When 128bit characteristic UUID is different form 128bit service UUID,how to discovery it?
I have the same problem as how to discovery 128bit characteristic UUID which is totally different form 128bit service UUID,the uuid in this question is the same with me,but I can not find solution .
I modified the ble_nus_c_init()  like this:
#define BASE_UUID                   {{0xfb,0x34,0x9b,0x5f,0x80,0x00,0x00,0x80,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00}}
#define BASE_UUID_FEE9              {{0xfb,0x34,0x9b,0x5f,0x80,0x00,0x00,0x80,0x00,0x10,0x00,0x00,0xe9,0xfe,0x00,0x00}}
#define BASE_UUID_CHAR_RX           {{0x00,0x96,0x12,0x16,0x54,0x92,0x75,0xb5,0xa2,0x45,0xfd,0xab,0x39,0xc4,0x4b,0xd4}}
#define BASE_UUID_CHAR_TX           {{0x01,0x96,0x12,0x16,0x54,0x92,0x75,0xb5,0xa2,0x45,0xfd,0xab,0x39,0xc4,0x4b,0xd4}}
uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)
    uint32_t      err_code;
    ble_uuid_t    uart_uuid,ble_uuid1,ble_uuid2;
    ble_uuid128_t nus_base_uuid =BASE_UUID;         //NUS_BASE_UUID;
    ble_uuid128_t base_uuid1 = BASE_UUID_CHAR_RX;
    ble_uuid128_t base_uuid2 = BASE_UUID_CHAR_TX;
    VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
    VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
    VERIFY_SUCCESS(err_code);
    uart_uuid.type = p_ble_nus_c->uuid_type;
    uart_uuid.uuid = 0xfee9;            //BLE_UUID_NUS_SERVICE;
    p_ble_nus_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
    p_ble_nus_c->evt_handler           = p_ble_nus_c_init->evt_handler;
    p_ble_nus_c->handles.nus_tx_handle = BLE_GATT_HANDLE_INVALID;
    p_ble_nus_c->handles.nus_rx_handle = BLE_GATT_HANDLE_INVALID;
    ble_db_discovery_evt_register(&uart_uuid);
    ble_uuid1.uuid = 0;
    err_code = sd_ble_uuid_vs_add(&base_uuid1, &ble_uuid1.type);
    ble_uuid2.uuid = 0;
    err_code = sd_ble_uuid_vs_add(&base_uuid2, &ble_uuid2.type);
    err_code=ble_db_discovery_evt_register(&ble_uuid1);
    err_code=ble_db_discovery_evt_register(&ble_uuid2);
    return err_code;
And I set NRF_SDH_BLE_VS_UUID_COUNT to 4 , modified the ram start and size.
I can't receive the event BLE_DB_DISCOVERY_COMPLETE, but  receive event  BLE_DB_DISCOVERY_ERROR and BLE_DB_DISCOVERY_SRV_NOT_FOUND
When I change 0xFEE9 to 0xFEE8 I can receive the event BLE_DB_DISCOVERY_COMPLETE,but characteristic.uuid.uuid = 0x00 I don't know why.
How to discovery 128bit characteristic UUID which is totally different form 128bit service UUID?
Can someone help me?
NRF52832   SDK14.2  code base "on ble_app_uart_c"   pca10040  s132
Thanks.
  • Hi
    There are many service in the BLE peripheral device. The BLE peripheral UUID I can get from nRF Connect APP, see the picture below please.
    The blue mark (fee8) is the UUID I can discovery . The red mark (fee9) is the UUID I want to discovery , but failed.The way I used to discovery the two uuid(fee8 and fee9) is the same(Like the init function above).
    In the nRF Connect APP ,when I click the yellow mark, I can receive the data I want.
  • That´s not what I´m asking. I´m asking if you're also trying to discover other services in your central application. And how are you starting the discovery in your central application?
  • The 0xfee9 service UUID is the only service I want to discovery. I had discovery other services successful.
    This is the code I used to discovery in my central application , this is in the ble_evt_handler() function:
            case BLE_GAP_EVT_CONNECTED:
                ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle);
    I am making changes based on ble_app_uart_c project.
  • I found I can't insert the code success, let me try again:
  • HI
    When I register both 0xfee8 and 0xfee9 at the same time by ble_db_discovery_evt_register() function. The value of p_evt->evt_type is 0x01.p_evt->params.err_code is 0x0011 (NRF_ERROR_INVALID_DATA) What does this error mean?
