hi...
i am working on mesh , i have done light switch example , now i want to get some message from node and send to particular node . how to print the same message which is from particular node to uart termite
please help me out.
thanks in advance
hi...
please help me out.
thanks in advance
message_create(p_client, GENERIC_ONOFF_OPCODE_SET, (const uint8_t *) &p_client->msg_pkt.set,
server_msg_length, &p_client->access_message.message); in this case which paramater i should send message
If you are sending a generic on off set message, the set_params variable in generic_onoff_client_set(&m_clients[0], &set_params, &transition_params); will send the message data, which will send a bool value state. Like I have mentioned previously, one of the updates you will need to make is to change this bool value to a character string. The message_set_packet_create function takes the set_params variable & makes changes via call by reference to the first argument provided (i.e. &p_client->msg_pkt.set).
how to change the bool value to a character string
That's standard 'C' - nothing to do with Nordic.
A moment with google:
https://stackoverflow.com/questions/17307275/what-is-the-printf-format-specifier-for-bool
ps_anu I did not mean to typecast the bool value to a character string, but instead of using bool on_off inside generic_onoff_set_params_t, you could use a fixed size variable e.g. char[3] msg
It should hopefully not be too hard to make the required changes required to send a message of a constant size over the mesh. You should also be able to provision & configure a custom model with nRF Mesh.
