid_t const m_scan_uuid[] =  { {BLE_UUID_NUS_SERVICE,BLE_UUID_TYPE_VENDOR_BEGIN},
                                          {BLE_UUID_HEALTH_THERMOMETER_SERVICE,BLE_UUID_TYPE_BLE},
                                          {BLE_UUID_NONIN_SENSOR_SERVICE,BLE_UUID_TYPE_VENDOR_BEGIN}};
typedef struct
    bool    is_not_empty;                   /**< Indicates that the structure is not empty. */
    uint8_t addr[BLE_GAP_ADDR_LEN];         /**< Device address. */
    char    dev_name[DEVICE_NAME_MAX_SIZE]; /**< Device name. */
    int8_t RSSI_value_RK;                   /**< RSSI value. */
}scanned_device_t;
typedef struct
    uint8_t * p_data;   /**< Pointer to data. */
    uint16_t  data_len; /**< Length of data. */
} data_t;
scanned_device_t   m_device[DEVICE_TO_FIND_MAX];                 /**< Stores device info from scan data. */
scanned_device_t * scan_device_info_get(void)
    return m_device;
static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report);
void scan_start(void);
//void address_to_cmd_add(ble_gap_addr_t const * p_connected_addr); to add devices to "known devices" list
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
NRF_CLI_UART_DEF(cli_uart,0 , 256, 16);
NRF_CLI_BLE_UART_DEF(cli_ble_uart, &m_gatt, 64, 32);
NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &cli_uart.transport,'\r', 4);
NRF_CLI_DEF(m_ble_cli, "ble_cli:~$ ", &cli_ble_uart.transport,'\r', 8);
static uint16_t  m_conn_handle = BLE_CONN_HANDLE_INVALID;                           /**< Handle of the current connection. */
task_id_t m_ble_console_task_id;
static ble_uuid_t m_adv_uuids[] =                                                   /**< Universally unique service identifiers. */
    {BLE_UUID_NUS_SERVICE,            BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
             advertising_start(false);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_dis_init_t     dis_init;
    ble_hts_init_t     hts_init;
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
    /*  RK code to initialize the nonin services used by the application.*/
         // Initialize CUS Service init structure to zero.
        memset(&cus_init, 0, sizeof(cus_init));
        cus_init.evt_handler = on_cus_evt;
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
        err_code = ble_cus_init(&m_cus, &cus_init);
         // Initialize Health Thermometer Service
    memset(&hts_init, 0, sizeof(hts_init));
    hts_init.evt_handler                 = on_hts_evt;
    hts_init.temp_type_as_characteristic = TEMP_TYPE_AS_CHARACTERISTIC;
    hts_init.temp_type                   = BLE_HTS_TEMP_TYPE_BODY;
    // Here the sec level for the Health Thermometer Service can be changed/increased.
    hts_init.ht_meas_cccd_wr_sec = SEC_JUST_WORKS;
    hts_init.ht_type_rd_sec      = SEC_OPEN;
    err_code = ble_hts_init(&m_hts, &hts_init);
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            //NRF_LOG_RAW_INFO("Fast advertising.\r");
        case BLE_ADV_EVT_IDLE:
            nrf_pwr_mgmt_run();
    // For readability
    //ble_gap_evt_t const        * p_gap_evt   = &p_ble_evt->evt.gap_evt;
        #ifdef RK_CLI
          case BLE_GAP_EVT_ADV_REPORT:
            // add all scanned devices without filter
            //device_to_list_add(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            nrf_cli_ble_uart_config_t config = { .conn_handle = m_conn_handle };
            err_code = nrf_cli_init(&m_ble_cli, &config, true, true, NRF_LOG_SEVERITY_INFO);
            APP_ERROR_CHECK(nrf_cli_task_create(&m_ble_cli));
        } break;
            NRF_LOG_INFO("Disconnected, reason %d.",
                          p_ble_evt->evt.gap_evt.params.disconnected.reason);
            (void)nrf_cli_uninit(&m_ble_cli);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle,
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
#ifdef RK_CLI
/**@brief Function for populating simulated health thermometer measurement.
static void hts_sim_measurement(ble_hts_meas_t * p_meas)
    static ble_date_time_t time_stamp = { 2012, 12, 5, 11, 50, 0 };
    uint32_t celciusX100;
    p_meas->temp_in_fahr_units = false;
    p_meas->time_stamp_present = true;
    p_meas->temp_type_present  = (TEMP_TYPE_AS_CHARACTERISTIC ? false : true);
    celciusX100 = sensorsim_measure(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
    p_meas->temp_in_celcius.exponent = -2;
    p_meas->temp_in_celcius.mantissa = celciusX100;
    p_meas->temp_in_fahr.exponent    = -2;
    p_meas->temp_in_fahr.mantissa    = (32 * 100) + ((celciusX100 * 9) / 5);
    p_meas->time_stamp               = time_stamp;
    p_meas->temp_type                = BLE_HTS_TEMP_TYPE_FINGER;
    // update simulated time stamp
    time_stamp.seconds += 27;
    if (time_stamp.seconds > 59)
        time_stamp.seconds -= 60;
        time_stamp.minutes++;
        if (time_stamp.minutes > 59)
            time_stamp.minutes = 0;
/**@brief Function for simulating and sending one Temperature Measurement.
static void temperature_measurement_send(void)
    ble_hts_meas_t simulated_meas;
    if (!m_hts_meas_ind_conf_pending)
        hts_sim_measurement(&simulated_meas);
        err_code = ble_hts_measurement_send(&m_hts, &simulated_meas);
        switch (err_code)
            case NRF_SUCCESS:
                // Measurement was successfully sent, wait for confirmation.
                m_hts_meas_ind_conf_pending = true;
            case NRF_ERROR_INVALID_STATE:
                // Ignore error.
                APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Health Thermometer Service events.
 * @details This function will be called for all Health Thermometer Service events which are passed
 *          to the application.
 * @param[in] p_hts  Health Thermometer Service structure.
 * @param[in] p_evt  Event received from the Health Thermometer Service.
    switch (p_evt->evt_type)
        case BLE_HTS_EVT_INDICATION_ENABLED:
            // Indication has been enabled, send a single temperature measurement
            temperature_measurement_send();
        case BLE_HTS_EVT_INDICATION_CONFIRMED:
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to
 *          the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service.
    switch(p_evt->evt_type)
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
             err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
        case BLE_CUS_EVT_NOTIFICATION_DISABLED:
            // Stop the application timer that is triggering the notifications
            err_code = app_timer_stop(m_notification_timer_id);
        case BLE_CUS_EVT_CONNECTED:
        case BLE_CUS_EVT_DISCONNECTED:
        case BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED:
/**@brief Function for searching for a device name and adding it to a dynamic command.
 * @details Use this function to parse the received advertising data and to find a given
 * name in them either as 'complete_local_name' or as 'short_local_name'.
 * @param[in]   p_adv_report   Advertising data to parse.
//static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report, uint16_t const *p_gatts_uuid)
    uint8_t  idx             = 0;
    uint16_t dev_name_offset = 0;
    uint16_t field_len;
    data_t   adv_data;
    // Initialize advertisement report for parsing
    adv_data.p_data   = (uint8_t *)p_adv_report->data.p_data;
    adv_data.data_len = p_adv_report->data.len;
    for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
        // If address is duplicated, then return.
        if (memcmp(p_adv_report->peer_addr.addr,
                   m_device[idx].addr,
                   sizeof(p_adv_report->peer_addr.addr)) == 0)
             /* update rssi value */
            memcpy(&m_device[idx].RSSI_value_RK,
                   &p_adv_report->rssi,
                   sizeof(p_adv_report->rssi));
            return;
    // Add device data if an empty record is found.
    for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
        if (!m_device[idx].is_not_empty)
          /* store peer address */
            memcpy(m_device[idx].addr,
                   sizeof(p_adv_report->peer_addr.addr));
            /* store rssi value */
            m_device[idx].is_not_empty = true;
            // Search for advertising names.
            field_len = ble_advdata_search(adv_data.p_data,
                                           adv_data.data_len,
                                           &dev_name_offset,
                                           BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
            if (field_len == 0)
                                               adv_data.data_len,
                                               &dev_name_offset,
                                               BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME);
                // If name is not found, then return.
                if (field_len == 0)
                    return;
            memcpy(m_device[idx].dev_name, &adv_data.p_data[dev_name_offset], field_len);
            m_device[idx].dev_name[field_len] = 0;
            return;
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
#ifdef RK_CLI //test scan filters
       case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            //Add devices to the list if the scan filter is matched
            device_to_list_add(p_scan_evt->params.filter_match.p_adv_report);
        }break;
//      case NRF_BLE_SCAN_EVT_NOT_FOUND:
//           if (p_scan_evt->params.filter_match.p_adv_report->peer_addr.addr[0] == 0x88)
//           NRF_LOG_RAW_INFO("Filter not found\r\n");
//          }break;
#endif //RK_CLI //test scan filters
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             // Scan is automatically stopped by the connection.
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
             ret_code_t ret;
            ret = nrf_ble_scan_start(&m_scan);
            APP_ERROR_CHECK(ret);
            ret = bsp_indication_set(BSP_INDICATE_SCANNING);
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = false;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    //add 'NRF_BLE_SCAN_UUID_CNT' filters
    for(int n_count = 0; n_count < NRF_BLE_SCAN_UUID_CNT; n_count++)
      err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_scan_uuid[n_count]);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/** @brief Function for initializing BLE components.
void ble_init(void)
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    APP_ERROR_CHECK(nrf_cli_ble_uart_service_init());
    peer_manager_init();
#ifdef RK_CLI
    scan_init();
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, 0);
#ifdef RK_CLI
    ret_code_t ret;
void scan_stop(void)
    ret_code_t ret;
    nrf_ble_scan_stop();
void int_addr_to_hex_str(char * p_result, uint8_t result_len, uint8_t const * const p_addr)
    ASSERT(p_result);
    ASSERT(p_addr);
    if (result_len > BLE_GAP_ADDR_LEN)
        return;
   // char buffer[BLE_GAP_ADDR_LEN] = {0};
    char tempbuffer = '\0';
    memset(p_result, 0, result_len);
    for (uint8_t i = 0; i < result_len; ++i)
        sprintf(&tempbuffer, "%.2X", p_addr[result_len - (i+1)]);
        strcat(p_result, &tempbuffer);
        if (i < (result_len - 1))
            strcat(p_result, ":");
/* Below funciton displays the scanned device list */
void device_list(nrf_cli_t const *p_cli, scanned_device_t * p_device )
    for (uint8_t i = 0; i < DEVICE_TO_FIND_MAX; i++)
        if (p_device[i].is_not_empty)
            nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Device ");
            char buffer[ADDR_STRING_LEN];
            int_addr_to_hex_str(buffer, BLE_GAP_ADDR_LEN, p_device[i].addr);
            nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s %s %d dB\r\n", buffer,  p_device[i].dev_name, p_device[i].RSSI_value_RK);
static void scan_on_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
    scan_start();
    nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scanning...\r\n");
static void scan_off_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
    scan_stop();
    nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scan stopped.\r\n");
static void display_device_list_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
  if (argc >= 2)
        if (nrf_cli_help_requested(p_cli))
            nrf_cli_help_print(p_cli, NULL, 0);
            return;
                            NRF_CLI_ERROR,
                            "%s:%s%s\r\n",
                            argv[0],
                            " bad parameter ",
                            argv[1]);
            return;
    /* Print connectable devices from scan data.*/
    scanned_device_t * p_device_list = scan_device_info_get();
    device_list(p_cli, p_device_list);
static void default_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
  if (argc >= 2)
            return;
                            NRF_CLI_ERROR,
                            "%s:%s%s\r\n",
                            argv[0],
                            " bad parameter ",
                            argv[1]);
            return;
// Register "mpu" command and it's subcommands in CLI.
NRF_CLI_CREATE_STATIC_SUBCMD_SET(scan_commands)
     NRF_CLI_CMD(on, NULL, "Scan on.", scan_on_cmd),
     NRF_CLI_CMD(off, NULL, "Scan off.", scan_off_cmd),
     NRF_CLI_SUBCMD_SET_END
NRF_CLI_CMD_REGISTER(scan, &scan_commands, "Commands for scan control", default_cmd);
NRF_CLI_CMD_REGISTER(devices, NULL, "print device list", display_device_list_cmd);
void idle_task(void * p_context)
    bool erase_bonds = (bool)p_context;
      advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
            nrf_pwr_mgmt_run();
        task_yield();
static void core_init(void)
    APP_ERROR_CHECK(NRF_LOG_INIT(app_timer_cnt_get));
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    APP_ERROR_CHECK(nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO));
    APP_ERROR_CHECK(nrf_drv_clock_init());
    APP_ERROR_CHECK(app_timer_init());
    APP_ERROR_CHECK(nrf_pwr_mgmt_init());
    APP_ERROR_CHECK(nrf_cli_task_create(&m_cli_uart));
/**@brief Function for application main entry.
    bool erase_bonds;
    core_init();
    ble_init();
    NRF_LOG_RAW_INFO("BLE Nordic Uart Service started\r\n");
    NRF_LOG_RAW_INFO("Press Tab to view all available commands.\r\n");
    task_manager_start(idle_task, (void *)erase_bonds);
#include "sdk_common.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
/**@brief Function for handling the Connect event.
 * @param[in]   p_cus       Custom Service structure.
 * @param[in]   p_ble_evt   Event received from the BLE stack.
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_CONNECTED;
    p_cus->evt_handler(p_cus, &evt);
/**@brief Function for handling the Disconnect event.
static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    UNUSED_PARAMETER(p_ble_evt);
    p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
/**@brief Function for handling the Write event.
static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    ble_cus_evt_t evt;
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    // Custom Value Characteristic Written to.
    if (p_evt_write->handle == p_cus->oxy_measurement_handles.value_handle)
        nrf_gpio_pin_toggle(LED_4);
    // Check if it is the Servo Control Characteristic that has been written to
    if (p_evt_write->handle == p_cus->nonin_control_point_handles.value_handle)
      // Set the event type
      evt.evt_type = BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED;
      // Assign the written value in the ble_cus_evt_t struct
      evt.servo_ctrl_value = p_evt_write->data[0];
      // Invoke the on_cus_evt event handler in main.c
    // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
    if ((p_evt_write->handle == p_cus->oxy_measurement_handles.cccd_handle)
        && (p_evt_write->len == 2)
        // CCCD written, call application event handler
        if (p_cus->evt_handler != NULL)
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
            // Call the application event handler.
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
    ble_cus_t * p_cus = (ble_cus_t *) p_context;
   // NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
    if (p_cus == NULL || p_ble_evt == NULL)
        return;
            on_connect(p_cus, p_ble_evt);
            on_disconnect(p_cus, p_ble_evt);
        case BLE_GATTS_EVT_WRITE:
            on_write(p_cus, p_ble_evt);
/**@brief Function for adding the Custom Value characteristic.
 * @param[in]   p_cus        Battery Service structure.
 * @param[in]   p_cus_init   Information needed to initialize the service.
 * @return      NRF_SUCCESS on success, otherwise an error code.
//static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
//    uint32_t            err_code;
//    ble_gatts_char_md_t char_md;
//    ble_gatts_attr_md_t cccd_md;
//    ble_gatts_attr_t    attr_char_value;
//    ble_uuid_t          ble_uuid;
//    ble_gatts_attr_md_t attr_md;
//    // Add Custom Value characteristic
//    memset(&cccd_md, 0, sizeof(cccd_md));
//    //  Read  operation on cccd should be possible without authentication.
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
//    cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
//    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
//    memset(&char_md, 0, sizeof(char_md));
//    char_md.char_props.read   = 1;
//    char_md.char_props.write  = 1;
//    char_md.char_props.notify = 1;
//    char_md.p_char_user_desc  = NULL;
//    char_md.p_char_pf         = NULL;
//    char_md.p_user_desc_md    = NULL;
//    char_md.p_cccd_md         = &cccd_md;
//    char_md.p_sccd_md         = NULL;
//    ble_uuid.type = p_cus->uuid_type;
//    ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
//    memset(&attr_md, 0, sizeof(attr_md));
//    attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
//    attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
//    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
//    attr_md.rd_auth    = 0;
//    attr_md.wr_auth    = 0;
//    attr_md.vlen       = 0;
//    memset(&attr_char_value, 0, sizeof(attr_char_value));
//    attr_char_value.p_uuid    = &ble_uuid;
//    attr_char_value.p_attr_md = &attr_md;
//    attr_char_value.init_len  = sizeof(uint8_t);
//    attr_char_value.init_offs = 0;
//    attr_char_value.max_len   = sizeof(uint8_t);
//    err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
//                                               &attr_char_value,
//                                               &p_cus->custom_value_handles);
//    if (err_code != NRF_SUCCESS)
//        return err_code;
//    return NRF_SUCCESS;
///**@brief Function for adding the Custom Value characteristic.
// * @param[in]   p_cus        Battery Service structure.
// * @param[in]   p_cus_init   Information needed to initialize the service.
// * @return      NRF_SUCCESS on success, otherwise an error code.
//static uint32_t servo_ctrl_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
//    char_md.char_props.notify = 0;
//    memset(&ble_uuid, 0, sizeof(ble_uuid));
//    ble_uuid128_t base_uuid_2 = {CUSTOM_SERVICE_UUID_BASE_2};
//    err_code =  sd_ble_uuid_vs_add(&base_uuid_2, &p_cus->uuid_type_2);
//    VERIFY_SUCCESS(err_code);
//    ble_uuid.type = p_cus->uuid_type_2;
//    ble_uuid.uuid = SERVO_CTRL_CHAR_UUID;
//                                               &p_cus->servo_control_handles);
//        return err_code;
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    if (p_cus == NULL || p_cus_init == NULL)
        return NRF_ERROR_NULL;
    uint32_t   err_code;
    ble_add_char_params_t add_char_params;
    // Initialize service structure
    p_cus->evt_handler               = p_cus_init->evt_handler;
    // Add Nonin Oxy sensor Service UUID BASE
    ble_uuid128_t base_uuid = BLE_UUID_NONIN_SENSOR_SERVICE_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
    ble_uuid.uuid = BLE_UUID_NONIN_SENSOR_SERVICE;
    // Add the Custom Service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
        return err_code;
    // Add UUID BASE for the Oxy measurement characteristic
    ble_uuid128_t base_uuid_oxy_measurement = BLE_UUID_OXY_MEASUREMENT_CHARACTERISTIC_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid_oxy_measurement, &p_cus->uuid_type_oxy_measurement);
    //Add the oxymetry measurement Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_OXY_MEASUREMENT_CHARACTERISTIC;
    add_char_params.uuid_type                = p_cus->uuid_type_oxy_measurement;
    add_char_params.max_len                  = sizeof(uint8_t);
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.write         = 1;
    add_char_params.char_props.write_wo_resp = 1;
    add_char_params.read_access  = SEC_OPEN;
    add_char_params.write_access = SEC_OPEN;
    err_code = characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->oxy_measurement_handles);
        return err_code;
    // Add UUID BASE for Nonin control point characteristic
    ble_uuid128_t base_uuid_nonin_control_point = BLE_UUID_NONIN_CONTROL_POINT_CHARACTERISTIC_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid_nonin_control_point, &p_cus->uuid_type_nonin_control_point);
    // Add the Nonin control point Characteristic.
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
    add_char_params.uuid              = BLE_UUID_NONIN_CONTROL_POINT_CHARACTERISTIC;
    add_char_params.uuid_type         = p_cus->uuid_type;
    add_char_params.char_props.notify = 1;
    add_char_params.cccd_write_access = SEC_OPEN;
    return characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->nonin_control_point_handles);
uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value)
    NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
    if (p_cus == NULL)
    uint32_t err_code = NRF_SUCCESS;
    ble_gatts_value_t gatts_value;
    // Initialize value struct.
    memset(&gatts_value, 0, sizeof(gatts_value));
    gatts_value.len     = sizeof(uint8_t);
    gatts_value.offset  = 0;
    gatts_value.p_value = &custom_value;
    // Update database.
    err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
                                      p_cus->oxy_measurement_handles.value_handle,
                                      &gatts_value);
        return err_code;
    // Send value if connected and notifying.
    if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_cus->oxy_measurement_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = gatts_value.offset;
        hvx_params.p_len  = &gatts_value.len;
        hvx_params.p_data = gatts_value.p_value;
        err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
        NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
        err_code = NRF_ERROR_INVALID_STATE;
        NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
    return err_code;
ble_cus.hsdk_config.h\
i have modified ble_app_cli example code to achieve my requirements. attached files main.c, sdk_config.h, ble_cus.c(custom service), ble_cus.h
  • Just in case there are some misunderstandings here:
    You are scanning as a central, not for central devices. So as a central, you are scanning for peripheral devices.
    Rekha said:
    it is set true. Because there might be different central devices with any one of these UUID's so i just want to check whether atleast one UUID is present or not. if yes then move to matched list and display in device list.
    so there may be different peripheral devices with only one of these UUIDs, and you want to connect to any peripheral with at least one of the UUIDs, is that correct?
    From the documentation (found online, but also in nrf_ble_scan.h line 286:
        bool all_filters_mode;                              /**< Filter mode. If true, all set filters must be matched to generate an event.*/
    This means that if all_filters_mode is true, then all filter UUIDs have to match in order to connect. The reason it is not checking for the others is that if the first one doesn't match, then there is no point in checking the rest if all_filters_mode is true.
    Try to set all_filters_mode to false. This is typically done in scan_init() in main.c:
    the last input parameter is the all_filters_mode value.
    Rekha said:
    But the issue is with scan filter not advertising. because i have 3 different device each advertises with one UUID. so i want to list all these 3 devices.
    I understand, but having  more than one service or characteristic UUID in your peripheral doesn't mean that it is included in the BLE advertisements.
  • so there may be different peripheral devices with only one of these UUIDs, and you want to connect to any peripheral with at least one of the UUIDs, is that correct?
    Yes..Sorry for that mistyping.i am scanning for peripherals
  • err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    Hi i have set it to false but still i am facing the issue.
    Thanks
    Rekha
  • Ok. Can you send me the advertising message and the UUIDs that should have been discovered? Does it detect any of the UUIDs? Does it work when you only have one of the UUIDs in your filter, and you try to connect to a device that advertises with this?
  • below are the filters used
    Step 1:
    initially i added NUS and Thermometer in the array and it was working fine and i could able to display devices for both the services.
    Note: I did not add service for Thermometer at that moment, only NUS service was included.
    Step 2:
    Later on i added service code for thermometer and Nonin. and added Nonin UUID to the filter array.after adding these it is showing only Thermometer in the device list other two are missing now.
