scan filters for custom uuid is not matching
hi attached code for below requirement:
command: scan on - scan devices
command: devices - display filtered devices .
Filters set are for : thermometer, NUS and custom service for nonin sensor.
but i could able to get only thermometer in peripheral device list.
please check and let me know what is wrong with the code.
i am using : SDK 15.02 nRF52832
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "boards.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "app_error.h"
#include "app_timer.h"
#include "task_manager.h"
#include "nrf_cli.h"
#include "nrf_cli_rtt.h"
#include "nrf_cli_uart.h"
#include "nrf_cli_ble_uart.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_stack_guard.h"
#include "nrf_fstorage_sd.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_log_backend_flash.h"
#include "ble_nus.h"
#define DEVICE_NAME                     "Nordic_CLI"                                /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(2000)                      /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                81                                         /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                100                                        /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT          1                                          /**< Increment between each simulated battery level measurement. */
#define MIN_CONN_INTERVAL                MSEC_TO_UNITS(400, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                MSEC_TO_UNITS(650, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                    0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#ifdef RK_CLI
//Added custom service
#include "ble_cus.h"
#include "ble_hts.h"
#define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
static void on_cus_evt(ble_cus_t     * p_cus_service, ble_cus_evt_t * p_evt);
BLE_CUS_DEF(m_cus);
APP_TIMER_DEF(m_notification_timer_id);
ble_cus_init_t   cus_init;
//Added HTS service
BLE_HTS_DEF(m_hts);
static void on_hts_evt(ble_hts_t * p_hts, ble_hts_evt_t * p_evt);
#define TEMP_TYPE_AS_CHARACTERISTIC     0                                           /**< Determines if temperature type is given as characteristic (1) or as a field of measurement (0). */
static bool              m_hts_meas_ind_conf_pending = false;                       /**< Flag to keep track of when an indication confirmation is pending. */
static sensorsim_cfg_t   m_temp_celcius_sim_cfg;                                    /**< Temperature simulator configuration. */
static sensorsim_state_t m_temp_celcius_sim_state;                                  /**< Temperature simulator state. */
#define ADDR_STRING_LEN         (2 * (BLE_GAP_ADDR_LEN)+6)
NRF_BLE_SCAN_DEF(m_scan);
/* array of Scan filters */
static ble_uuid_t const m_scan_uuid[] =  { {BLE_UUID_NUS_SERVICE,BLE_UUID_TYPE_VENDOR_BEGIN},
                                          {BLE_UUID_HEALTH_THERMOMETER_SERVICE,BLE_UUID_TYPE_BLE},
                                          {BLE_UUID_NONIN_SENSOR_SERVICE,BLE_UUID_TYPE_VENDOR_BEGIN}};
typedef struct
    bool    is_not_empty;                   /**< Indicates that the structure is not empty. */
    uint8_t addr[BLE_GAP_ADDR_LEN];         /**< Device address. */
    char    dev_name[DEVICE_NAME_MAX_SIZE]; /**< Device name. */
    int8_t RSSI_value_RK;                   /**< RSSI value. */
}scanned_device_t;
typedef struct
    uint8_t * p_data;   /**< Pointer to data. */
    uint16_t  data_len; /**< Length of data. */
} data_t;
scanned_device_t   m_device[DEVICE_TO_FIND_MAX];                 /**< Stores device info from scan data. */
scanned_device_t * scan_device_info_get(void)
    return m_device;
static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report);
void scan_start(void);
//void address_to_cmd_add(ble_gap_addr_t const * p_connected_addr); to add devices to "known devices" list
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
NRF_CLI_UART_DEF(cli_uart,0 , 256, 16);
NRF_CLI_BLE_UART_DEF(cli_ble_uart, &m_gatt, 64, 32);
NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &cli_uart.transport,'\r', 4);
NRF_CLI_DEF(m_ble_cli, "ble_cli:~$ ", &cli_ble_uart.transport,'\r', 8);
static uint16_t  m_conn_handle = BLE_CONN_HANDLE_INVALID;                           /**< Handle of the current connection. */
task_id_t m_ble_console_task_id;
static ble_uuid_t m_adv_uuids[] =                                                   /**< Universally unique service identifiers. */
    {BLE_UUID_NUS_SERVICE,            BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
             advertising_start(false);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_dis_init_t     dis_init;
    ble_hts_init_t     hts_init;
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
    /*  RK code to initialize the nonin services used by the application.*/
         // Initialize CUS Service init structure to zero.
        memset(&cus_init, 0, sizeof(cus_init));
        cus_init.evt_handler = on_cus_evt;
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
        err_code = ble_cus_init(&m_cus, &cus_init);
         // Initialize Health Thermometer Service
    memset(&hts_init, 0, sizeof(hts_init));
    hts_init.evt_handler                 = on_hts_evt;
    hts_init.temp_type_as_characteristic = TEMP_TYPE_AS_CHARACTERISTIC;
    hts_init.temp_type                   = BLE_HTS_TEMP_TYPE_BODY;
    // Here the sec level for the Health Thermometer Service can be changed/increased.
    hts_init.ht_meas_cccd_wr_sec = SEC_JUST_WORKS;
    hts_init.ht_type_rd_sec      = SEC_OPEN;
    err_code = ble_hts_init(&m_hts, &hts_init);
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            //NRF_LOG_RAW_INFO("Fast advertising.\r");
        case BLE_ADV_EVT_IDLE:
            nrf_pwr_mgmt_run();
    // For readability
    //ble_gap_evt_t const        * p_gap_evt   = &p_ble_evt->evt.gap_evt;
        #ifdef RK_CLI
          case BLE_GAP_EVT_ADV_REPORT:
            // add all scanned devices without filter
            //device_to_list_add(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            nrf_cli_ble_uart_config_t config = { .conn_handle = m_conn_handle };
            err_code = nrf_cli_init(&m_ble_cli, &config, true, true, NRF_LOG_SEVERITY_INFO);
            APP_ERROR_CHECK(nrf_cli_task_create(&m_ble_cli));
        } break;
            NRF_LOG_INFO("Disconnected, reason %d.",
                          p_ble_evt->evt.gap_evt.params.disconnected.reason);
            (void)nrf_cli_uninit(&m_ble_cli);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle,
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
#ifdef RK_CLI
/**@brief Function for populating simulated health thermometer measurement.
static void hts_sim_measurement(ble_hts_meas_t * p_meas)
    static ble_date_time_t time_stamp = { 2012, 12, 5, 11, 50, 0 };
    uint32_t celciusX100;
    p_meas->temp_in_fahr_units = false;
    p_meas->time_stamp_present = true;
    p_meas->temp_type_present  = (TEMP_TYPE_AS_CHARACTERISTIC ? false : true);
    celciusX100 = sensorsim_measure(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
    p_meas->temp_in_celcius.exponent = -2;
    p_meas->temp_in_celcius.mantissa = celciusX100;
    p_meas->temp_in_fahr.exponent    = -2;
    p_meas->temp_in_fahr.mantissa    = (32 * 100) + ((celciusX100 * 9) / 5);
    p_meas->time_stamp               = time_stamp;
    p_meas->temp_type                = BLE_HTS_TEMP_TYPE_FINGER;
    // update simulated time stamp
    time_stamp.seconds += 27;
    if (time_stamp.seconds > 59)
        time_stamp.seconds -= 60;
        time_stamp.minutes++;
        if (time_stamp.minutes > 59)
            time_stamp.minutes = 0;
/**@brief Function for simulating and sending one Temperature Measurement.
static void temperature_measurement_send(void)
    ble_hts_meas_t simulated_meas;
    if (!m_hts_meas_ind_conf_pending)
        hts_sim_measurement(&simulated_meas);
        err_code = ble_hts_measurement_send(&m_hts, &simulated_meas);
        switch (err_code)
            case NRF_SUCCESS:
                // Measurement was successfully sent, wait for confirmation.
                m_hts_meas_ind_conf_pending = true;
            case NRF_ERROR_INVALID_STATE:
                // Ignore error.
                APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Health Thermometer Service events.
 * @details This function will be called for all Health Thermometer Service events which are passed
 *          to the application.
 * @param[in] p_hts  Health Thermometer Service structure.
 * @param[in] p_evt  Event received from the Health Thermometer Service.
    switch (p_evt->evt_type)
        case BLE_HTS_EVT_INDICATION_ENABLED:
            // Indication has been enabled, send a single temperature measurement
            temperature_measurement_send();
        case BLE_HTS_EVT_INDICATION_CONFIRMED:
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to
 *          the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service.
    switch(p_evt->evt_type)
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
             err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
        case BLE_CUS_EVT_NOTIFICATION_DISABLED:
            // Stop the application timer that is triggering the notifications
            err_code = app_timer_stop(m_notification_timer_id);
        case BLE_CUS_EVT_CONNECTED:
        case BLE_CUS_EVT_DISCONNECTED:
        case BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED:
/**@brief Function for searching for a device name and adding it to a dynamic command.
 * @details Use this function to parse the received advertising data and to find a given
 * name in them either as 'complete_local_name' or as 'short_local_name'.
 * @param[in]   p_adv_report   Advertising data to parse.
//static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report, uint16_t const *p_gatts_uuid)
    uint8_t  idx             = 0;
    uint16_t dev_name_offset = 0;
    uint16_t field_len;
    data_t   adv_data;
    // Initialize advertisement report for parsing
    adv_data.p_data   = (uint8_t *)p_adv_report->data.p_data;
    adv_data.data_len = p_adv_report->data.len;
    for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
        // If address is duplicated, then return.
        if (memcmp(p_adv_report->peer_addr.addr,
                   m_device[idx].addr,
                   sizeof(p_adv_report->peer_addr.addr)) == 0)
             /* update rssi value */
            memcpy(&m_device[idx].RSSI_value_RK,
                   &p_adv_report->rssi,
                   sizeof(p_adv_report->rssi));
            return;
    // Add device data if an empty record is found.
    for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
        if (!m_device[idx].is_not_empty)
          /* store peer address */
            memcpy(m_device[idx].addr,
                   sizeof(p_adv_report->peer_addr.addr));
            /* store rssi value */
            m_device[idx].is_not_empty = true;
            // Search for advertising names.
            field_len = ble_advdata_search(adv_data.p_data,
                                           adv_data.data_len,
                                           &dev_name_offset,
                                           BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
            if (field_len == 0)
                                               adv_data.data_len,
                                               &dev_name_offset,
                                               BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME);
                // If name is not found, then return.
                if (field_len == 0)
                    return;
            memcpy(m_device[idx].dev_name, &adv_data.p_data[dev_name_offset], field_len);
            m_device[idx].dev_name[field_len] = 0;
            return;
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
#ifdef RK_CLI //test scan filters
       case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            //Add devices to the list if the scan filter is matched
            device_to_list_add(p_scan_evt->params.filter_match.p_adv_report);
        }break;
//      case NRF_BLE_SCAN_EVT_NOT_FOUND:
//           if (p_scan_evt->params.filter_match.p_adv_report->peer_addr.addr[0] == 0x88)
//           NRF_LOG_RAW_INFO("Filter not found\r\n");
//          }break;
#endif //RK_CLI //test scan filters
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             // Scan is automatically stopped by the connection.
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
             ret_code_t ret;
            ret = nrf_ble_scan_start(&m_scan);
            APP_ERROR_CHECK(ret);
            ret = bsp_indication_set(BSP_INDICATE_SCANNING);
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = false;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    //add 'NRF_BLE_SCAN_UUID_CNT' filters
    for(int n_count = 0; n_count < NRF_BLE_SCAN_UUID_CNT; n_count++)
      err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_scan_uuid[n_count]);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/** @brief Function for initializing BLE components.
void ble_init(void)
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    APP_ERROR_CHECK(nrf_cli_ble_uart_service_init());
    peer_manager_init();
#ifdef RK_CLI
    scan_init();
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, 0);
#ifdef RK_CLI
    ret_code_t ret;
void scan_stop(void)
    ret_code_t ret;
    nrf_ble_scan_stop();
void int_addr_to_hex_str(char * p_result, uint8_t result_len, uint8_t const * const p_addr)
    ASSERT(p_result);
    ASSERT(p_addr);
    if (result_len > BLE_GAP_ADDR_LEN)
        return;
   // char buffer[BLE_GAP_ADDR_LEN] = {0};
    char tempbuffer = '\0';
    memset(p_result, 0, result_len);
    for (uint8_t i = 0; i < result_len; ++i)
        sprintf(&tempbuffer, "%.2X", p_addr[result_len - (i+1)]);
        strcat(p_result, &tempbuffer);
        if (i < (result_len - 1))
            strcat(p_result, ":");
/* Below funciton displays the scanned device list */
void device_list(nrf_cli_t const *p_cli, scanned_device_t * p_device )
    for (uint8_t i = 0; i < DEVICE_TO_FIND_MAX; i++)
        if (p_device[i].is_not_empty)
            nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Device ");
            char buffer[ADDR_STRING_LEN];
            int_addr_to_hex_str(buffer, BLE_GAP_ADDR_LEN, p_device[i].addr);
            nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s %s %d dB\r\n", buffer,  p_device[i].dev_name, p_device[i].RSSI_value_RK);
static void scan_on_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
    scan_start();
    nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scanning...\r\n");
static void scan_off_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
    scan_stop();
    nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scan stopped.\r\n");
static void display_device_list_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
  if (argc >= 2)
        if (nrf_cli_help_requested(p_cli))
            nrf_cli_help_print(p_cli, NULL, 0);
            return;
                            NRF_CLI_ERROR,
                            "%s:%s%s\r\n",
                            argv[0],
                            " bad parameter ",
                            argv[1]);
            return;
    /* Print connectable devices from scan data.*/
    scanned_device_t * p_device_list = scan_device_info_get();
    device_list(p_cli, p_device_list);
static void default_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
  if (argc >= 2)
            return;
                            NRF_CLI_ERROR,
                            "%s:%s%s\r\n",
                            argv[0],
                            " bad parameter ",
                            argv[1]);
            return;
// Register "mpu" command and it's subcommands in CLI.
NRF_CLI_CREATE_STATIC_SUBCMD_SET(scan_commands)
     NRF_CLI_CMD(on, NULL, "Scan on.", scan_on_cmd),
     NRF_CLI_CMD(off, NULL, "Scan off.", scan_off_cmd),
     NRF_CLI_SUBCMD_SET_END
NRF_CLI_CMD_REGISTER(scan, &scan_commands, "Commands for scan control", default_cmd);
NRF_CLI_CMD_REGISTER(devices, NULL, "print device list", display_device_list_cmd);
void idle_task(void * p_context)
    bool erase_bonds = (bool)p_context;
      advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
            nrf_pwr_mgmt_run();
        task_yield();
static void core_init(void)
    APP_ERROR_CHECK(NRF_LOG_INIT(app_timer_cnt_get));
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    APP_ERROR_CHECK(nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO));
    APP_ERROR_CHECK(nrf_drv_clock_init());
    APP_ERROR_CHECK(app_timer_init());
    APP_ERROR_CHECK(nrf_pwr_mgmt_init());
    APP_ERROR_CHECK(nrf_cli_task_create(&m_cli_uart));
/**@brief Function for application main entry.
    bool erase_bonds;
    core_init();
    ble_init();
    NRF_LOG_RAW_INFO("BLE Nordic Uart Service started\r\n");
    NRF_LOG_RAW_INFO("Press Tab to view all available commands.\r\n");
    task_manager_start(idle_task, (void *)erase_bonds);
#include "sdk_common.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
/**@brief Function for handling the Connect event.
 * @param[in]   p_cus       Custom Service structure.
 * @param[in]   p_ble_evt   Event received from the BLE stack.
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_CONNECTED;
    p_cus->evt_handler(p_cus, &evt);
/**@brief Function for handling the Disconnect event.
static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    UNUSED_PARAMETER(p_ble_evt);
    p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
/**@brief Function for handling the Write event.
static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    ble_cus_evt_t evt;
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    // Custom Value Characteristic Written to.
    if (p_evt_write->handle == p_cus->oxy_measurement_handles.value_handle)
        nrf_gpio_pin_toggle(LED_4);
    // Check if it is the Servo Control Characteristic that has been written to
    if (p_evt_write->handle == p_cus->nonin_control_point_handles.value_handle)
      // Set the event type
      evt.evt_type = BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED;
      // Assign the written value in the ble_cus_evt_t struct
      evt.servo_ctrl_value = p_evt_write->data[0];
      // Invoke the on_cus_evt event handler in main.c
    // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
    if ((p_evt_write->handle == p_cus->oxy_measurement_handles.cccd_handle)
        && (p_evt_write->len == 2)
        // CCCD written, call application event handler
        if (p_cus->evt_handler != NULL)
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
            // Call the application event handler.
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
    ble_cus_t * p_cus = (ble_cus_t *) p_context;
   // NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
    if (p_cus == NULL || p_ble_evt == NULL)
        return;
            on_connect(p_cus, p_ble_evt);
            on_disconnect(p_cus, p_ble_evt);
        case BLE_GATTS_EVT_WRITE:
            on_write(p_cus, p_ble_evt);
/**@brief Function for adding the Custom Value characteristic.
 * @param[in]   p_cus        Battery Service structure.
 * @param[in]   p_cus_init   Information needed to initialize the service.
 * @return      NRF_SUCCESS on success, otherwise an error code.
//static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
//    uint32_t            err_code;
//    ble_gatts_char_md_t char_md;
//    ble_gatts_attr_md_t cccd_md;
//    ble_gatts_attr_t    attr_char_value;
//    ble_uuid_t          ble_uuid;
//    ble_gatts_attr_md_t attr_md;
//    // Add Custom Value characteristic
//    memset(&cccd_md, 0, sizeof(cccd_md));
//    //  Read  operation on cccd should be possible without authentication.
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
//    cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
//    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
//    memset(&char_md, 0, sizeof(char_md));
//    char_md.char_props.read   = 1;
//    char_md.char_props.write  = 1;
//    char_md.char_props.notify = 1;
//    char_md.p_char_user_desc  = NULL;
//    char_md.p_char_pf         = NULL;
//    char_md.p_user_desc_md    = NULL;
//    char_md.p_cccd_md         = &cccd_md;
//    char_md.p_sccd_md         = NULL;
//    ble_uuid.type = p_cus->uuid_type;
//    ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
//    memset(&attr_md, 0, sizeof(attr_md));
//    attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
//    attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
//    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
//    attr_md.rd_auth    = 0;
//    attr_md.wr_auth    = 0;
//    attr_md.vlen       = 0;
//    memset(&attr_char_value, 0, sizeof(attr_char_value));
//    attr_char_value.p_uuid    = &ble_uuid;
//    attr_char_value.p_attr_md = &attr_md;
//    attr_char_value.init_len  = sizeof(uint8_t);
//    attr_char_value.init_offs = 0;
//    attr_char_value.max_len   = sizeof(uint8_t);
//    err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
//                                               &attr_char_value,
//                                               &p_cus->custom_value_handles);
//    if (err_code != NRF_SUCCESS)
//        return err_code;
//    return NRF_SUCCESS;
///**@brief Function for adding the Custom Value characteristic.
// * @param[in]   p_cus        Battery Service structure.
// * @param[in]   p_cus_init   Information needed to initialize the service.
// * @return      NRF_SUCCESS on success, otherwise an error code.
//static uint32_t servo_ctrl_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
//    char_md.char_props.notify = 0;
//    memset(&ble_uuid, 0, sizeof(ble_uuid));
//    ble_uuid128_t base_uuid_2 = {CUSTOM_SERVICE_UUID_BASE_2};
//    err_code =  sd_ble_uuid_vs_add(&base_uuid_2, &p_cus->uuid_type_2);
//    VERIFY_SUCCESS(err_code);
//    ble_uuid.type = p_cus->uuid_type_2;
//    ble_uuid.uuid = SERVO_CTRL_CHAR_UUID;
//                                               &p_cus->servo_control_handles);
//        return err_code;
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    if (p_cus == NULL || p_cus_init == NULL)
        return NRF_ERROR_NULL;
    uint32_t   err_code;
    ble_add_char_params_t add_char_params;
    // Initialize service structure
    p_cus->evt_handler               = p_cus_init->evt_handler;
    // Add Nonin Oxy sensor Service UUID BASE
    ble_uuid128_t base_uuid = BLE_UUID_NONIN_SENSOR_SERVICE_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
    ble_uuid.uuid = BLE_UUID_NONIN_SENSOR_SERVICE;
    // Add the Custom Service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
        return err_code;
    // Add UUID BASE for the Oxy measurement characteristic
    ble_uuid128_t base_uuid_oxy_measurement = BLE_UUID_OXY_MEASUREMENT_CHARACTERISTIC_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid_oxy_measurement, &p_cus->uuid_type_oxy_measurement);
    //Add the oxymetry measurement Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_OXY_MEASUREMENT_CHARACTERISTIC;
    add_char_params.uuid_type                = p_cus->uuid_type_oxy_measurement;
    add_char_params.max_len                  = sizeof(uint8_t);
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.write         = 1;
    add_char_params.char_props.write_wo_resp = 1;
    add_char_params.read_access  = SEC_OPEN;
    add_char_params.write_access = SEC_OPEN;
    err_code = characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->oxy_measurement_handles);
        return err_code;
    // Add UUID BASE for Nonin control point characteristic
    ble_uuid128_t base_uuid_nonin_control_point = BLE_UUID_NONIN_CONTROL_POINT_CHARACTERISTIC_BASE;
    err_code =  sd_ble_uuid_vs_add(&base_uuid_nonin_control_point, &p_cus->uuid_type_nonin_control_point);
    // Add the Nonin control point Characteristic.
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
    add_char_params.uuid              = BLE_UUID_NONIN_CONTROL_POINT_CHARACTERISTIC;
    add_char_params.uuid_type         = p_cus->uuid_type;
    add_char_params.char_props.notify = 1;
    add_char_params.cccd_write_access = SEC_OPEN;
    return characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->nonin_control_point_handles);
uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value)
    NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
    if (p_cus == NULL)
    uint32_t err_code = NRF_SUCCESS;
    ble_gatts_value_t gatts_value;
    // Initialize value struct.
    memset(&gatts_value, 0, sizeof(gatts_value));
    gatts_value.len     = sizeof(uint8_t);
    gatts_value.offset  = 0;
    gatts_value.p_value = &custom_value;
    // Update database.
    err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
                                      p_cus->oxy_measurement_handles.value_handle,
                                      &gatts_value);
        return err_code;
    // Send value if connected and notifying.
    if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_cus->oxy_measurement_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = gatts_value.offset;
        hvx_params.p_len  = &gatts_value.len;
        hvx_params.p_data = gatts_value.p_value;
        err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
        NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
        err_code = NRF_ERROR_INVALID_STATE;
        NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
    return err_code;
ble_cus.hsdk_config.h\
i have modified ble_app_cli example code to achieve my requirements. attached files main.c, sdk_config.h, ble_cus.c(custom service), ble_cus.h
